LG 42PC1DA Plasma Sound but blank screen
  • LesWoollam
    • Nov 2012
    • 69
    • United Kingdom
    I have an LG 42PC1DA plasma TV with good sound but a completely blank screen (nothing at all even in a blacked-out room).
    The Y-sus heatsink is warmish but the Z-sus heatsink is cold.
    Voltage measurements are:
    Y-sus VS 180.5v VA 60.1v VSC 120.1v -VY 199.9v 5vdc 4.9v
    Z-sus VS 180.5v VA 60.1v Vzbias 100.2v
    Any ideas??
  • randtek
    • Oct 2011
    • 280
    • US
    Re: LG 42PC1DA Plasma Sound but blank screen
    Here's a trick that may help you. It will immediately tell you if you have a main board problem, or a panel drive board failure.
    1) Unplug the TV from AC.
    2) Disconnect the power supply cable going to the main board at the main board end.
    3)Disconnect the LVDS cable going from the main to the Digital board.
    5) On the digital board find 2 test point holes, probably labeled "Ext. Gen.". Short these 2 points together.
    6) Plug the unit in to AC.
    This process will generate test patterns from the digital board. If you see the test patterns begin to cycle on the screen, you know everything is working properly except your main board. If you do not see the test patterns, you have an issue in the panel drive circuitry.
    • LesWoollam
      • Nov 2012
      • 69
      • United Kingdom
      Thanks for the tip.
      Checked but no pattern on screen - still completely blank.
      Any suggestions?
        Check the fuses on the Y-sustain and Z-sustain boards.
        • LesWoollam
          • Nov 2012
          • 69
          • United Kingdom
          All fuses (including the 5v fuses) on both boards are good.
            We have sometimes seen the hybrids fail on these TVs without shorting out. Do you have 193V both ends of the fuses?
            Try without Z-sustain disconnected. You should get a dim, blurry picture if Y-sustain is still working.
            • LesWoollam
              • Nov 2012
              • 69
              • United Kingdom
              There's 186v5 at both ends of the fuses, I believe this is the VS supply from the smps. I've completely unplugged the Z-sus board but the screen remains completely blank.
                It is possible the Z-sus is failed in such a way that means the plasma panel is not lighting. Try with the ribbons disconnected from the plasma panel on the Z-sus side. Otherwise, the Y-sus may also have a problem.
                • LesWoollam
                  • Nov 2012
                  • 69
                  • United Kingdom
                  I've removed the ribbon cables from the Z-sus board - no difference, screen still blank. Are there any more tests I can do on the boards?
                    Unless you have access to an oscilloscope, unfortunately, no...
                    • LesWoollam
                      • Nov 2012
                      • 69
                      • United Kingdom
                      I have a dual trace 60mhz scope.
                        Brilliant... do you have a 10X probe which is capable of 400V measurements? (Peak voltage on Y-sustain can be 350V+)
                        • LesWoollam
                          • Nov 2012
                          • 69
                          • United Kingdom
                          Yes. What is the test?
                            Connect the probe to the Vscw test point, set your scope to 2ms/div, 10V/div, and see if you get any waveform (set trigger to auto for now.)
                            • LesWoollam
                              • Nov 2012
                              • 69
                              • United Kingdom
                              Is that the "Waveform" test point on the Y-Drive board on the far left of the TV?
                                That might be it. I might be getting confused with the older generation LG plasmas.
                                • LesWoollam
                                  • Nov 2012
                                  • 69
                                  • United Kingdom
                                  I'll scope it and post the results.
                                  • LesWoollam
                                    • Nov 2012
                                    • 69
                                    • United Kingdom
                                    Scope set to 10V/Div (probe x10) 0.2ms/Div.
                                    Scope trace attached.
                                      Y sus is working, that looks normal. Check Z sus too.
                                      • LesWoollam
                                        • Nov 2012
                                        • 69
                                        • United Kingdom
                                        Scope set to 5V/Div (probe x10) 0.2ms/Div.
                                        Z-sus scope trace attached.
                                        • mecha1166
                                          KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                                          by mecha1166
                                          KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                                          11-25-2024, 05:22 PM
                                        • mrtek
                                          Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                                          by mrtek
                                          Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                                          11-26-2024, 09:58 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • triplefour
                                          TCL 65S403 Blank Backlit Screen w/ sound ... voltage besides 12v missing at LVDS
                                          by triplefour
                                          Blank Backlit Screen w/ sound verified via DVD on HDMi 3
                                          no change to display when disconnect tcon
                                          no change to display when disconnect panel cables (both sides, one at a time, etc-)
                                          can faintly see a vertical dividing line splitting the panel even in half. super faint tho.
                                          also can faintly see a black cloud in the center of the screen. a darker area.
                                          color of screen is backlit black screen which basically looks gray
                                          12v present at TCON fuse
                                          other voltages on LVDS cable (TCON side) are missing. only see 2 pins with voltage .69v and .60v
                                          10-28-2021, 01:00 AM
                                        • Rozp
                                          70LE660U dark cloud or black screen with sound.
                                          by Rozp
                                          Hello Everyone,
                                          This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                                          I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                                          08-29-2023, 05:25 PM
