14 blinks TC-P50ST30
  • scpat97
    • May 2014
    Re: 14 blinks TC-P50ST30
    Northwestdad - Sorry for your issues as I'm having the same problem you are,, exactly.. Just wondering if you had any luck following up with moduslink.com as I'm having a hard time finding the SC board as well.. WIll probably give it a shot with repair kit they are selling if all else fails
    tw2005 - see all of your feedback and everything has worked for but I can't seem to get any reading on multimeter from pins to ground to check the SD and SU boards.. Does that prove there isn't a short?
    With the buffer boards if you have a meter measure these points.
    SU board at connector SU41 , each of these pins 2,6,8 with respect to the gnd plate on buffer.
    likewise, pin 6,2,1 SD42 to gnd plate on buffer.
    disconnect the little white ribbon in between, disconnectd from the sc board also.
    should be ok but to be sure.
    • northwestdad
      • Feb 2014
      • 51
      • usa
      #102
      Well, I can say that ModusLink is consistantly not the best at communication. It took over a month for my board to be shipped back the first time, and was only after I inquired about the status did they inform me they had to wait for a componant to arrive. The order status was listed as "waiting for shipment" leading me to believe that it was ready to ship back for a couple weeks but never arrived. Eventually I contacted them and that's when I was informed about the wait for an additional part. When the repaired board did arrive and subsecquently failed, it was necessary to navigate their website to find the instructions for returning something under warranty. Within 48 hours I had the return authorization, but no instructions or packslip notes so I just shipped it back on my own dime, which was around $12.50 US. I sent it back over a week ago and there is no change to the status...still says "approved for return". Right now I'm in it for around $25.00 in shipping + the original cost of the repair, so I'm getting closer to the price of just purchasing a new/used functional board.
      • tw2005
        • Oct 2011
        • 6458
        sorry to hear of the troubles. probably gives us a more balanced view on what's going on. Of the few posts i've seen by their report Modus have been alright, but not for you it seems.
        Do you get to talk to a real person or is it all online contact?
        • scpat97
          • May 2014
          So I found a replacement SC board for my TV ( TC-P50ST30 ) and I ordered correctly but they didn't send me the right board.. Instead of sending TNPA5351AQ they send TNPA5351AM.. I'll follow up as I know more as I have an email out to the company now.. Link below where I purchased..
          https://www.emtcompany.com/panasonic...101337111.html
          @TW2005 - Just a follow up, I couldn't find an shorts between ground and pins at SD42 and SU41.. Is that a good enough test to ensure my SD and SU boards are good?
          • tw2005
            • Oct 2011
            • 6458
            The link did not work. No shorts at those is a good start. could also run a continuity test between the gnd plates and the outputs of the buffer ICs or measure resistance.
            I trust we're talking about pins for, VF5V, VSCN-F, VFO only.
            TNPA5351AM would work but it's not matched to your panel.
            The differences on the board are subtle, c643,c644 are not populated on yours but are on the AM. Could be others but that's a quick example of the difference.
            • northwestdad
              • Feb 2014
              • 51
              • usa
              #106
              ***UPDATE***
              The board was re-repaired and arrived yesterday. I hooked everything up and so far so good. Got a few hours of viewing in without any hiccups.
              Huge thank you to TW2005. Your information was spot on.
              Anyone who has the same issue as me, I highly recommend you follow the testing and isolation steps listed above to confirm a faulty SC board.
              Regarding ModusLink:
              They were one of the only location I found that was offering a repair of the board rather then buying a new/used one at twice the price. They also had a big special going on at the time which made the repair choice a nobrainer. Overall their customer service team is responsive to inquiry as my questions where answered usually within 24 hours (excluding holidays/weekends). However, it is up to the customer to ask the questions rather then assuming.
              Specific examples to consider:
              1. The original repair took nearly a month to complete when the predicted timeframe was 3-5 business days. The issue was due to a part being on backorder. My order status when viewed online merely stated "awaiting shipment". Easy to assume that meant the board was completed and ready to be shipped. After three weeks of being in that status I finally emailed and asked what the deal was. It was only then that they responded informing me of the delay. When the repair was completed the status was changed and a tracking number provided.
