crackling and fart noise coming from speakers!
  • newtoCaps101
    • Jul 2011
    • 93
    long time guys, remember few months ago the speaker set I fixed up with your help, the one that had the big bad cap in the power brick?(https://www.badcaps.net/forum/showthread.php?t=16013)
    Well they have been working fine until today, it has started to make these low crackle and fart noises coming from the speakers. first it was the rear speakers but now I notice its all of them. I switched them around but didnt help. I think its the decoder / amp, because I removed the speaker front and rear inputs and it still makes that crackle and small fart noises! Sometimes there is also a small buzz / loud boop noise I hear around every 30mins or so. the kind of noise you hear after first turning the unit on.
    what should I do?
  • bluto
    • Oct 2007
    • 560
    Re: crackling and fart noise coming from speakers!
    Is your cell phone sitting near the speakers when this happens?
    • newtoCaps101
      • Jul 2011
      • 93
      No, my cell phone and stuff is in the other room and usually sits turned off unless I am going out!
      So I opened up the AMP / Decoder last night and kept it turned on and it hasn't made any crackle and fart sounds? the whole thing is plastic with no shielding so if anything there should be more crackle. I dont get it
      • newtoCaps101
        • Jul 2011
        • 93
        I applied some fresh solider and re-soldered most of the pcb joints before putting this thing together, it was running and playing music great up to 30% ~ 50% volume levels for hours, a brief while ago I cranked up the volume to say approx 60% - 80% blasting some rock and roll for a few mins(just to test things out) and the crackling sound is back!
        I have noticed that it gets higher as I increase the volume.
        I need some help with this guys, need it real bad.
        • b700029
          Banned
          • Sep 2010
          • 640
          Check the power supply decoupling caps.
          • bluto
            • Oct 2007
            • 560
            Check all the smaller caps too for that matter. You might even be able to identify the bad one by spraying it with freeze spray.
            • newtoCaps101
              • Jul 2011
              • 93
              I have checked all the caps in the amp and the everything looked fine. I did change a cap few months ago in the brick power supply. I will look into it again and get back to you guys.
              The power brick is 15V 3A so I am guessing thats around 45W. So maybe replace it with a laptop power supply? I found some with the same 15 volts and 3 amps.
              where is the unique one, he and a couple other guys helped me a lot last time, basically walked me through it
              • newtoCaps101
                • Jul 2011
                • 93
                Please guys I need some help
                • ay633
                  • May 2012
                  • 1
                  Are you in the states? I have a DTT2500 that lost its digital inputs. The amp part of the control box works fine. Do you think you'd be interested in sending me the input board from your control box (for $$ of course)? Or would you like my box and power adapter?
                  -Tom
                  • redrooster
                    • May 2011
                    • 114
                    Turn it off and spray the volume pot on the amp with contact cleaner and turn it back and forwards about 20 times.Do this twice and it should come right in fact do all your potentiometers at the same time.The mineral oil will collect dust and crap and only work for a while.So flush it all out.
                    HP P6-2203a desktop,AMD CPU A8-5500 with Radeon HD7560D,3.20Ghz. Radeon HD 6670.8Gb Ram.2TB HDD. WIN 10 64 bit O/S.
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      Sounds like crossover distortion. Maybe a bad cap near one of the amp chips.
                      Muh-soggy-knee
                      • MegaZAC
                        Onkyo TX-SR805 noise in one channel
                        by MegaZAC
                        Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                        Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                        There's some logic behind it. As soon as I select an input I get only left...
                        04-23-2025, 10:09 PM
                      • courtcircuit
                        Philips HTS8000 home cinema noise problem
                        by courtcircuit
                        Hello
                        I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                        Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                        Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                        I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                        Removed each of tyhe boards
                        02-08-2025, 08:22 AM
                      • Asxetos21
                        Dell Latitude 5511 audible electrical noise
                        by Asxetos21
                        I have a Dell Latitude 5511 laptop, and lately, a faint but clearly audible electrical (crackling) noise comes from the motherboard, similar to the random clicking coming from a mechanical hdd's heads moving inside it.
                        The laptop shows no signs of malfunction, and clearly this is electrical not mechanical, so my suspicion goes to a dodgy component in the power rails (a capacitor or a coil?). I fear this could develop into a serious damage.
                        Any advise on how to narrow it down?
                        The schematic is available here:
                        Dell Latitude 5510 5511 - Precision 3551 FDV50 FDV51 LA-J282P...
                        03-03-2025, 09:53 AM
                      • karatzdi
                        Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                        by karatzdi
                        I know some might say... just buy another one. Sell it as parts..!
                        So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                        Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                        Spent some time downloading the Service...
                        06-11-2024, 08:38 AM
                      • tony359
                        by tony359
                        11-28-2023, 05:18 AM
