32" Goodmans TV
    32" Goodmans TV
    I got this TV for cheap.
    Model Goodmans LD3262D.
    Symptoms are it is stuck in standby. Sometimes it will switch on and work for a few hours.
    I took it apart and none of the caps look visibly bad.
    Problem is there are like 20 different values of cap in it, so I have to order a lot of caps and replace them to get it working.
    The caps are cheap: Chong, Aishi, Teapo, G-Luxon and Samxon (good?) From the number of them and the inconsistency it looks like they picked whatever caps they could get the cheapest or quickest.
    I don't have an ESR tester, only a multimeter with basic cap range. I *do* have an oscilloscope to probe power supply lines so I can check for ripple.
    • Jul 2011
    • 6070
    Re: 32" Goodmans TV
    Here is what I would if the monitor is more than two years old I would replace
    ALL the caps on the inverter/power board
    I just repair a monitor that was made in 2004 and I replaced ALL the caps on the Power board and works great now
    ALL the caps read 10% or more under what the caps had print on them so you be the judge and jury on whether or not to change all the caps on the Power board
    • jsog
      • Feb 2011
      • 220
      Re: 32" Goodmans TV
      With a signal generator, you can test ESR with the oscilloscope. Not as convenient as a dedicated ESR meter, but better than none at all.
      http://www.repairfaq.org/sam/captest.htm#ctsim
      http://www.electronics-diy.com/elect...tic.php?id=948
      http://emcesd.com/tt020100.htm
      Some of those circuits aren't much less complicated than a full analog ESR meter. http://members.shaw.ca/swstuff/esrmeter.html works. If you have a reasonably good stock of junk, you might have all the parts already.
      Edit: page with a bunch of ESR meters in all styles:
      http://kripton2035.free.fr/esr-repository.html
        Re: 32" Goodmans TV
        A signal generator is on my wishlist, but I don't have one yet.
        I probably will do this. What is the best source for various values of caps? Farnell wants me to order minimum 5; Mouser wants £12 shipping.
        I was measuring the standby power supply of the TV when it tries to turn on. It measures about 8.18V - 8.24V - that's quite a large ripple. I'm suspicious of the standby caps the most, for this reason.
        • jsog
          • Feb 2011
          • 220
          Re: 32" Goodmans TV
          "Signal generator" can be as simple as a single resistor. The standalone meters usually use a single chip like a 74HC14 or even a 555 timer to generate a signal.
            Re: 32" Goodmans TV
            This is bizarre.
            I was scoping the 8V line and I notice it runs at 8.18V idle but every so often spikes to 8.25V. Perhaps that is caused by it cycling power: it's trying to start up, but failing.
            The 1.8V supply measures at 1.887V and the 3.3V supply at 3.324V... both seem perfectly in spec.
            I've ordered some replacement standby caps. I'll only replace the caps powering the inverter board if I have to.
            • dumpystig
              • Jul 2011
              • 485
              Re: 32" Goodmans TV
              i had a similar prob which I have just fixed. If you post more detail of what happens from plugging in the TV I may be able to help. To start with if all your standby voltages are correct check PL803, Pin 1, 3V2 - this is the output from the Mainboard that fires up the inverters.
              System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFP
                Re: 32" Goodmans TV
                When plugging in and turning on the TV, the blue power LED lights up, but nothing more. If I listen carefully, I can hear a faint whistling sound - a characteristic switching power supply sound. According to the person I bought it off, it will occasionally switch on, but I don't know whether or not to trust them.
                I've looked all across the board for a PL803 but can't find it. Can you give me a location to look in? The only connector which goes to the inverter is PL802, it is black and has many rails on it. Could a failing inverter/backlight be causing my problem? The TV has no sound and has no "2 secs to black" issue.
                  Re: 32" Goodmans TV
                  Oh, nevermind, just found PL803. I tried both sides (not sure which is pin #1) and both measure 0V. Scope shows a tiny bit of ripple (<20mVp-p) possibly just caused by the SMPS on the board for the standby supply.
                    Re: 32" Goodmans TV
                    OH! I feel like a complete DUMBASS!
                    I haven't been turning it on properly, that's why! You need to turn on the switch AND press the power button to turn it on.
                    Just got it to switch on and show "No Signal" on the display. It makes a rather loud buzzing sound from what I suspect to be the PFC transformer. Maybe this is shielded by the case or maybe it's just a crap TV.
                    Now I can try and debug the intermittent power issue reported by the original owner.
                    • dumpystig
                      • Jul 2011
                      • 485
                      Re: 32" Goodmans TV
                      My chassis Mainboard is Vestel 17MB22-2, PSU is Vestel 17PW20.1. I already see your PSU is the same, what about your Mainboard? PL803 Pin 1 is on the left, thin white wire.
                      D/l from this link, it helped me out a lot
                      http://www.megaupload.com/?d=ER9AMF73
                        Re: 32" Goodmans TV
                        Mainboard is the same. Looks like we have identical TVs. This will be helpful.
                        Are we looking leftmost pin on the PSU or on the mainboard - connector swaps around between boards.
                        • dumpystig
                          • Jul 2011
                          • 485
                          Re: 32" Goodmans TV
                          PSU - the corresponding plugs at the M/b are numbered differently. Have you d/l from the link above? You will find 2 pages with the layouts of both boards and associated voltages.
