I have a magnavox 32mf231d with a couple of caps that just failed, lucky me. The pair that were on the power supply board were 1200uf, 35v. I went to radio shack looking for the exact thing, and they did not have them. They did have 2200uf, 50v caps and I was told that these would be fine to use as because they held more capacity. I remove the broken caps, install the new caps and put everything back together. When I plug my screen in, there is a beeping/warning sound coming from the power supply board and the tv won't turn on. Any thoughts on what is now the problem? Is it that the caps are so far above the originals?
Replaced bad caps, still having problems
Tags: None
Re: Replaced bad caps, still having problems
You need low ESR caps [which rack-shack does not carry] and whoever told you 1200uF -> 2200uF was okay was a moron.
Those caps are used to remove [filter] Ripple from the power supply.
The uF is chosen based on the expected Ripple frequency and the value of the inductor in the filter.
Changing uF that far 'de-tunes' it from being optimized for that frequency.
GP caps [like places like rack-shack sell] have a higher ESR which [without getting too deep] means they have a higher resistance to Ripple and thus the Ripple tends to stay in the power circuits. IC chips don't work real well when voltage sent to them is jumping all over the place.
I hope you saved the old caps.
Needed to get the ESR and Ripple specs to find correct replacements.
.Mann-Made Global Warming.
- Dr Seuss
Radioshack has been worthless for most things since I was in High School.
I Graduated in the 70's.
- Dr Seuss
Pcbonez you have it backwards, he had 1200 if and ratshack sold him 2200uf caps.
But everything else bonez said is right. Between the higher esr and higher capacity it probably detuned the circuit so bad it wont cycle properly. Post the brand and series of the caps and we can steer you in the right direction.Comment
Thanks to you and bonez.Pcbonez you have it backwards, he had 1200 if and ratshack sold him 2200uf caps.
The caps I had before were from CapXon. 1200uf, 35v.
Are these from MCM going to fit the bill?
http://www.mcmelectronics.com/produc...LAID=220394416Comment
Dont know if this helps any but here are a couple of threads with this set.
https://www.badcaps.net/forum/showthread.php?t=13566
https://www.badcaps.net/forum/showthread.php?t=13832
After your experience with that Radio Shak, I want to drive up there and fire the guy myself. I dont work for them but I'll tell the guy to punch out and go home!
These (badcaps) guys are correct in telling you about this error.The strong-minded rise to the challenge of their goals,the weak-minded BECOME HATERS
Wow, $3.83 for one no-name cap.The caps I had before were from CapXon. 1200uf, 35v.
Digikey has Panasonic FC for $1.25 or Panasonic FR for 1.18. Shipping from digikey is around $2.50 USD and arrives in 48 hours.
The choice between FC an FR will depend on what original Capxon series you have. On the Capxon cap should be a two letter code as per this post
https://www.badcaps.net/forum/showpo...39&postcount=2--- begin sig file ---
--- end sig file ---Comment
Which way is the arrow Hot Shot?Pcbonez you have it backwards, he had 1200 if and ratshack sold him 2200uf caps.
""1200uF -> 2200uF""
I didn't get anything backwards.
- Dr Seuss
The other side says LZ 105 C then p608 ventWow, $3.83 for one no-name cap.
https://www.badcaps.net/forum/showpo...39&postcount=2Comment
Here is the datasheet.
Ripple is obvious.
The ESR is for all intents and purposes is Impedance. [At 100kHz which is what they show.]
You want caps with the same or more Ripple.
And, the same or less ESR.
If your exact cap isn't in there it is special order.
In that case use the specs for the closest one [by uF/volts] with the same size can.
.Last edited by PCBONEZ; 06-12-2011, 07:04 PM.Mann-Made Global Warming.
- Dr Seuss
ooookayHere is the datasheet.
Ripple is obvious.
So would something like this be okay:
http://search.digikey.com/scripts/Dk...name=P12406-NDComment
What size is the can on the old ones?
- Dr Seuss
Well, if I had a stick of chap stick....
The diameter is important.
- Dr Seuss
That's way off.
Let me know when you get a ruler or a tape measure.
- Dr Seuss
Let me know when you get a ruler or a tape measure.Mann-Made Global Warming.
- Dr Seuss
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
https://www.badcaps.net/filedata/fetch?id=3591771
https://www.badcaps.net/filedata/fetch?id=3591772
It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
https://www.badcaps.net/filedata/fetch?id=359177... -
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
Channel: Troubleshooting Computer Displays
by zlr8rHey guys, bit stumped with this laptop after replacing 2 blown components i.e., MP86493, MP2979A.
To begin with, this laptop was dead-dead.
Now with replaced (visibly) blown components, i do get some progress; after connecting battery or main cable;- am getting white power led
- 5-long-flashes on CAPS Lock and NUM lock
- then, fan full speed
- CPU heats up some (smaller die PCH, does not)
- always constant black screen no matter what's tried
- no USB recognition
- no HDMI output
I tried... -
by dragon3xHi, I have some 32 bits computer motherboards that need repair, as they fail to
power on.
Here are some examples :
(N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
switching supply area).
(N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
than 6.3 V.)
1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
I replaced capacitors with aluminum-polymer.
3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA... -
by bcstedtLG 42LB5D (42LB5DF-UL) from 2008-01, unit is in good shape and no obvious heat damage or cracked solder on the boards.
Problem:
On first power-up the power LED flashes green about 18x and then stays solid. No backlight or image is present. Click power button, wait 10s for a click and the LED turns red. Wait 1-2s and hit power again and maybe it'll power up fully after 6 green flashes. If it doesn't light up on the sixth flash then the cycle repeats.
It seems that if the mainboard power is left on for a few minutes (solid green power, no backlight, no image)... - Loading...
- No more items.
