FSP PSU and Capxon caps
  • envoid
    • 26
    Hello again everyone.
    I'm trying to find a replacement cap for a Capxon KF 2200uf 6.3v cap that is/was in a FSP 600w PSU. What makes it so special is that it is 8mm in diameter and where it is sitting in the PSU it needs to have a heatshrink sleeve on it, making it 10mm. Anything larger than that will not fit due to two 45v rectifiers on either side.
    The FSP PSU model is FSX600-GLN.
    I looked up the specs for the KF series but they don't list an 8x20mm diameter cap for above 1000uf at 6.3v (which kinda leads me to believe it isn't even 2200uf). The closest replacement I found with the size constraints was a Nichicon HM.
    I'm thinking the HM will work as the ESR for the 8x20mm Capxon KF (~.15-.20Ohm) seems higher than the Nichicon HM (.16Ohm) but want to make sure I'm thinking this right.
    I had tried searching as I saw someone mentioning working on FSP PSUs before with the Capxon issues but wasn't finding anything more than that.
    Any help is soooooo appreciated! Thanks!!
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: FSP PSU and Capxon caps
    The HM is .016 ohms.
    I had an FSP 700W a while ago that had those and the HM were are the only thing I could find to fit.
    Ordered the caps but I haven't needed it yet so it's still sitting waiting to be rebuilt.
    These are a custom ordered size so not in data sheet.
    I think the 2200uF is probably right.
    In general KF cross-reference to about Chemicon KY and Nichicon HE.
    Using the KY 8x20mm I'd say this KF's ESR/Ripple is -around- .069/1050.
    HM is serious over-kill but I couldn't find any alternates for that one at the time.
    Mann-Made Global Warming.
    - Dr Seuss
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      Go with a 10mm cap and forget about the heatshrink sleeve - it's completely useless and does nothing for the cap.
      I've looked at the KF data sheets several times before when I was replacing caps in a monitor, and it seems that they are actually closer in ESR (at least for the sizes I looked at) to United Chemicon KZE and Rubycon ZL. I replaced mine with Panasonic FM, which are slightly better than Chemicon KZE and Rubyocn ZL, and I haven't had any problems.
      But I think that even Chemicon KY and Nichicon HE would also work.
      *** EDIT ***
      It seems that the data sheet for KF on CapXon's website must be newer than what I was looking at when I replaced mine. PCBONEZ is right - CapXon KF is closer in specs to United Chemicon KY and Nichicon HE.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Nice try but in some positions 10mm are a no-way no-go in this one and the heat-shrink IS needed because some of the caps are right up against energized heatsinks.
        - Dr Seuss
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Originally posted by momaka
          *** EDIT ***
          Capxon KF can be hard to cross reference because the can sizes for what ever uF are just plain weird in some cases.
          Not too unusual to have to go up a grade or two just to find one with will work in a good brand.
          - Dr Seuss
          • c_hegge
            • Sep 2009
            • 5219
            If there is absoloutely nothing else that will fit, then I would use the HM. It may not be an ideal replacment, but it will probably work, although it may make the ripple a bit higher.
            • envoid
              • 26
              Thanks everyone for the input. And sorry, I'm always off with my decimal places.
              The heatsink isn't charged, it actually gets screwed to the outer shell of the PSU. These rectifiers have pin 2 connected to the back but there is a very thin membrane between the heatsink and rect. The outer pins are grounded so the cap sits next to grounded pins on it, and a grounded heatsink. I wonder though if it is the coils it was being insulated from.
              The pic is from my BB so I apologize in advance. On the left I already replaced one of the KFs with a Panny FM I had. Little bigger and wider wire offset (forgetting the proper word) but it works (i want to add some hot glue on the side to help sturdy it though).
              I just wish they didn't cram that area and I could fit the FM in there with a little insulation...
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Mine has one that actually touches a heatsink and another that's so close to an xfmr that a 10mm would touch it's coils.
