Sony STR-DH820 not powering up
  • the loner
    • Feb 2013
    • 55
    I have purchased this AV amp, (along with 3 others, but I want to work on 1 maybe 2 at a time) from an auction for cheap, $40 for 4 of them.
    When I plug in the amp, I can hear the relay click on to energize it(it is a Tyco Electronics SDT-S-105DMR2).
    If I unplug and re plug it back in, after about 20 or so times, it will power on .
    When it does power on, I get sound from the 2 speakers that I connected to it, I haven't plugged in all 7 speakers in because I'm trying to get it to work.
    I have a feeling that it maybe the relay being weak, or maybe a cap that is dying, but I don't know how to test it to correctly find the problem.
    These are my voltage readings.
    From the power plug
    71.7 V hot (black)
    25.2 V common (white)
    Fuse 71.4V both sides
    Relay has 5.2V from under side
    First picture.
    I could be wrong, but the transformer looks burnt, but that maybe the from the welding (second picture)
    DCDC power supply voltages (third picture) are as follows...
    starting from left plug pin 1 working to the right
    14.53v,
    n/c,
    0v,
    0v,
    0v,
    6.3v
    right plug pin 12 working to the right
    6.3v,
    0v,
    3.95v,
    3.95v,
    n/c,
    6.3v,
    6.3v,
    0v,
    0v,
    3.9v,
    n/c,
    3.9v
    The next 6 pictures are what looks like fluid/water damage which I'm not to worried about, I have cleaned up the board but if I can get it working properly, then I will put all boards into my ultrasonic cleaner.
    The last picture is the bottom of the power supply.
    I know that you don't really do amplifiers, but any help would be greatly appreciated.
    Thanks.
    Re: Sony STR-DH820 not powering up
    I cannot find the service manual for this model, but from the look of the first picture which has the small transformer and relay on it, that should be the standby power supply to run the main board, when the receiver the turn on command from the remote or the power switch, the main board will then send the signal to turn the big power transformer through the relay contact. So if the relay contact is bypassed, then you should see 120V on the primary winding of that big transformer.
    By the way, when you measure the AC in the primary side, you do not use the safety/chassis ground as the ref point, that is why you are reading 71V on the Hot (black), you will put the AC probe on the Hot and Neutral to see the AC input voltage feeding the transformers.
    • the loner
      • Feb 2013
      • 55
      Thanks budm. I do get 115.9v when connected properly as you stated.
      I have the service manual also.
      I just don't know what to check as the amp will turn on after about 20 un plugs and re plugs to get it to come on, it's a guessing game and the luck of the draw when it comes on.
      When it does work and I shut it off, then try to turn it back on again, I go through the same process of un plugging and re plugging it in.
      • rhomanski
        nowhere man
        • 5157
        • U S of A
        Sounds like the contacts in the relay. Either open it up and clean them or replace the relay.
        sigpicThe Sky Is Falling
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          I wonder if it is one of those "energy saving", "switching" standby power supplies.
          Like this one from the EEVblog: http://www.youtube.com/watch?v=MwvjAtSr5t8
          Muh-soggy-knee
          • the loner
            • Feb 2013
            • 55
            Thanks rhomanski, the relay is the problem. I sanded the contacts and it works a lot better, I just need it to work 100% as it will be given to my father in law as a present.
            I just need to source out a relay now.
            If I can't find a direct replacement relay, can I use one of these as a substitute...
            SDT-S-105LMR2,000 5VDC Sensitive 150mW coil 8-1419125-3 or
            SDT-S-105DMR,000 5VDC standard coil 8-1419125-0 or
            SDT-S-105LMR,000 5VDC Sensitive new design AgSnO2 1 form A (NO) 250mW 8-1419125-1
            Either I'm not looking in the right place or I can't seem find exactly what I'm looking for.
            And I don't need 500+ minimum quantity, just 1
            • the loner
              • Feb 2013
              • 55
              I hope that I don't get into any trouble posting the relay data sheet but here it is...
                So what is the original relay P/N as printed on the body? SPST (Single Pole Single Throw) type? Or it is the one you post the PDF spec ?
                • the loner
                  • Feb 2013
                  • 55
                  The original relay # is SDT-S-105DMR2. I put the pdf sheet there for everyone's reference if they would like to see it to compare.
                  5V Rated voltage VDC,
                  3.75 Operate voltage,
                  0.5v release voltage,
                  100 ohm resistance +- 10%
                  250 mW Rated coil power.
                  I have read the coil resistance and rated coil power are different, but I don't know if it will cause any damage if I use a different value, because it is working nicely right now.
                    It is relay with 5V DC coil voltage, the coil has 100 Ohms reistance and consumes 250 mili-watt. To improve the reliability is to find the one that has the contacts that can handle high inrush current, that big transformer and the large filter caps will draw lots of current when the power is first applied.
                    • rhomanski
                      nowhere man
                      • 5157
                      • U S of A
                      The original relay is rated at 10 amps. Should be just fine. This place sells a similar one. http://www.onlinecomponents.com/te-c...tml?p=12114038 . I would try for an original replacement part. If the pins line up I would just use it.
                      It does have a slightly lower coil resistance which may cause the transistor that runs it to get hotter. Just monitor the temp for a while when you first install it. If you have to put a bigger transistor in.
                      • the loner
                        • Feb 2013
                        • 55
                        So if I understand correctly, this relay, SDT-S-105DMR,000 5VDC standard coil
                        (part #8-1419125-0) is fine, since the voltage is the same, it has less coil resistance
                        (46.3 ohms vs 100 ohms) , and it can handle more current (540 mW vs 250 mW)
                        • the loner
                          • Feb 2013
                          • 55
                          All 3 relay's are physically the same, as in pin layout and dimension, just the internals are different, as in current draw, and resistance.
