Acer X241W (Power Board Failure)
  • stevekasian
    Old N00b
    • Dec 2010
    • 182
    • USA - West Side!
    I have an Acer X241W with a backlight failing to come on.
    Display works - I can see the OSD Menu when holding a flashlight to the screen, and it is responsive to menu/button controls.
    Upon opening up the unit, I could tell it has been worked on. Replacement low ESR caps have been installed on both the power and logic boards, and the work looks good.
    I pulled the inverter board and checked the transformers. They all appear to be in working order. No burns or heat marks visible and each measures the same resistance across each lead in each respective combination.
    So I decided to power up the power board (Model AS08B360411) and take some readings from the 5v/12v/19v rail that powers the inverter. When switching the unit on and measuring voltages before the standby mode engages, this is what I came up with (see attached images and annotation on image #3).
    There does appear to be heat discoloration on the front and back of the section of the board I'm dealing with, although I believe it is probably from an earlier failure, as no components appear to be damaged/burned.
    Anyone care to help me troubleshoot this board?
    Thanks,
    SK
    p.s. Entry #17 on the following page reports almost the same readings on the pins of a similar monitor: https://www.badcaps.net/forum/showth...ighlight=x241w
  • stevekasian
    Old N00b
    • Dec 2010
    • 182
    • USA - West Side!
    Re: Acer X241W (Power Board Failure)
    Ok, as a follow up, I have checked the 12v rectifier in circuit and found it to be conducting equally in all directions from P-N/N-P. I'm gonna remove it from the circuit tomorrow and check it again, but I believe that's a bad sign, especially considering it's the 12v pin on the rail that is registering no voltage.
    I believe I should also order the caps circled in PlainBills annotated image in the other thread, as they are apparently the only ones that look to be original equipment on this board. I will give an update here tomorrow... Time for sleeeeeep.
    SK
    • dondrusco
      • Apr 2009
      • 89
      Try to start with this post in another thread - AL2423W has the same power board
      https://www.badcaps.net/forum/showpo...9&postcount=23
      • stevekasian
        Old N00b
        • Dec 2010
        • 182
        • USA - West Side!
        The 12v rectifier checks ok out of circuit.
        I did notice that 2 of the largest caps in the images above (19v section) were most likely replaced by a previous tech and are slightly too tall. As a result, the head skink "cap" that goes across all 3 sections put a lot of pressure on them when screwed into place, and it appears that one may have crumpled a bit under the stress. So I've ordered replacements for all the remaining OEM caps, as referenced in a previous post, plus all 3 of the largest caps (680uf@25V) in a shorter/smaller can.
        So it looks like the middle of next week I should know whether or not this did the trick!
        SK
        • stevekasian
          Old N00b
          • Dec 2010
          • 182
          • USA - West Side!
          Ok, I changed out all the caps listed previously and still no dice. Anybody?
          Thanks,
          SK
          • alexanna
            • Mar 2010
            • 1346
            What voltages do you see on CNS1?And is FS3 a fuse and dose it test good?
            • stevekasian
              Old N00b
              • Dec 2010
              • 182
              • USA - West Side!
              CNS1 is not an issue, as the only problem is the backlight not coming on.
              The voltages on CNS2, however, are. Please see photo #3 (annotated) for voltage readings there.
              All fuses are good.
              Thanks,
              SK
              • jetadm123
                • 2169
                Have you tried checking the fuses on the inverter board?
                • stevekasian
                  Old N00b
                  • Dec 2010
                  • 182
                  • USA - West Side!
                  Yes. All fuses are good. All transformers read the same (chances are slim all 12 went out simultaneously).
                  As for voltages on the 19v rail being a problem, I could be mistaken but I don't understand what 5v would be doing on this rail. ?
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Because, Doofus, that is the connector to the inverter. It carries ground, the 19V inverter supply and the inverter control lines - On/Off and Brightness.
                    Those voltages may indicate a problem with the signal card, or with the inverter.
                    PlainBill
                    • stevekasian
                      Old N00b
                      • Dec 2010
                      • 182
                      • USA - West Side!
                      I know it's the connector to the inverter! :-p But everyone always says that the inverter only gets 12V or more. So the control lines are on the 5v lead?
                      And what is the "signal card"?
                      SK
                      • PlainBill
                        • Feb 2009
                        • 7034
                        SK
                        1. The inverter POWER is often 12V, 18V, or 24V. The CONTROL signals are usually much lower 0-3.3V for Off/On and 1-3V for brightness.
                        2. The control lines come from the signal card. Don't confuse the power carried on a connector with the control signals on a connector. At least one manufacturer (Samsung?) feeds 15 volts to the signal card on one model.
                        3. The signal card is also called the video card, control card, or logic card. I prefer 'signal card' because most people will not confuse it with the video card in the computer, the power supply, or the panel card.
                        PlainBill
                        • stevekasian
                          Old N00b
                          • Dec 2010
                          • 182
                          • USA - West Side!
                          Thanks for the info.
                          So how would you proceed with this at this point if this was your project?
                          • PlainBill
                            • Feb 2009
                            • 7034
                            I'd put it on the shelf until I had the urge to work on it. Then I'd play 'Angry Birds' or help someone on the Badcaps forum until the urge went away.
