LG 50px5d and others Buffer boards. 6871qdh089a, 6871qdh088a
  • tw2005
    • Oct 2011
    • 6458
    LG 50px5d and others Buffer boards. 6871qdh089a, 6871qdh088a. I have a good pair but 2 of the locking tabs are broken, one missing, the other damaged.
    From what I can tell they are 40 way.
    Anyone been in this predicament and know how I could salvage the locking tabs from something else or get replacements?
    Can't seem to find any bad boards for sale either.
  • drpj23
    • May 2012
    • 528
    Re: LG 50px5d and others Buffer boards. 6871qdh089a, 6871qdh088a
    That sucks how simple stuff can cause the biggest issues...well i did find this list of TV's that may use that part....you can look around on ebay or shopjimmy for cheap parts
    HP PL5060N
    LG 50PC1DRA-UA
    LG 50PC3D-UC
    LG 50PC3D-UD
    LG 50PC3D-UE
    LG 50PM1M-UCLG 50PX1D
    LG 50PX1D-UC
    LG 50PX2DC-UD
    LG 50PX5D-UB
    LG 50PY2DR
    MAXENT MX-50X3
    MAXENT MX-50X5
    MAXENT P500150X3
    PELCO PMCP650
    PHILIPS BDH5021V/27
    POLAROID PLA-5048
    SONY FWD-50PX2
    SONY FWD-50PX3
    TOSHIBA 50HP16
    TOSHIBA 50HP66
    VIZIO P50HDM
    VIZIO P50HDTV10A
    VIZIO P50HDTV20A
    VIZIO VP50HDTV20A
    ZENITH Z50PG10-UA
    ZENITH Z50PX2D
    • tw2005
      • Oct 2011
      • 6458
      Thanks for the effort. Yes it is most annoying. i picked this up and managed to get another working using this ones ysus and zsus. Did not know about this until I powered it up to find the picture did not match what I saw when advertised. Not my doing and I'd say they broke the tabs and called it quits.
      The buffers are fine and it's the only thing is making me think twice about fixing it. It needs an IPM but to shell outfor the buffer makes it such a waste of a good board otherwise.
      I guess it's not normal for someone to sell a bad buffer, who would want one except in this situation.
      I think at one stage I had a bad board and tossed it because I thought it was silly hanging onto junk.
      Typical whenever you throw something you end up needing it.
      Have used SJ and pretty good service but with a minimum postage of $60 to Aust on top makes it silly to buy. They actually get the parts here within the week but I guess that's why it costs.
      • drpj23
        • May 2012
        • 528
        Occasionally you can find bad buffers on ebay, some people will by them to replace the ICs on them. Buuuut, you just have to keep your eye out and since they don't sell very often, market is scarce still.
        Did find a $20 one for the LG 50PC3D but I dont know how much shipping is.
          Maybe you could hold them down with tape or glue.
          • tw2005
            • Oct 2011
            • 6458
            I was hoping if anybody had some boards laying around it would be you. you seem to do a lot.
            Anyway , one is broken, the other is completely missing. Not sure if you're serious or not but really would not expect glue or tape to work. i don't think I could bring myself to even try it.
            I certainly could not do that and hold my hand on my heart and sell it.
              I keep very few parts, any TVs I cannot fix I usually sell at a loss to other TV techs.
              It is better than throwing it out to make a TV work again, as long as you make it a reversible repair and one which will last.
              • drpj23
                • May 2012
                • 528
                I think glue would work but if the buffers ever need replacing well ........ sucks for the next guy :P haha
                Of course I have seen one manufacturer heat seal (it seemed) the ribbon cables to the buffers.....they must have had a lot of confidence in their ICs or no damage from the Y-SUS
                • tw2005
                  • Oct 2011
                  • 6458
                  how would you be sure of getting positive pressure on the ribbon for good contact. The tab clamps it in place to make good contact.
                  • drpj23
                    • May 2012
                    • 528
                    Why not get a piece of plastic or popsicle stick to put over the ribbon cable in the connector then glue the two ends of the stick down? Theoretically that should like the connector did.
                    • tw2005
                      • Oct 2011
                      • 6458
                      Well I'll have a think but thanks for the input.
                      • tw2005
                        • Oct 2011
                        • 6458
                        Well you won't believe this but I managed to get 1 of the clips in and latch.
                        Out of desparation I could not help but think the missing one may have fallen off inside the set.
                        So I figured if so it would be in he chassis or maybe landed inside on the back cover.
                        So retraced my steps and looked around on the floor around the set because if it was on the cover it would have landed because at that stage I was unaware of the broken clip.
                        And there it was, must have walked over it a thosand times. How lucky but the clip is broken so to is the body.
                        I figured maybe it would still clamp on the ribbon and it did. Of course it will fall out as soon as it is unclamped.