                          I'm not sure what the coil type means on the last page of the pdf file stands for though.
                          • the loner
                            • Feb 2013
                            • 55
                            I did see that website, but I wasn't sure if the specifications were ok to use that relay.
                              "it has less coil resistance
                              (46.3 ohms vs 100 ohms) , and it can handle more current (540 mW vs 250 mW)" The lower coil resistance will cause more current draw by the transistor to be higher, that is why rhomanski suggested to check the temp of the transistor that drivea this relay coil, since the resistance is half the original, the current will be twice as much through the transistor which can cause the transistor to heat up, it not relay current handling specification, there is current handling spec for the relay contacts current spec, which is 10A.
                              Bottom line is that the sub relay consumes twice as much power as original, so if the transistor that drive this relay can handle it, then there will be no problem, if not, the transistor can be damaged.
                              • rhomanski
                                nowhere man
                                • 5157
                                • U S of A
                                This one http://www.mouser.com/ProductDetail/...p1G2fZFP9mw%3d is the best electrical fit but will not fit your holes. If you turn it upside down and run wires from it's contacts, what we call dead bugging, you shouldn't have to worry about anything else. Just glue it upside down somewhere on the board as close to the original spot as you can. I've used RTV in the past. The form a gasket for your car. It holds forever but won't dry out so it can be removed pretty easily. I have always made sure to keep it away from all contacts because I'm not sure if it is conductive. It could short something out if it isn't used properly. I don't think it would but I've never tried it, so I can't say for sure.
                                • rhomanski
                                  nowhere man
                                  • 5157
                                  • U S of A
                                  To explain a little better. Your relay is probably used to control the power to at least parts of the unit. This means you don't have full currant flowing through switches and such as that. Since the unit probably has a remote control, it will be run by a transistor. In the old units I work on the relays are to delay start up to control the currant draw in the first second it's turned on. Also they are used to protect the speakers, when the power supply voltages are all correct, the relay closes and connects the speakers. That keeps you from putting DC voltage on the speakers in a malfunction.
                                  The transistor supplies all the currant for the coil, it has to be large enough to to do it without overheating. If the coil draws 250 mW's then the transistor has to be able to put out more than that. Engineers almost always leave a little fudge room. If they run it close to it's maximum output they usually put a heat sink on it. This helps it dissipate the heat generated by that much currant flow. What I meant in my other post is that with less coil resistance, the relay might draw more currant and overheat the transistor. It can be replaced with a bigger transistor or it could be fitted with a heat sink. Another possible solution would be to mount a small resister in series with the coil to bring the resistance up to what the transistor is designed for. If the relay still actuated then no problem.
                                  One thing engineers discovered in the mid seventies when they started doing this, is that when the relay is deenergized, the collapsing magnetic field will induce a voltage in the opposite direction. This reverse voltage will ultimately break down the P N junction and kill the transistor. They began putting in diodes in the path so currant would flow normally but the reverse voltage would be stopped by the diode. The diode gets damaged just like the transistor would, but it has a larger P N junction and will last longer. I hope that clears up some things.
                                  It would probably be easiest to just dead bug the relay I pointed out. The other things I spoke of could work, but might not be easy or as reliable as you want.
                                    From the way it looks, that relay is used for supplying the 120V to the primary side of the large power transformer for the audio power amp section, picture #2 on post 1, this is very common setup for the receiver, that is why I suggested higher inrush current rating of the relay contact, the inrush current can be as high as 10 time the running current. Most relay company will post the inrush current rating of their relay. There are other relays for speakers protection as well.
                                    • the loner
                                      • Feb 2013
                                      • 55
                                      Sorry for not getting back sooner to everyone, it's been a busy week. Reinstalling windows 7, helping a friend move.
                                      I plan to order that relay this week and try the "dead bugging" you mentioned rhomanski.
                                      Not sure if there are any other Canadians in this posting (it doesn't look like it), but Digikey also has the relay that you mentioned rhomanski,
                                      http://www.digikey.ca/product-search...Q305&x=18&y=13
                                      I do appreciate the help everyone has given me though.
                                      There is way too much to learn but I can slowly learn from other members. I like to think about ways I can fix electronics and I don't expect to be spoon fed, but when I don't understand, or I don't feel safe, especially with high voltage transformers, I ask questions.
                                      baman, the receiver was purchased from an auction, so there is no warranty on it at all.
                                      • CyberPhoenix
                                        Issue with picture quality of Sony bravia TV
                                        by CyberPhoenix
                                        Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                        01-22-2024, 02:08 AM
                                      • noisykid
                                        Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                        by noisykid
                                        5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                        12-30-2024, 07:15 PM
                                      • tree5656
                                        diagnosing sony XBR-75X900H. NO PICTURE
                                        by tree5656
                                        This tv is not even 3 years old. its a sony XBR-75X900H, it was like a flashbang went off suddenly, tv faded to black and no picture. backlight is on. tried to do the power cycle, factory reset. i get beeps from remote if i tap up/down but no picture. how can i determine if its the panel or a board? i have replaced boards before im just not sure what the issue is here. sony said nothing they can do and only suggested to find a local repair shop. please guide me here
                                        11-09-2023, 04:55 PM
                                      • DKWS89
                                        Sony XBR 49x900E - Sound and backlight on but no picture
                                        by DKWS89
                                        Hey Guys,
                                        So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                                        All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                                        12-14-2023, 04:30 PM
                                      • Tr0ll
                                        by Tr0ll
                                        Original T-con:
                                        First replacement T-con:
                                        10-07-2023, 07:48 PM
