CK = CM replacement?
  • salawayon
    • Nov 2012
    • 572
    • philippines
    i have this dell laptop with this CK = CM chip getting hot, and i want know what is the replacement ic for this one? and how can i know by its code (top mark) that this ic is the same with other ic? just like CK = DK is same with RT5205 and TPS 51125....
    thanks...
  • Momad
    • May 2013
    • 24
    • ITALY
    Re: CK = CM replacement?
    Hi! Write your Model No. of the Laptop.
    First search the schematics of the Motherboard (MOBO) of your Laptop with the code number of (MOBO), usually found under the sheet of protection under the Ram socket or other area on superface of Mobo, frome the schematics and after you identific the IC Model, type, Function. Search the Datasheet of your IC, look for model, type(Function), how many Pins and configuratione connectionand. If you not found the same IC, now you can searche anather IC with all these Informations.
    • spidey
      climbs
      • Dec 2012
      • 644
      • Cyprus
      Rt8205bgqw
      • salawayon
        • Nov 2012
        • 572
        • philippines
        Thanks spidey. How about if i want to replace it with TI chip? Does TI got a replacement for this?
        • masud
          • Jul 2011
          • 317
          • Bangladesh
          DT=CC stands for ??
          • spidey
            climbs
            • Dec 2012
            • 644
            • Cyprus
            You must check from the schematics about pin 18. if it is N/C you can safely use TPS51125.
            • salawayon
              • Nov 2012
              • 572
              • philippines
              Thanks. Btw, it's dell inspiron N4030... Do you have schematics? I can't find rt8205b on my junk boards.... And pin18 somewhat is in use because it has a resistance reading when Chip is removed....
              • salawayon
                • Nov 2012
                • 572
                • philippines
                Sorry, i've measured pin24. At pin18 there's a small caps connected and no resistance reading with respect to ground....
                • lezsimply
                  The Wanderer
                  • 645
                  • Philippines
                  @ salawayon
                  I'm having same issue, TPS51125 is getting very hot. Have you succeeded in replacing this regulator? Thanks
                  • Momad
                    • May 2013
                    • 24
                    • ITALY
                    Where you found, DT=CC stands for ??
                    At the schematics o IC marked?
                    • khaahk
                      • Dec 2013
                      • 778
                      • Estonia
                      here
                      • sanehdeep2012
                        • Oct 2013
                        • 139
                        • india
                        Originally posted by khaahk
                        here
                        thanks for your info this will help me lot
                        thanks again
                        • mrsith
                          Dell G3 17 3779 - no display after mobo replacement
                          by mrsith
                          Hi guys,
                          I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
                          Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
                          04-30-2023, 05:11 AM
                        • reformatt
                          Macbook Air M2 A2681 Kernel panics after screen replacement
                          by reformatt
                          Just had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
                          It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...
                          07-31-2025, 08:37 PM
                        • the_rem
                          Unknown transformer : how to find a good replacement part ?
                          by the_rem
                          Hello guys,
                          I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                          I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                          04-23-2025, 01:48 AM
                        • ezenia
                          PS4 controller left stick potentiometer replacement issue
                          by ezenia
                          Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                          So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                          I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                          09-30-2023, 02:19 PM
                        • boosti45
                          Macbook pro logic board replacement parts quesion
                          by boosti45
                          i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                          08-21-2024, 05:23 AM
