Measuring capacitance using multimeter
  • Rulycat
    • Apr 2010
    • 724
    • United Kingdom
    I was talking to my physics teacher about how to measure capacitance today, and he suggested i charge up a capacitor with a 10 volt battery (assuming 10V or more capacitor) and discharge it through a 10kohm resistor (think it was 10kohm). Time how long it takes to reach 3.7V and use this data to calculate the capacitance.
    Is this right?
  • PeteS in CA
    • Aug 2005
    • 3583
    • USA, Unsure of Planet
    Re: Measuring capacitance using multimeter
    It can be done that general way. It takes 1 time constant to discharge a capacitor to ~37% of its initial voltage. The formula for the time constant is T = (R)(C). So you would know the "R" term, and you would be measuring the "T". From that you can calculate "C". Do not forget, however, that your meter (or oscilloscope) is part of the circuit. You have to select "R" to be low enough for the "meter's" resistance to be irrelevant, but high enough to get an observable time. Using an oscilloscope will improve your observation (and a digital meter's refresh rate will mess up your time observation), and a 10X probe is commonly 10M-Ohms (a 1X probe is just 1M-Ohms, IIRC).
    PeteS in CA
    • Rulycat
      • Apr 2010
      • 724
      • United Kingdom
      Thanks for that PeteS. I have a £15 multimeter and not the cash for an oscilloscope. I have some cheap caps (470uf, 1000uf, 4700uf) that I'd like to test to see if they're near what they say they are as they are a fly-by night brand.
      • PeteS in CA
        • Aug 2005
        • 3583
        An analog volt meter might work almost as well as a scope, depending on how good of a measurement you want. Also, do you have access to equipment at your school?
        PeteS in CA
        • Rulycat
          • Apr 2010
          • 724
          • United Kingdom
          I only have a digital one, there is an oscilloscope at my school I could perhaps use in the Physics department, but if I can get a reading within 10% of the value I'm happy.
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16959
            I check mine with a Sencore LC102. To get an accurate capacitance reading, it MUST be checked out of circuit.....anymore, with my stash of caps, if I remove it I just replace it..... I will get curious every now and then on some I pull that APPEAR ok (mainly teapo and OST), just to see how far out of tolerance they are. Most the time, they're way out of spec.
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            http://folding.stanford.edu/
            Team : 49813
            Join in!!
            Team Stats
            • Rulycat
              • Apr 2010
              • 724
              • United Kingdom
              Cheers for that Topcat, I just need something crude now to give me a rough idea of the capacitance. I have some uses for these off-brand caps but I need to make sure the capacitance is about right.
              • Rulycat
                • Apr 2010
                • 724
                • United Kingdom
                Just charged up a 25V 1000uf cap and as it's connected to the multimeter the voltage gradually drops to 0 over 5 minutes or so. Is this normal, and will it affect my capacitance calculation?
                Got some resistors today from Maplin as well. 0.25W, assorted sizes from 10R to 1M0.
                Should I use a 10K or a 1K? Or neither?
                • popeye
                  • May 2011
                  • 155
                  Is this right?
                  your teacher is as suggested one way to get a rough idea as a city and guilds engineer I would sagest as you seem to very keen go online to your local library and type in electronics you will find a lot of books that will take you through the basics one of those basics is about capacitors you can learn the formula's and the correct way to measure capacitance you may even find a circuit for an lcr bridge you can build that is an old way of checking caps inductors and resisters that is very accurate you may even have one in your physics department. You can find a lot of information on the web for free I know what it is like when funds are tight but if you persevere you can end up repairing items for a profit and then your hobby will self fund its self.
                  I will try to find some of the text books in pdf form and will attempt to upload them to badcaps for you
                  popeye city and guilds engineer.
                  • Rulycat
                    • Apr 2010
                    • 724
                    • United Kingdom
                    Thanks popeye, my teacher has given me an old 80's book on electronics, as my school no longer offers the course so he let me have it. It has the equations for capacitance and so on and some stuff on other things like transistors and specially computers, such as 4 bit multipliers etc. But for capacitors it is too vague without mention of ESR and so on. Thanks for the offers to upload the PDFs and I will read them when I get back from work. (checkout job - not too fun!)
                    We've a branch library a few miles away, I can have a gander at what's on the shelves there. My objective at some point in the future is to be able to repair PSUs to a competent level as well as design my own circuits because I find often I have the parts from dead ones but not the knowledge to use them to assemble my own. It should save me money if I can repair things like this, and perhaps make some on the side as an income source when I go to university in a few years.
