Help for Newbie on measuring capacitance
  • Flux_Cap
    • Aug 2018
    • 9
    I need help with measuring capacitance on vintage paper in oil, paper in wax, or Mylar film capacitors. I am using these vintage capacitors on my guitars. There are many sellers on eBay that offer these. Guitars generally have a very low operational voltage values; we are talking millivolts at most over a frequency range which is probably the same as the frequency range for the human ear. Most of the eBay sellers that I get my capacitors from are using different types of meters then I use; such as the PEAK ESR 70 or some cheap capacitance or transistor meter they got on Amazon. These old capacitors usually drift up in capacitance with age. I recently ordered a couple .02 microfarad Sprague black beauties that the seller claims read at .025 on his 30$ capacitance meter. When I got them, they read .033 microfarads on my Fluke 115 True RMS mm on capacitance setting. I have checked other known good brand new caps with my Fluke and the measurements are spot on. So I am hoping someone can explain why there is a difference and which meter I should believe and how to avoid this problem in the future. Thanks in advance for any help clarifying this.
    • 31170
    Re: Help for Newbie on measuring capacitance
    capacitance mat vary with frequency of the tester slightly.
    you should be more concerned with ESR and leakage if your using them as signal filters.
    • Flux_Cap
      • Aug 2018
      • 9
      I thought leakage was only an issue at higher voltages. I don't see how leakage would be a problem. I really don't have a good understanding of ESR.
        • 31170
        leakage is a problem if your trying to block dc from an amplifier.
        esr is resistance at a specific frequency.
        in audio filters lower esr = more signal getting through, often with a wider frequency range.
        (better bass/top-end)
        • Flux_Cap
          • Aug 2018
          • 9
          ESR sounds like capacitive reactance Xc that I remember from my Navy electronics training. I have read many books on electric guitars and have never seen the term ESR when capacitor values are discussed. These ESR meters give the value of capacitance in farads not ohms. I would think that measuring a capacitor at a specific frequency would not be an effective way to test a capacitor that operates over a wide frequency range. Well, I appreciate your taking the time to respond. This does not seem.like an enticing topic for the rest of the forum. I'm not going to give until I understand this better. Perhaps I did not post this in the right forum topic.
          • Flux_Cap
            • Aug 2018
            • 9
            In my last post I meant to say that some ESR meters read capacitance in farads and some give a reading in ohms.
              • 31170
              good ones give all 3 values.
              pics later.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8302
                good LCR meters aren't cheap either... on the other hand... what is cheap these days?
                  • 31170
                  component testers are 5-15 and work well, 99% of the magic is the software.
                  • Radio Fox
                    • Jan 2010
                    • 281
                    All ESR meters give a reading in Ohms (Equivalent Series Resistance). Some also give a capacitance reading.
                    ________________________________________________
                    Invisible airwaves crackle with life
                    Bright antennae bristle with the energy
                    • redwire
                      • Dec 2010
                      • 3912
                      A leaky capacitor can fool some capacitance meters because it takes longer to charge up due to current loss in the dielectric.
                      So a leaky cap can read higher in capacitance on some equipment. Some days I get a different reading from every meter I own which drives me nuts.
                      Many capacitance meters are single-slope and only measure charge time to ramp up and calculate a value.
                      What you will find with old paper/wax caps is some leakage current supposedly due to the paper absorbing moisture.
                      ESR is not a useful measurement for low value film capacitors. These capacitors are too small in value and circuit impedances too high for it to matter. ESR is very important for wet capacitors, such as electrolytic capacitors.
                      Best to use a good DMM and check the dielectric insulation resistance through the megohms.
                      A perfect capacitor has no leakage current, but some is perfectly fine in a guitar as it is AC signal and would just soften the tone.
                      • Flux_Cap
                        • Aug 2018
                        • 9
                        I think most of the ESR meters I've seen only test down to 0.1 microfarad. What is the best meter to use for these old and small (.015 to .047 )caps?
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          Flux_Cap, do you mean old caps like these?
                          https://www.patreon.com/posts/20834648
                          If so the component tester that stj recommended above is what I've used to measure those.
                          But also like redwire says it's likely that leaky caps can fool an ESR meter.
                          The little transistor tester is pretty smart though: it tests for leakage too!
                          If you look at the hand written text, within parenthesis that is what the meter read them as.
                          A value with a percentage is how leaky it was.
                          So for example the first cap, 100nF read as 330nF with 8% leakage and ESR of 3.3.
                          If you want I can test it with some DMM's too, and see what they say.
                          But all in all I have to question why not just replace these old crap capacitors?
                          • Flux_Cap
                            • Aug 2018
                            • 9
                            Yes, these are similar to the caps Im interested in. I need to talk to Mr. Carlson too, thanks for posting that link. In the late 50's to early 60's, Gibson guitars used black beauty's, bumble bees and some paper and wax type caps, usually .02 microfarad. Guitar aficionados, luthiers building replicas, and hobbyists, like to try to use the same components used back in the 50's in order to chase that vintage tone. I totally agree with you. If you are restoring an old radio or amp or some other than a guitar, these old caps should be the first to go. For a guitar which sees only millivolts at most, Im not sure leakage would be a concern. A guitar tone circuit is just a frequency filter. The value of the cap changes the response curve which affects the tone. It would be nice to see how your DMM compared to that transistor tester though. I think Im going to have to buy anbokd vintage tester to test these old caps, I' don't know.