                            Re: 32" Goodmans TV
                            Yeah, thanks for that. Looks excellent. Anyway:
                            When plugged in while in standby: 0V
                            When plugged in while on, but not working: 0.01V
                            When plugged in and while working: 3.21V (note: it jumps to 0.04V just before starting and then to 3.21V and then the TV works and shows "no signal".)
                            I'll scope pin #1 later after the TV stops working again.
                            • dumpystig
                              • Jul 2011
                              • 485
                              Re: 32" Goodmans TV
                              Haha I've just seen post#10. good luck, if you have any probs let me know, I have gained more experience of these boards over the past 2 weeks (and it's done my head in!).
                                Re: 32" Goodmans TV
                                Thanks for your help
                                It's not turning on right now and the RUN pin (pin #1) is at 0.01V.
                                According to the Sanyo service manual PL811 should be pulsing. But it isn't. It's at a fixed 8.27V (when in standby.) So where is this pulsing produced and is it required to start the power supply? Would it be temperature dependent e.g. a bad cap?
                                  Re: 32" Goodmans TV
                                  Okay, I got it to power on after a lot of coercing.
                                  I found a service manual for a similar TV. The power supply is different (I believe it adds support for plasma panels too), but a lot of the component designators are the same and the layout is similar, so it might be helpful. I've attached the manual.
                                  Anyway, there's a pin called STBY on PL803. When it is not working, it is at 0.09V. When it is working, it is at 2.5V. Could the control board be telling the PSU to turn on using this? Why isn't it going high normally?
                                  PL803 when ON:
                                  #1: 3.204V
                                  #2: 0.512V
                                  #3: 0.050V - 0.150V (climbs slowly)
                                  #4: 3.364V
                                  #5: 2.578V
                                  #6: 0.050V
                                  #7: 34.03V (for tuner?)
                                  #8: 11.08V
                                  #9: 0.009V
                                  #10: 0.009V
                                  PL803 when set is in standby:
                                  #1: 0.001V
                                  #2: 0.000V
                                  #3: 0.001V
                                  #4: -0.003V
                                  #5: 0.060V
                                  #6: 1.754V
                                  #7: 33.02V (decays slowly)
                                  #8: 0.030V
                                  #9: 0.009V
                                  #10: 0.009V
                                  PL803 when trying to start:
                                  #1: 0.010V
                                  #2: 0.000V
                                  #3: 0.150V - 0.180V
                                  #4: 0.323V
                                  #5: 0.059V
                                  #6: 0.055V
                                  #7: 32.40V (decaying slowly)
                                  #8: 0.128V
                                  #9: 0.009V
                                  #10: 0.009V
                                  This is odd, because I would expect pin #5 to be the signal from the mainboard to turn on the TV, but there is no significant signal on it.
                                  But, when scoping it... I think it has a clue. While it is trying to turn on it goes crazy! It changes between several waveforms - at one point 2.5Vp-p - but eventually goes almost completely dead. Sometimes these waveforms show up when the set is switching on and sometimes not. And sometimes pressing the power button on the remote makes this pin go high for maybe half a second, then go low. Something is stopping it fully starting.
                                  I've ordered some caps, but it seems less and less likely to be a cap issue now.
                                  Maybe I should try jumpering this to 2.5V to get the set to switch on?
                                  • dumpystig
                                    • Jul 2011
                                    • 485
                                    Re: 32" Goodmans TV
                                    Yep, the answer is maybe related to Pin 5...
                                    Is the manual you have Hitachi No. 0234? That's the one I've been working from.
                                      Re: 32" Goodmans TV
                                      I'm trying to attach the manual right now... but it's taking a long time. I found it here: http://www.eserviceinfo.com/download.php?fileid=56543
                                      It is indeed Hitachi 0234.
                                      • dumpystig
                                        • Jul 2011
                                        • 485
                                        Re: 32" Goodmans TV
                                        No need for the attachment, we're on the same manual.
                                          Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
                                          by momaka
                                          I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
                                          For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
                                          https://www.badcaps.net/filedata/fetch?id=3591771
                                          https://www.badcaps.net/filedata/fetch?id=3591772
                                          It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
                                          https://www.badcaps.net/filedata/fetch?id=359177...
                                          03-12-2025, 03:42 PM
                                        • Paxman_Swede
                                          Identifying caps on an old Zoom 9000
                                          by Paxman_Swede
                                          Hello!
                                          I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
                                          The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
                                          I have studied the board and...
                                          01-14-2025, 09:51 AM
                                        • captain150
                                          Help with switching power supply caps
                                          by captain150
                                          I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
                                          I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...
                                          03-16-2025, 07:34 PM
                                        • Foetuss
                                          Gigabyte GA-6OXT :: caps question
                                          by Foetuss
                                          Good evening
                                          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                          But I was also suprised about the bigger boys, which are 330µF 25V.
                                          Could it be they used 25V caps because they were cheaper / available at that time?...
                                          02-11-2025, 12:22 PM
                                        • madscientist750
                                          Replacing electrolytic caps by solid caps on old motherboards
                                          by madscientist750
                                          I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                                          I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                                          I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                                          10-19-2025, 06:10 AM