                            OK, I'll try to offer some real help. First, the service manual is at Elektrotanya. That may help.
                            1. The manufacturer REALLY isn't helping; the pins on the power supply aren't labeled, which is unusual. I haven't seen pictures of the signal card, but they usually don't label the connector pins. The best hope is the inverter. That MIGHT give a clue.
                            2. As I mentioned, the two signal (control) lines are at unusual voltages. There are a number of reasons for this. Were the readings taken while the monitor was connected to a working computer? If not, that would explain the strange readings.
                            3. The fact that the backlights never come on, but the monitor does display a desktop leads me to suspect the inverter, in particular the fuses.
                            4. A simple test is to monitor the voltages on the two control pins in question while pressing the power button slowly. If the voltages change on every other button press, the problem MUST be in the inverter or possibly the backlights.
                            5. I took a look at the service manual, and surprisingly they had a schematic of the inverter. Pin 1 is On/Off, 2 is brightness, and there is a single fuse.
                            PlainBill
                            • alexanna
                              • Mar 2010
                              • 1346
                              This may have been answered already but are we sure the controll lines for the back light are not on CNS1.I can make out 12V-ground-5V-Ground -On Off -Something? And what looks like ADJ.
                              • PlainBill
                                • Feb 2009
                                • 7034
                                They are. If you look at the picture of the back of the power supply two lines run from CNS1 to CNS2. This is a typical arrangement - the two signals originate on the signal card, pass through the power supply and go to the inverter.
                                The schematics in the Service Manual are pretty cheezy, but the one of the inverter is clear enough. OK, pin 1 is On/Off, and should be at 5V to turn the inverter on. Pin 2 is the brightness.
                                PlainBill
                                • stevekasian
                                  Old N00b
                                  • Dec 2010
                                  • 182
                                  • USA - West Side!
                                  > 2. I did not take the readings while a video source was connected. However, i did take the readings as i turned the monitor on and waited for it to go into standby mode. I got the 5V reading every time the display was supposed to be active (not in standby). So I guess that would be equivalent to "every other button press".
                                  > 3. I checked the 2 fuses (yes, there are actually 2) on the inverter and they are not burned.
                                  There is a single fuse on the PS board right at CN2 - perhaps that is what you are seeing on the schematic?
                                  I found the service manual the other day, but unfortunately they really dropped the ball on the Power Board section... lol
                                  • PlainBill
                                    • Feb 2009
                                    • 7034
                                    Excellent - I was thinking that the readings were taken with the monitor in a standby state. That turns out not to be the case.
                                    No, the first page of the inverter schematic clearly showed a single fuse at the power input. However, when examining the second page of the inverter schematic, they show a second fuse. And when I reexamined the first page, I find a third fuse. Just to be cute, they seem to be numbered F1, F2, and F101. I would expect F1 to be a smaller (physical and current rating) fuse than F101 and F2.
                                    IF you locate all three fuses and they are intact, there are a few additional points to measure on the inverter. Transistors Q2, Q1, and Q3 handle level shifting of the On / Off signal. I suggest setting your DMM on the 20 volt range and measuring the voltage on the three pins of those transistors as you press the power button on and off. I would expect voltage changes on all pins of Q1 and Q3, and 2 of the three pins of Q2.
                                    That is a polite way of describing the utter lack of a schematic for the power supply.
                                    PlainBill
                                    • stevekasian
                                      Old N00b
                                      • Dec 2010
                                      • 182
                                      • USA - West Side!
                                      Well, it would've helped matters if I'd posted picts of the inverter board to begin with ;-) (see attached)
                                      F1 is not in use on this board revision. (I swear I didn't cut it off - really)
                                      (And apparently the explanation for the cute numbering job is that everything in the area of F101 is in the 100s.)
                                      Thanks! I'll report back with results...
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        There IS a reason I ask for pictures.
                                        It appears someone has been working on the inverter with a pair of cutters. In addition to F1, I see three missing electrolytics. If you look at the assembly instructions in the service manual the three fuses and the caps are visible.
                                        PlainBill
                                        • howardc64
                                          by howardc64
                                          Today, 05:17 PM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • Roman555
                                          [Offer] Acer IPIMB-AR (w/o on-board gfx) of Acer Predator G5920 fullflash BIOS
                                          by Roman555
                                          I'd like to offer an Acer IPIMB-AR Rev: 1.02A fullflash BIOS (cleaned ME region). The model is for Acer Predator G5920.
                                          It is a model that is based on Intel Z77 PCH and doesn't have on-board graphics and video connectors.
                                          I suppose it doesn't have any restriction about discrete graphics cards (I mean they don't have to be in a whitelist).
                                          Please don't mistake this mainboard with a similar model with on-board graphics and based on Intel B75 PCH.
                                          Jumper FLASH_OVERRIDE
                                          default position: 1-2 - BIOS area protected
                                          position 2-3 allows to dump BIOS or write
                                          06-26-2025, 05:15 AM
                                        • delpiero3
                                          Sony Vaio SVS MBX-261 board failure
                                          by delpiero3
                                          Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
                                          Nevertheless, let's say, i don't come as a total beginner.
                                          I have this old laptop, which suit perfectly my needs, with the...
                                          10-29-2024, 06:16 AM