                        Maybe that glue idea will work after all. I'm thinking maybe some strong silicone over it would work and this would allow it to be removed by someone down the track if needed. it will a nice surprise for someone.
                        Run the TV up and it has connected good enough, pictures good, no lines.
                        • cheebster
                          • May 2008
                          • 376
                          hehe. nice one.
                          what i've used in the past is, if you have some old flex cables around, there's always some blue rigid part that helps you slide the connector in ? well you cut a part of it of the good size, and slide it on the proper side (not the side with the contacts
                          This way it'll be harder to slide the flex in, and it's gonna make good contact.. adds pressure to the connection. used that a few times in laptops, always worked good !
                          • tc123
                            • Sep 2012
                            • 1
                            My tv just stopped working. It is an LG 50pc3d can you send the service manual. I got an error on your link.
                            • cheebster
                              • May 2008
                              • 376
                              there u go ;
                              you should post a new thread describing the issue if you want proper help !
                              • Blaujunk
                                • Aug 2013
                                • 1
                                Hi guys, have got both the 6871QDH088/089, with a total of 6 locking flaps still on it, boards are not working and mosfets have been removed to fix other boards. They are available for free if anybody pays postage.
                                • ajshoe
                                  ajshoe
                                  • Dec 2012
                                  • 477
                                  • usa
                                  Throw some info on this subject. If u have a broke tab - its not the end of the world. usually they break by the end snapping off. insert ribbon cable and then use (brown) tab manually. That is - insert broken tab on top of ribbon cable and then gently push down carefully. It does apply pressure but it applies it uniformly by the tab going under the board connector and applying pressure to the ribbon cable. After manually using broken tab - I usually put heat glue over top of connection. Has worked every time for me. Obviously if the tab breaks in half or in many pieces - you'll have to find another tab from a dead board. Or just buy another on EBAY.
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Good info.
                                    guess what, I worked that out in the end, it's funny what you discover out of desparation. I ended up running a bead of selleys all-clear to secure it.
                                    Worked a treat and glad to be rid of it. Did keep me occupied for a while.
                                    • splitcrete
                                      • Dec 2012
                                      • 387
                                      • usa
                                      Use some of that heat sink pad and cut it to size,and hold it down with 2 or three wide rubber bands. Has worked for me. Good Luck
                                      • cliff_hootarski
                                        • Jul 2006
                                        • 411
                                        Quick question, anybody have the two ribbon cables that connect the upper buffer board to the Ysus and between the two buffer boards?
                                        I've misplaced mine and I need them to finish repairs.
                                        How much, if you have them?
                                        Thanks.
                                        The buffer boards can be found in many model TV's:
                                        Hp
                                        PL5060N
                                        Lg
                                        50PY2DR 50PY2DR-UA AUSYLAD50PC1DR-UA SUSLLJR50PC1DRA-UA SUSLLJR50PC3D-UC 50PC3D-UD AUSLLHR50PC3D-UE AUSLLMR50PC3DH-UD AUSLLH50PM1M-UC SUSLLJR50PX1D-UC 50PX1D 50PX1DH-UC AUSYLAD50PX2D-UD 50PX2DC-UD SUSLLBR50PX4D-EB 50PX4DR-UA A850PX5D-UB SUSYLBR
                                        Maxent
                                        MX-50X3 MX-50X5 P500150X3
                                        Pelco
                                        PMCP650
                                        Philips
                                        BDH5021V/27
                                        Polaroid
                                        PLA-5048
                                        Sony
                                        FWD-50PX2 FWD-50PX3
                                        Toshiba
                                        50HP16 50HP66
                                        Vizio
                                        P50HDM P50HDTV10A P50HDTV20A VP50HDTV20A
                                        Zenith
                                        Z50PG10-UA Z50PX2D
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • Yanleb
                                          Schematic or datasheet for Plasma TV buffer chip
                                          by Yanleb
                                          I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
                                          So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
                                          Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
                                          05-18-2022, 01:36 PM
                                        • legg
                                          LG 42PC3 buffer output doesn't follow YSUS
                                          by legg
                                          LG42PC3D -UD originally with green lamp but no display or audio.
                                          Owner says was working, then went 'pop'.
                                          All 5V caps bulging. replaced.
                                          All PSU output voltages within spec but -Vy is low on YSUS.
                                          One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                                          eventually shorts DG. Replaced all 3 - -Vy now OK.
                                          Y scan buffer test point does not follow YSUS output below -50V
                                          Note: This unit seems to expect YSUS output to park at -Vy in between
                                          drive signal pattern periods. A replacement drive signal board confirms this....
                                          11-18-2021, 11:49 AM
                                        • howardc64
                                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                          by howardc64
                                          • Prior owner tried a replacement main board. No difference.
                                          • Samsung 2x red blinking standby LED = panel fault
                                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                          07-19-2025, 10:54 PM
