My Epox 8RDA3+ mobo has always been a bit flaky, but these last few weeks it started behaving really badly. Random crashes, complete hangs, BSOD:s...
I suspected the problem was heat-related. Tried cleaning fans+heatsinks and applied new arctic silver, which got the CPU temp down from 50-ish to 40. The problems kept coming. When I opened the case and put a big table fan facing the mobo everything started to work fine.
Then I looked at what was happening in MBM5 and USBM without the table fan providing cooling. Hardly any difference at all in disk, system or cpu temps. The only parameter that changed was that "Core VDD" dropped rapidly from 1.7V to under 1.4V, and somewhere at about 1.3V the mobo crashed consistently (and I don't blame it, it's default voltage is 1.6). So what is causing the VDD voltage to drop to critically low levels when I haven't got a big fan flowing into the case?
Googled the issue and found this site. Could this problem be capacitor related? I see no physical irregularities on the Teaco's. Do motherboards with caps going bad get more temperature sensitive according to your experience?
If bad caps are causing this, is there anything I could do to squeeze another year out of the board? (I guess you'll tell me to change the Teaco caps but I'm not that big on soldering) I'll try to apply cooling to some of the mosfets as a temporary solution. Any other suggestions welcome!
(Hope I didn't bore you to death with my long post but then I suppose the easily bored don't read these forums to begin with!
/ David
/ David