                            • Flux_Cap
                              • Aug 2018
                              • 9
                              Did I miss something? What tester did he recommend?
                              Thank you Redwire. I have been going nuts myself trying to buy these from sellers on eBay only to find out that they read way different on my Fluke 115. I've head to return several because they didn't read what the seller for using his meter. I'm not making friends on eBay this way!
                              • Per Hansson
                                • Jul 2005
                                • 5895
                                • Sweden
                                The tester exists in a thousand variants.
                                If you want a recent one you should buy this one I link to here:
                                https://www.eevblog.com/forum/testge...31/#msg1730831
                                But the older meter exists in a cased variant, also shown there (which I also have, and like).
                                The first one I bought, it's this one (not recommending you buy it now, better variants exists today): https://www.ebay.com/itm/2016-EZM328...a/201663141755
                                This I'm sorry is called audiophoolery!
                                You seriously can't think that a 70 year old capacitor sounds the same today, with how much it has degraded, compared to how it sounded when it was new?
                                  • 31170
                                  the new software can read fractions of a Picofarad afaik.
                                  • redwire
                                    • Dec 2010
                                    • 3912
                                    I say be careful with Mr. Carlson and his capacitor leakage tester and his reasoning. Some of it is incorrect, from my point of view.
                                    He seems to be confusing wet capacitor increased leakage current with that of failing film capacitors.
                                    A few uA of leakage current at low test voltages and he says the film cap is bad.
                                    Vintage capacitors have different dielectric absorption and ESL that seems to be the Holy Grail for old gear. Modern dielectric plastics in film caps are different (RoHs, SMT temperatures etc.) and do sound different depending on the circuit. Guitars are high-impedance so DA has a stronger effect.
                                    • Per Hansson
                                      • Jul 2005
                                      • 5895
                                      • Sweden
                                      Thanks for asking me to do this test: it was quite revealing:
                                      My UNI-T UT61E reported pretty much spot on for all caps vs the "transistor tester"
                                      With exception for the caps that the transistor tester showed a leakage percentage on:
                                      Those it could not test properly: it would flash a value, then go back to zero, and flash a value, like it was getting overloaded (probably exactly what happens)
                                      When tested on my useless Fluke 113 the resolution is only 1nF, so it can't show pF values.
                                      It's behavior was different though: the first capacitor in my previous example that the transistor tester read as 330nF with 8% leakage and ESR of 3.3:
                                      The Fluke 113 read that as 500nF, so it confirms the point made by others: cheap meters are fooled by leaky caps: they read them too high.
                                      Well, maybe not cheap meters then, since I paid a grand total of $15 for my transistor tester kit back in 2016
                                      Agreed to some extent, but realize that he has allot of traditional high voltage capacitor leakage testers that he has compared it with.
                                      But yes sure, some faults are bound to only be found with proper high voltage.
                                      Indeed, it can go really really low.
                                      It's discussed a bit here how to do it:
                                      http://www.eevblog.com/forum/testgea...92/#msg1753292
                                      • Radio Fox
                                        • Jan 2010
                                        • 281
                                        ...the first capacitor in my previous example that the transistor tester read as 330nF with 8% leakage and ESR of 3.3:
                                        The Fluke 113 read that as 500nF, so it confirms the point made by others: cheap meters are fooled by leaky caps: they read them too high...
                                        ...and an expensive Fluke meter reads them even higher.
                                        • SolomonMan
                                          Vintage BK Precision 1403 Oscilloscope....
                                          by SolomonMan
                                          All,
                                          Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
                                          Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
                                          I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor...
                                          12-03-2023, 10:39 PM
                                        • Junkrepair
                                          Calculating ESR from tan delta -- tan delta's dependence on capacitance
                                          by Junkrepair
                                          I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
                                          I found this nice little description of the conversion:
                                          Calculating capacitor ESR from Tan(delta)
                                          https://forum.digikey.com/t/calculat...-from-tan/2633
                                          It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
                                          06-12-2023, 02:45 PM
                                        • DrDos
                                          Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
                                          by DrDos
                                          Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
                                          08-08-2025, 03:16 AM
                                        • Sparklingx
                                          SMD ceramic capacitor capacitance & voltage
                                          by Sparklingx
                                          what is the easiest way to measure the capacitance of SMD ceramic capacitors and its rated voltage?...
                                          09-12-2024, 01:04 AM
                                        • rcanpolat
                                          M1 MacBook Pro 2021 A2485 - No backlight display
                                          by rcanpolat
                                          I recently got my hands on an M1 MacBook Pro (2021, A2485) that I suspect suffered some liquid damage. I have a hot air station and the basic tools to work on the board, but I’m new to SMD repair and would love some guidance before diving in.
                                          Here’s what I’ve observed so far:
                                          • When I power it on, I hear the MacBook chime and, with a flashlight, I can see the Apple logo on the screen. However, it never completes the boot and eventually powers off. My plan is to try to get the display fully working first, then tackle the boot issue.
                                          • I did some basic resistor
                                          08-24-2025, 02:16 PM
