Bestec ATX-250 12E going bad - waveform analysis
  • everell
    • Jan 2009
    • 1514
    I have worked with Bestec ATX-250 12E power supplies that were working OK, and I have worked on/fixed Bestec ATX-250 12E power supplies that were "blown". At last, I have one that is in between.
    The critical capacitor in the 5vsb circuit is labeled C1 (see attachment). Its value is 10Mfd/50 volts. This capacitor is NOT in the 5vsb line, but in the feedback side of the 5vsb transformer. It is part of the regulation circuit. To determine if this capacitor is giving a problem, you can connect an oscilloscope across the capacitor. Two pictures are attached, a picture of a good capacitor with a nice straight line. The picture of the bad one shows a peak voltage of 16.4 volts and lots of signal. The large signal is what is confusing the regulator and causing the problem. In this case the 5vsb was measuring 8.4 volts. The critical capacitor measured ESR = 43.
    Warning: when using an oscilloscope to measure this capacitor, you must have an isolated ground. If you hook the scope probe across this capacitor without proper isolation, it will blow your scope!
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
  • xchequer
    • Mar 2009
    • 3
    Re: Bestec ATX-250 12E going bad - waveform analysis
    Great scope pics of bad capacitor. Is that noise or oscillation? Try changing the scope time base and see what kinda results you get.
    • everell
      • Jan 2009
      • 1514
      Great idea. Here are some scope pictures of the same signal using different time bases on the scope. Looks like lots of oscillations on different frequencies instead of just noise. So what do you think?
      • xchequer
        • Mar 2009
        • 3
        It looks more like oscillations than noise. I guess if you need an oscillator you can grab a screwed up capacitor! If you can get a hold of a spectrum analyzer it would be interesting to see a fft analysis.
        • everell
          • Jan 2009
          • 1514
          My USB Stringray scope does have fft, so here is a picture of the signal in fft style. Not sure as to exactly what it means, but it is neat to play with the scope and experiment with all the knobs. Perhaps some of our other experts can tell us more about what we are looking at!
          • прямо
            Viper22A 5VSB circuit
            by прямо
            So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
            In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
            01-13-2024, 07:05 PM
          • kotel studios
            FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
            by kotel studios
            Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
            Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
            I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
            Any ideas where to go next?
            02-23-2025, 11:47 AM
          • mrcliem
            CM V700 no +5vsb, ICE2QR4765 low VCC in... Need guidance please...
            by mrcliem
            Hello...
            I got my self a dead CM V700 PSU, with nothing on +5vsb
            I have tried to fix it for the past 2 week, and I'm stuck... so i guess i post it here to get some pointer before i scrap it..
            As you can see in photo, the psu still pretty clean, no visible damage or bulging cap.. when i got it, it still has CM seal on it
            The +5vsb system use ICE2QR4765, I have trace and measure the voltage on ICE2QR4765 and the only voltage reading i got is in VCC 4.8v, Drain 310v and FB 3v.
            I have read the datasheet and and still can not...
            06-29-2023, 08:18 AM
          • socketa
            Zalman ZM500-GV stops after 40s and 5VSB drops to 2.5V
            by socketa
            Rescued this one
            Started it up in the computer case, and noticed that it would shut down after about 10s in the BIOS
            Took it out, connected to hard drive and it loses all power on all rails (except for 5VSB) after about 40s or so. (the same result happens without a hard drive connected)
            The 5VSB drops to 2.5V when it 'shuts down'
            And the voltage across the primary cap falls from 335V to 330V at the same moment
            I think that the 5VSB is regulated by an A6069H PWM chip (which was initially dropping to 2.5V even before the the PS-ON was grounded - but it now stays at...
            12-20-2022, 03:06 AM
          • hobostove
            Corsair RM1000e - Help identify 5VSB Zener diode
            by hobostove
            Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
            Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
            There's a 22ohm resistor that's melted and open, but it still has the bands.
            The other part is a zener diode and it's top went to jesus, so I can't read the marking.
            It looks like the diode connects the source and drain of a TNY284...
            03-27-2025, 02:25 PM