              2. After the original repair failed right away, I went to their website to learn how to request a return under warranty. It took some initial searching but eventually there was a link to request a return. The request was approved the next day, but no instructions on what to do or any type of packslip, RMA form to include, or a return shipping label. I ended up just shipping it back on my own coin. However, when I did ask about it they offered to reimburse my shipping cost if I could forward a copy of the receipt. They said most customers ask specifically for a return shipping label. Seems to me it should automatically generate when approving a return.
              3. The board was returned on May 12 and there was no confirmation about it being received or what the official finding was (bad repair or otherwise). I emailed them on May 24 asking about the status and received a response back on the 26th saying it had been repaired again and shipped back on the 20th. No tracking number was provided so I had to ask for it separately. They provided the tracking number yesterday, and the board arrived that afternoon.
              So overall my experience with them was good and they offered a good service at a good price. Communication was quick, but I had to initiate most of it. In short I would definitely recommend them but don't merely assume they are as automated as other organizations (like ShopJimmy for instance).
              • tw2005
                • Oct 2011
                • 6458
                ***UPDATE***
                Thanks for the feedback. I was fairly confident the diagnosis was correct and the issue most likely was a dud repair.
                Even better now that it's been proven though and your TV is now good.
                Good info on your part, keeps the forum balanced and sure to help many.
                • northwestdad
                  • Feb 2014
                  • 51
                  • usa
                  #108
                  ***Additional Update****
                  TV is still working solidly. It is a noisy unit (buzzing), but I believe that's normal for this set. Overall very satisfied. All said and done, my out-of-pocket expenses where $100 for the non-working tv, $48 for the board repair, and around $20.00 total for shipping various boards ordered and returned. I bought the TV on March 5 and it was officially resurrected on May 27. Loads of frustration (and learning) during those 2 1/2 months, but in the end I'm quite happy.
                  I'm now feeling ready to invest in some 3D glasses and would like to know which one's to purchase. The tv has a 2D - 3D converter for non-3D content, but have no idea how well it works. Figured it would be fun watching World Cup matches in 3D. I didn't see the type of glasses required listed in the manual, and going online reveals hundreds of different options. I don't mind spending $50 or so just to try something out to see if it is worth watching an entire program, but am not going to drop several hundred on high end equipment. I anticipate I may rarely use the 3D function anyways.
                  • scpat97
                    • May 2014
                    Thanks TW2005 from me as well.. Got a replacement SC board for 110 bucks and the kids couldn't be happier.. Hopefully this will get me thru the next 5 years...
                    northwestdad - I installed lock washers ( 3mm ) on all of the screws for the SC, SS, SD, SU and pretty much any other screw that didn't have a lock washer and that got rid of the humming / buzzing sound.. Pretty easy to find at any hardware store for a few bucks.. I can't imagine that it's good for the board and may be one of the factors that's causing the board to fail?? You never know though
                    • northwestdad
                      • Feb 2014
                      • 51
                      • usa
                      #110
                      scpat97....really? Lock washers on all the mounting screws holding the boards in place helped? I figured it was just the components or something. If the volume is up I don't even notice the buzzing, but I'll keep that in mind in case it really becomes too annoying.
                      What do the lock washers accomplish that properly tightened screw doesn't? that would be a super cheap fix.
                      • tw2005
                        • Oct 2011
                        • 6458
                        If you have to turn the TV up to mask the buzzing, probably not a bad idea to make sure all the screws and boards are secure.
                        Some if not most are earthing points and there have been a few posts now regarding arcing and blowing boards due to bad screws and earth.
                        It's been said that the wrong screws were used in assembly.
                        I've worked on a few Panasonic plasmas, never been noisy, the only time one made a racket was my main TV when i did not have all the screws in and tight during fault finding.
                        Otherwise you'd have to have your ear right next to the set to hear the buzz of the sustain boards.
                        • northwestdad
                          • Feb 2014
                          • 51
                          • usa
                          #112
                          I took the back cover off last night and checked every screw I could easily access with a screwdriver and sure enough there were several that I was able to get another 1/4 turn in. I had originally used an electric drill with the clutch set really low as to not damage the boards, but they still should have been tighter then they were. With the back cover off the buzz was still very noticeable, but not as much so, and only when there was a blank screen. Once images started moving around it quieted considerably. With the cover back on it made a world of difference.
                          Once again....YOU GUYS ROCK!
                          • tw2005
                            • Oct 2011
                            • 6458
                            electric screwdriver on an electronic board Imagine if the tip spun and jumped out of the screw and onto the board, still spinning. Chance of breaking the copper tracks or taking out a surface component.
