Hp Pavillion G6-1244sa won't turn on - Quanta R13 schematic
  • morphski
    • Mar 2013
    • 4
    • uk
    With power plug connected, it charges ok. When you hit the power button, the led on the button lights for 1 sec then goes off. Tried pulling ram, hard drive, dvd, wifi card. Also tried the reset, battery off, hold power button for 30 secs then power back up via the jack. Had motherboard out, all looks ok but still only getting led for 1 second, no beeps, no fan and no screen! Also tried it with processor removed, still the same.
    It's an i5 about 15months old.
    Lad at work said it made a buzzing noise, then he turned it off that night, and now shows above symptoms when trying to turn it on.
    Any help greatly received. P,s I don't have any schematics for this motherboard it's a DA0R13MB6E0
  • Francisco.s
    • 686
    • Spain
    Re: Hp Pavillion G6-1244sa won't turn on
    Here you have it.
    Take your dmm and post the results.
    • pajdek
      Lenovo Y700-17ISK turn on and off
      by pajdek
      Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
      09-20-2023, 02:49 AM
    • dfragx
      HP Pavillion 16 Quanta G3JC DAG3JCMBCE0
      by dfragx
      Friends, here is the boardview and schematic for G3JC DAG3JCMBCE0. Didnt find it anywhere besides buying it, Thank you for everything...
      09-04-2024, 08:02 AM
    • RdeveLabs
      MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
      by RdeveLabs
      To all the members here...
      Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
      So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
      05-05-2025, 04:59 AM
    • robante15
      Acer Aspire 4520 won't turn on after reboot
      by robante15
      Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
      It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
      The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
      If I remove the...
      04-06-2024, 06:50 PM
    • masoksian
      Dell latitude e7470 not turn on .power buton on off and Run Power problem
      by masoksian
      Hi everyone,
      I am dealing with the problem of turning on and off my Dell e7470 notebook.
      The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
      The system does not turn on, there is no post.
      I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
      The problem continues in the same way.
      I tried to turn on the Fn key, nothing came to the screen....
      02-15-2025, 12:08 PM