                    • PeteS in CA
                      • Aug 2005
                      • 3583
                      Approximating a bit, your cap will be effectively discharged in 5 time constants. So the effective time constant you observed is 60 seconds. Using T = (R)(C), if your cap is truly 1000uF, your effective meter resistance is ~60K ohms. That seems really low, less than 3K ohms/volt if the cap was charged to 25V! With a meter resistance of 60K, a 1K resistor should be used to swamp out the meter resistance. The problem with that is that the time constant of a 1000uF cap and a 1K resistor is 1uS, which you won't be able to observe using a meter.
                      I'm not using my 1970s-vintage steam-powered calculator, so check my very mental Math.
                      A 10M-ohm 'scope probe would let you use a resistor in the 100K-1M range. And the 'scope would then introduce you to a phenomenon known as "switch bounce".
                      If things like meter and 'scope probe impedance seem arcane and less than practical, consider a trouble-prone circuit in the systems I work with every day. It's a ~2 minute timer that uses a .47uF cap being charged through a 60M-ohm resistor (I think those are the values). The cap is a (evil) large form-factor SMT monolythic ceramic capacitor, which are susceptible to cracking. Also, any conductive residue around either part will screw up the operation of the circuit. So, if I try to observe the charging of the cap, my 'scope probe forms a 60M-ohm -- 10M-ohm series circuit, with the 10M-ohm being across the cap. Because of my 'scope probe the 2-minute timer cannot work and I cannot tell whether the cap is leaky ... Gotcha!
                      PeteS in CA
                      • Rulycat
                        • Apr 2010
                        • 724
                        • United Kingdom
                        Going to Maplin again to get some more parts tomorrow, most notably a proper switch and some electrical wire (currently using wire savaged from an ATX PSU) so does anyone have advice on what other stuff to get to fill out my parts bin?
                        For the Americans Maplin is like the U.K's version of Radio Shack. (but better)
                        http://www.maplin.co.uk/
                        • jamesbo
                          • Aug 2011
                          • 36
                          I've been to Maplin, it's a lot better.
                          • lipyphil
                            • Mar 2012
                            • 26
                            Omg..I have now understood time constant reading this post. I have struggled with this concept for a while. Is it also right to say that the time constant measures time it takes to charge a capacitor to about 67% of its maximum charge? Folks am new to electronics and trying to understand capacitors,inductors and resistors.
                            • rcanpolat
                              M1 MacBook Pro 2021 A2485 - No backlight display
                              by rcanpolat
                              I recently got my hands on an M1 MacBook Pro (2021, A2485) that I suspect suffered some liquid damage. I have a hot air station and the basic tools to work on the board, but I’m new to SMD repair and would love some guidance before diving in.
                              Here’s what I’ve observed so far:
                              • When I power it on, I hear the MacBook chime and, with a flashlight, I can see the Apple logo on the screen. However, it never completes the boot and eventually powers off. My plan is to try to get the display fully working first, then tackle the boot issue.
                              • I did some basic resistor
                              08-24-2025, 02:16 PM
                            • dj8452000
                              How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                              by dj8452000
                              I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                              02-18-2025, 08:28 AM
                            • trex66
                              Craftsman 82345 Multimeter broke!
                              by trex66
                              My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
                              03-04-2025, 04:26 PM
                            • Flux_Cap
                              Help for Newbie on measuring capacitance
                              by Flux_Cap
                              I need help with measuring capacitance on vintage paper in oil, paper in wax, or Mylar film capacitors. I am using these vintage capacitors on my guitars. There are many sellers on eBay that offer these. Guitars generally have a very low operational voltage values; we are talking millivolts at most over a frequency range which is probably the same as the frequency range for the human ear. Most of the eBay sellers that I get my capacitors from are using different types of meters then I use; such as the PEAK ESR 70 or some cheap capacitance or transistor meter they got on Amazon. These old capacitors...
                              08-22-2018, 07:38 PM
                            • Junkrepair
                              Calculating ESR from tan delta -- tan delta's dependence on capacitance
                              by Junkrepair
                              I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
                              I found this nice little description of the conversion:
                              Calculating capacitor ESR from Tan(delta)
                              https://forum.digikey.com/t/calculat...-from-tan/2633
                              It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
                              06-12-2023, 02:45 PM
