i also have a vx922 with fluctuating power from the 12v rail between boards. i have replaced all caps but the large 400v. still the power goes from 12v to 4v and repeats over and over. and the screen and green power light blink in time with it. what else could be the problem?
vx922 recapped still fluctuating power
Re: vx922 recapped still fluctuating power
1) A clear focused picture of your boards using the manage attachments function would help. Please do not post inline as it slows down loading of pages.
2) If you disconnect the logic board and ccfls, does the power board (now standalone) have steady 12V DC?
3) What brand and series did you use for replacement caps?--- begin sig file ---
--- end sig file --- -
Sounds like a possible short in the system. Power supplies for this monitor were supplied by different manufactuers, so without photos, help will be limited. If it's the power supply I'm thinking about, with power off, try checking the 4 surface mount transistors under the board marked "DK"? for shorts. Post some clear focused photos of the top and bottom of the power board. Do not post them inline, use the "manage attachments" button.Comment
is the circled fuse 1 supposed to be connected to the12v connector ? looks like the fuse moved , but is still connected well.
as for power when disconnected from the rest. no very minimal. when they are all connected, and the power switch is off, i get a steady 12.42v.
as for the type of caps, not sure it was all i could find at alfatronics. but i have all new panasonic fm caps comming from digikey soon.
thanksComment
when i disconnect the power board completly, minimal voltage.
as far as caps....NRWA series M for the two 470uf 25v (mine are 35v), and another no name with just an M on it for the one 330uf 35v, also the 2 big caps on the logic board g-luxon 411b(M) 330uf 16v, and one sheng 100uf 25v on the logic board.
if i put it all together again and plug it in with the power switch off i get a constant 12.42 v on the 12v connector between boardsLast edited by blutch; 03-24-2011, 07:39 PM.Comment
Whatever I do, I consider it a success, if in the end I am breathing, seeing, feeling and hearing!Comment
I give up. See
https://www.badcaps.net/forum/showth...773#post156773Last edited by retiredcaps; 03-24-2011, 11:56 PM.--- begin sig file ---
--- end sig file ---Comment
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 02:15 PM
by meraklinetxHello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
- Loading...
- No more items.
