FSP PSU and Capxon caps
  • envoid
    • 26
    Re: FSP PSU and Capxon caps
    Hate to revive an older thread but finally got the caps in and since this is about this damn PSU again I felt starting a new thread wasn't right.
    I found some new Panasonic FR caps which are like the FM's but smaller but still had to use those Nichi's for that tight spot and replaced all the Teapo's and Capxon's. Now, wife's PSU is fixed, another PSU is fixed, but mine just keeps tripping the breaker as soon as AC is applied.
    I suck at switching power supplies so would like help if possible again. I'm thinking it is these 20N60C3 IGBT's as I get .1-.2ohm between collector and emitter and vice versa (though they are still soldered to the board as I didn't have time tonight to desolder them). I also get 22ohm from emitter to the gate on two of them while one is 2.2ohm (really). They are in parallel.
    From what I was looking at in their datasheet there shouldn't be any flow from E to C, am I correct in thinking that or totally off? I know I won't have 100% accurate readings while they are still attached to the board but am trying more prelim stuff before the deeper work. Nothing is fried or burnt and I quadruple-checked to make sure I didn't bleed over any solder.
    Also, oddly, the fuse hasn't blown in it.
    Any help, please? thank you!
    • nick3092
      Mid/late 80's Nichicon Yellow Caps
      by nick3092
      I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
      08-28-2022, 03:56 PM
      by momaka
      03-15-2023, 10:17 PM
      by momaka
      03-12-2025, 03:42 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • SwedishDiesel
      Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
      by SwedishDiesel
      Howdy folks,
      I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
      10-30-2021, 12:47 AM
