Philips 50PF7321D/37 Line in the screen
  • Mr Bill
    • Nov 2011
    • 648
    This tv was FREE!!!
    The guy said it had the 6 blink error code but for the moment it turns on. There are a few buldged caps under a heatsink which will probably be a big-ol-pain to replace but that can be another thread
    There is a faint green line on the right side of the screen one pixel wide. Does this look like a buffer starting on its way out or the panel is starting to show its age. It's not terribly noticable but i'm curious if it will get worse as time goes on.
    Re: Philips 50PF7321D/37 Line in the screen
    It's a panel failure, not repairable. Fairly common to have that with older TVs. But otherwise, looks in good order.
    Not a bad TV for free.
    • Mr Bill
      • Nov 2011
      • 648
      Do you think it'll get worse tom? I'm probably just gonna give it away since i have nothing invested in it other than a recap of the power board.
      Thanks for the input
        It's unlikely to get worse, just a defect in the driver IC which has developed due to heat/age/stress/manufacturing error. Unfortunately, the drivers are not replaceable (for some reason, I'm not sure why...)
        • Kiberge
          Samsung LH82QENELGC/EN Help needed - Static line on screen
          by Kiberge
          HI guys!
          I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
          I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
          the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
          This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
          04-22-2024, 11:28 AM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • almarhum
          To fix laptop screen vertical line by working on its EDP cable
          by almarhum
          Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
          As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
          05-07-2024, 02:12 PM
        • reformatt
          Macbook Air M2 A2681 Kernel panics after screen replacement
          by reformatt
          Just had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
          It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...
          07-31-2025, 08:37 PM
        • smic717394
          by smic717394
          07-25-2024, 10:16 AM
