Macbook air with 820-3437-B extremely slow
  • Francisco.s
    • 686
    • Spain
    Hi, have a Macbook air with 820-3437-B with a weird problem.
    It starts and seems to stop at the very beginning of POST, there is no chime and no access to usb boot pen-drive.
    Current consumption is near 500 mili amps and seems not to do anything/
    The weird issue is that if left it in this state "booting", the chime sounds about 4 minutes from start, and 2 minutes later I can see the pendrive led blinking and back-light is on. About 2 minutes more the progress bar starts, but in very slow motion.
    It takes more than 30 minutes to show the logo screen. (I am using a windows boot pen-drive)
    This board came to me with a new smc and I've tested a good clean dump for bios.
    At first I thought that smc could be not from a correct donor motherboard, so I decided to update smc firmware.
    So I use SMCTool_V1.0.7 to update the smc firmware and it took half an hour to do it.
    After that nothing has change, the chime sound and POST are still extremely slow.
    All voltages and signals seems to be in order.
    Could be a re-branded smc or a damaged smc, what do you think?
    Forgot to say that cpu temperature is normal and battery is original and ok.
  • mon2
    • Dec 2019
    • 14982
    Re: Macbook air with 820-3437-B extremely slow
    https://boards.rossmanngroup.com/thr...ry-slow.51214/
    • reformatt
      • Feb 2020
      • 1553
      These boards will throttle the CPU when a sensor is missing or there is bad data (e.g. when the trackpad is disconnected/cable is corroded/bad). I've also had slow boots off a bad SSD too.
      That said, it isn't normally that slow. ASD is available for this model, so might be worthwhile running it to check sensors etc. The problem with 2nd hand boards like this is you don't know what the last guy did to it.
      I'd start off with a known good clean ME BIOS for this board and go from there.
      • Francisco.s
        • 686
        • Spain
        Thanks mon2, i've read the post at rossmanngroup.com and seems to be the same isssue.
        I've tested the board with and without nothing connected.I will tray with external screen.
        In the post mention the idea to change the smc, but is not clear if it was changed finally.
        by the way, the smc version reported by MRI was 2.12f137, and before update with SMCTool is 2.13f15.
        I want t thanks MuertoGB and P Daniels for this great tool.
        • Francisco.s
          • 686
          • Spain
          Thanks reformatt, I've tested with no ssd connected, and also trackpad works ok, at least in boot selection menu.
          I've tested a different bios dump and cleaned me region and pram with Medusa.
          I will try ASD and let you know.
          • Francisco.s
            • 686
            • Spain
            I have managed to run ASD EFI 3S156 but can't run ASD OS 3S156.
            It shows an error with Management Engine:
            Chipset (test 1) - Management Engine Presence Test
            -verifies the presence of the Management Engine.
            ERROR-not found
            Can't go any further showing more errors due to track-pad (or mouse) has a terrible delay.
            I also run a linux distro from an external usb dvd drive, and it loads at a normal speed and runs smooth. (also trackpad is ok with linux)
            I tried a win-10 install dvd but never ends loading. (progress bar gets stuck)
            There are many references on internet about this error message but seems nobody solve the issue.
            • Francisco.s
              • 686
              • Spain
              Still working with this Macbook, I'd manage to disable the "chipset test" and there are no more errors detected.
              Something new occurred, now, doesn't work with a clean ME bios, it tries to start, but immediately goes to stand-by and takes only 20 mili-amps, but with the original bios newly programmed, boots but very slow as before.
              I'm thinking that is not a problem with SMC, but a cpu/pch issue.
              I wanted to say after update.
              • mon2
                • Dec 2019
                • 14982
                Still could be your bios.
                See here:
                https://www.badcaps.net/forum/showthread.php?t=47250
                • piernov
                  • Jan 2016
                  • 4438
                  • France
                  https://logi.wiki/index.php/ME_Disable_Strap
                  • Francisco.s
                    • 686
                    • Spain
                    See here:
                    Hi mon2, I've sent a pm to the author of the post, because it's not clear that bios solve the problem, and he says that bypassing chipset test, some more sensor errors were shown.