                            Anyway, the TV works.
                            • northwestdad
                              • Feb 2014
                              • 51
                              • usa
                              #114
                              TV continues to be great. The buzzing is still present when a solid color image appears like a white background or the red when Netflix starts up. Once the video gets going it quiets down.
                              I took a chance and purchased some 3D glasses for this and was pretty impressed with the 2D-3D conversion...particularly when watching a soccer match with my 14 year old. I don't have a 3D player yet but hopefully it will be even better.
                              • Shinju
                                • Mar 2014
                                • 1239
                                I ordered a panny mainboard for my TC-P50G15 from ModusLink one of there "new" probably a rebuild but I have yet to see the status change from Awaiting Shipping to Shipped.
                                good to hear their parts are solid!
                                • northwestdad
                                  • Feb 2014
                                  • 51
                                  • usa
                                  #116
                                  They were responsive via email so I'd inquire on the actual status. I don't remember if I was able to find a phone number or not, but I think they are in Indiana and so a 3-hour time difference between West Coast (or maybe they are in Central Time Zone).
                                  • Shinju
                                    • Mar 2014
                                    • 1239
                                    NVM, had to dig deep lol, they really don't want to be bothered!
                                    • hrdcoretexan
                                      • Sep 2014
                                      • US
                                      #118
                                      I realize this is an old thread, so I may not get a response, but I'll try anyway.
                                      Let me start by saying I have zero electronics repair experience, so I apologize if I ask a silly question.
                                      I have a TC-P42ST30 that is just under 3 years old. Earlier today, an AT&T u-Verse tech was out trying to troubleshoot quality of service problems we've been having for a couple of weeks. He went outside to the AT&T network box, on the back of my house, to check for a good ground. Came inside and said it was okay and then left shortly thereafter. About 15 minutes after this, my son told me the TV had shut off and wouldn't come back on. The red power LED was still on and I had to unplug the power cord to get it off. After plugging it back in, I get the 14 blinks.
                                      My question is this: Is it possible that something the AT&T tech did caused the problem, or is it probably just a wild coincidence?
                                      Thank you!
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        Thank you!
                                        Wild coincidence I would say. Being Non -US, what does an AT&T network box do? Is this just a phone/internet connection?
                                        shorted SN board would be my first guess, fairly prevalent with these.
                                        If it is I would suggest sending it to ModuslinkPTS since you have no knowledge
                                        http://www.moduslinkptstvboards.com/TXNSN1PKUU/
                                        I would ask them also since TNPA5349AB and TNPA5349AD are equivalents then why are they quoting $30 more for the AB? I would expect the failure points to be the same and the parts are most likely too.
                                        From what I can work out, the only difference between the 2 boards is the style of connector at SN20. I realise you may not understand but that's the connector that the white ribbon connects to from the A board.
                                        One is $104, the other $75
                                        • tw2005
                                          • Oct 2011
                                          • 6458
                                          well I tried with Modus on their pricing.
                                          here's their response and I must point out, no salutation or Company title block or name at the end. very,very weird and unprofessional for a company
                                          with any quality assurance,
                                          "We appreciate your feedback very much. We set our pricing based on average parts and labor cost per board, so in the cases below we have found that we average more labor/parts for the higher priced boards and have found that using this model our pricing will vary some even on exact substitution boards. ......................................"
                                          • Biruslapio
                                            Panasonic P58V11B 8 and 12 blinks error "fix"
                                            by Biruslapio
                                            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                            04-13-2021, 07:13 AM
                                          • Nairolf
                                            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                            by Nairolf
                                            I have a Samsung DM32D display.
                                            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                            Here’s what I have tried so far:
                                            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                            From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                            Today, 03:47 AM
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            11-20-2024, 08:52 PM
                                          • Taurus12
                                            Optiplex 3050 micro 2 blinks followed by 3 blinks issue
                                            by Taurus12
                                            Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
                                            I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
                                            i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
                                            Any recommendation on what I have to do next? Thanks in advance
                                            06-10-2025, 05:05 PM
                                          • jchon
                                            Sony A1e 5-blinks help
                                            by jchon
                                            Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                                            I found the service manual, which was critical to know where to probe.
                                            https://www.manualslib.com/manual/20...1e-Series.html
                                            With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                                            Unfortunately the 5-blinks...
                                            06-28-2023, 11:52 AM