                - Dr Seuss
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  Even so, couldn't this be done by putting a piece of insulating plastic on the heat sink (the same kind that is used under the power supply PCB)? I've seen it done on other power supplies.
                  Yes, it seems CapXon likes to do that a lot and not just with the KF series. I've seen identical size and voltage KM caps that had different capacitance rating. Also seen it with GL. Really makes me wonder what CapXon did with those. Would be nice to have a capacitance and ESR meter in one of those cases.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    If I thought that would work I wouldn't have bought HM, and you know how picky I am about matching specs.
                    - Dr Seuss
                    • envoid
                      • 26
                      Thats funny, I was contemplating it also, just hadn't had the time to see if anything would work. I was pondering maybe electrical tape placed strategically, though I'm also not sure it is insulating from the heatsink but the coils. Or its for nothing at all and just to make it die faster.
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        Good point .
                        But still, if this is true:
                        ... then you don't need to isolate cap from the heatsink.
                        Probably a good idea to isolate it from the inductor/toroid, though (just in case).
                        Personally, I don't think it matters all that much (not for the caps on the secondary side, anyways). The cap has its own insulating sleeve, and if the inductor and/or capacitor should become so hot that the insulating sleeve on the cap burns, then I think you got bigger problems in the PSU to worry about.
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          That's fine for him. - Doesn't help mine.
                          Sleeves are not electrical insulation.
                          A number of cap manufacturers warn against using it as such.
                          - Dr Seuss
                          • yyonline
                            • Jul 2009
                            • 692
                            I'll second that. I'm actually fixing an amplifier at the moment that somehow had arcing through the sleeve of a capacitor to a nearby component, as it melted a little hole through the sleeve.
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              Interesting, didn't know that.
                              I guess electrical tape will have to do then.
                              • envoid
                                • 26
                                Tried fitting the 10mm Panny FM last night and it won't go in at all. It got half way and then it was too tight. And this is without any insulating materials around it. So the HM it is. That should get ordered in a few months lol.
                                This thing also has some teapo caps, should I just replace them while I'm in this thing? I read some conflicting threads on here about them. They are 5yrs old? One shows "12/06" on the wrapping.
                                Thanks again everyone!!
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  I wouldn't tear down a PSU just because it has Teapo, but if I have to tear it down and has Teapo I'll replace them while I'm in there.
                                  - Dr Seuss
                                  • envoid
                                    • 26
                                    I might do it anyway then. Better now than do this again later anyway. =)
                                    • delaware74b
                                      • Apr 2009
                                      • 628
                                      momaka - heat shrink tubing might be a better choice than electrical tape. It won't leave adhesive goo all over everything.
                                      Stupidity should be a crime, especially for drivers. I have NO patience for them.
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        • Bulgaria
                                        Yeah, that's one thing I don't like about electrical tape, too. Cleaning that sticky stuff isn't a lot of fun either. But if you apply it on something that doesn't move a lot and where the tape won't undo itself, then it's okay.
                                        Sometimes, I even burn it with a lighter to make it hard so that it won't undo itself. Helps a little bit, but not that much.
                                        • nick3092
                                          Mid/late 80's Nichicon Yellow Caps
                                          by nick3092
                                          I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                                          08-28-2022, 03:56 PM
                                          by momaka
                                          03-15-2023, 10:17 PM
                                          Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
                                          by momaka
                                          I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
                                          For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
                                          https://www.badcaps.net/filedata/fetch?id=3591771
                                          https://www.badcaps.net/filedata/fetch?id=3591772
                                          It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
                                          https://www.badcaps.net/filedata/fetch?id=359177...
                                          03-12-2025, 03:42 PM
                                        • eryjus
                                          Heathkit IO-4205 Power Supply Caps
                                          by eryjus
                                          First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
                                          I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
                                          I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
                                          05-10-2023, 11:21 AM
                                        • SwedishDiesel
                                          Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
                                          by SwedishDiesel
                                          Howdy folks,
                                          I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
                                          10-30-2021, 12:47 AM