                    I bypassed chipset test, and no more errors were found.
                    Just in case I will reprogram a new dump.
                    • Francisco.s
                      • 686
                      • Spain
                      Originally posted by piernov
                      Hi piernov, I have tested the circuit of Q1920 and it works as it have to. (I think)
                      Pin 2 of Q1920, SPI_DESCRIPTOR_OVERRIDE_L, is high level and SPI_DESCRIPTOR_OVERRIDE_LS5V is low level, so SPI_DESCRIPTOR_OVERRIDE is low level or floating.
                      I've tested with shorting SPI_DESCRIPTOR_OVERRIDE to ground, and all is the same.
                      SMBUS_PCH_CLK and SMBUS_PCH_DATA has good dc level but no pulses. (R5300, R5301) (have nothing connected to the board)
                      All I2C signals in page 40 have good dc level and pulses. (except the above mentioned)
                      • gjlpereira
                        MacBook Pro A1708 - CPU extremely slow, locked @ 0.39ghz; fan full speed
                        by gjlpereira
                        Hi forum.
                        I'm working on a macbook pro, model a1708, that is running extremely slow.
                        Everything on it seams to work just fine, it just works extremely slow; painfully slow; especially running macos (windows and linux actually run OKish on it, slow, but usable).
                        One other symptom of the problem with the machine is that the fan is always running at full speed.
                        This machine has been worked on by someone else previously; they tried to repair it, but with no success. The motherboard does have sings of being worked on, but it all looks good/OK; like...
                        09-06-2022, 07:45 PM
                      • adelfr2009
                        HP Victus Charging Circuit Issue – System Extremely Slow, No Charging
                        by adelfr2009
                        Hi everyone, I’m working on an HP Victus 15 motherboard that previously had a strong short-circuit on 19v line. The laptop now powers on, but system performance is extremely slow and laptop works only on AC adapter
                        This are Important PIN Voltage Measurements (ISL88739 Charging IC)
                        1 ACIN 2.08V
                        2 ACOK 2.94V
                        3 SDA 3.28V
                        4 SCLK 3.28V
                        5 #PROCHOT 0v
                        10 COMP 0V
                        11 CCLIM 4.14V
                        12 FSET 0V
                        13 BATGONE 0V
                        16 ACLIM 2.48V
                        17 NTC 1.60V
                        18 DCIN 19.51V
                        20 VDDP 5.15V
                        21 LGATE 0V
                        22 PHASE 0V
                        23 UGATE 0V...
                        11-15-2025, 06:47 PM
                      • envym
                        MacBook Pro 2018 with Activation Lock
                        by envym
                        Hi everyone!
                        I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                        I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                        06-27-2025, 08:54 AM
                      • resistor83
                        Macbook pro 15" 2011 A1286 stuttering and slow
                        by resistor83
                        hi all, I have a problem with my macbook pro 15 inch, late 2011 with SSD, AMD Radeon HD 6770M dedicated video card and Intel HD 3000 integrated card.
                        I use the computer occasionally at home and a few weeks ago I noticed that the battery was charging very slowly, I changed the power supply with a new original one and the problem remains. I also changed the battery to a compatible one and the problem persists. Now for a few days I have also noticed that the computer after a few minutes from starting it jerks and becomes very slow. However, this problem arises in several ways:
                        02-09-2023, 03:19 AM
                      • Stevie_belfast
                        820 00850 Macbook Pro Slow performance
                        by Stevie_belfast
                        Hi guys
                        820 00850 board here, clean, no previous repair.
                        Had a short on PPBUS, I found the problem, was shorted cap C8150, replaced and macbook boots.
                        Problem is its very slow.
                        It would boot to login screen eventually, but mouse and keyboard very erratic and slow to respond.
                        When I tried Internet Recovery, it takes a few hours then fails on 2005F error.
                        When I try to boot from USB stick, it lets me select the stick, then just a blank screen and goes no further.
                        I restored using DFU...
                        10-20-2022, 04:55 AM
