Macbook Pro A1706 (820-00923) no boot if display or Trackpad connected
  • cyber47
    • Nov 2018
    • 11
    i have used the search function but i doesnt found my problem.
    I am reparing a MacBook Pro A1706 with the Boardnumber 820-00923-A.
    If i have the display and/or the trackpad installed the Macbook does not boot, i have 20V and 0.03 Amps at the charger (without the battery connected), i can post a video of the Amperemeter if this helps.
    The board has PPBUS_G3H and it seems it is in the S5 state (i have the voltage on the S5 rails but not on the S4 rails).
    If i connect the charger without die display and the trackpad installed i get fanspin and 20V with 0.8A to 0.6A. Here is a video of the Ampmeter: https://youtu.be/73dbuSqg0cw (if it is not ok to link my video i will remove it )
    Is this the normal boot behavior? If i connect a screen with usb-c to hdmi adapter i get no image.
    Without the screen and the trackpad connected the board has all powerrails present.
    I dont have a replacment screen or trackpad because i only repair MacBooks as a hobby.
    The board looks very clean and no liquid damage or burned components are visible.
    I hope the information are enough, please ask if a forgot something important.
    Thank you for your help
    Best regards
    Cyber47 from Germany
  • cyber47
    • Nov 2018
    • 11
    Re: Macbook Pro A1706 (820-00923) no boot if display or Trackpad connected
    sorry for a second post but i have a update:
    The Trackpad seems to work after i cleaned the connector again. I can feel the click now and from what i can see on the amperemeter the Board seems to boot, but i get no display on an external monitor, no chime and no green light on the shift-button. SMC seems to work because if i press the keyboard to perform an smc reset the amperemeter goes to 0A for a short time and up after that.
    If i connect the internal display the board does not boot, it only draws around 20mA at 20V. I get only to state S5.
    I am really bad with finding problems so any hint would be appreciated!
    Thank you very much!
    • dellxps15
      • Feb 2014
      • 1596
      • italy
      try pram reset (command option p r ). check if it chime.
      try usbc->vga or usbc-hdmi. if u plug power to usbc adapter use more then 67 watt charger
      plug a usb flash drive with led and see if it blink.
      if nothing happen. check lcd backlight cable if it has the common problem and maybe is shorting backlight to alluminium chassis.
      focus first on make it work on external (internal not connected)
      1° usb flash drive light blinking ?
      2° pram reset ?
      3° cpu get hot ?
      according to ampere consumption ur pc is starting and booting.
      if no image try dfu restore.
      • cyber47
        • Nov 2018
        • 11
        thank you very much for your help
        At first i have news about the board: i checked the connector on the display daughterboard and i have a short on PP5V_S0_ALSCAM_F on the daughterboard. I2C_CAM_SDA is very low resistant to ground on the mainboard and also on the daughterboard.
        I have used capton tape to disconnect the two lines on the connector and the board seems to boot (or behaves like it boots) with the displayconnector in place but i have no PPVOUT_S0_LCDBKLT.
        But you are right i will focus first on make it work on external display with the internal display not connected:
        I used the original apple usb-c charger with 30W but i will test other chargers
        I tried pram reset multiple times after you suggested it but i hear no chime, no external display and no light on the shift key.
        1° usb flash drive light blinks every 10 seconds, so i think the mac tries to read the drive
        2° pram reset does not make a difference
        3° cpu gets hot and after a while the fans go on
        I think a dfu restore is not possible with the A1706 Macbook Pro because i think it has no T2-security-Chip? If it is possible can you please link a guide or give me a hint how to do it? I only found guides for dfu restore for newer MacBook models.
        Is there anything i can check to make sure the integrated gpu is working?
        Thank you very much for your help again!
        Have a nice day
        Cyber47
        • cyber47
          • Nov 2018
          • 11
          i have a little update:
          1. I tested a charger with 100W but nothing changed.
          2. I am missing PPVCCEDRAM_S0_CPU and after i followed the signal i found out that PPVCCEDRAM_S0_CPU is missing because CPU_ZVM_L is missing.
          But CPU_ZVM_L is generated from the cpu, so i can nothing change here i think.
          I dont know if the signal is necessary or if it should be present at all because in the schematic the signal is negated, if i read it right.
          Can someone please help me to find out, if PPVCCEDRAM_S0_CPU should be present and if so if it prevents the board from turning on?
          Any hint would be great
          • DeCrybaby
            • Dec 2022
            • 3
            The PPVCCEDRAM_S0_REG_F should at pin 5 of U7760.
            Did you check at L7700?
            • cyber47
              • Nov 2018
              • 11
              thank you for your help!
              I checked PPVCCEDRAM_S0_REG_F at pin 5 of U7760 and i have 1.05V
              I also checked L7700, there i have also 1.05V.
              I followed the Signal and it seems it is missing CPU_ZVM_L at pin 2 of U7790. As far as i know the "_L" means the signal is low in its "normal" state? But i have no second working board to confirm. Do you know if it should be present?
              I checked all voltages that are on Power Aliases pages of the schematic and the only one missing is PPVCCEDRAM_S0_CPU, thats how i found that CPU_ZVM_L is missing. Are there any other signals or power rails i should check besides the ones on the Power Aliases pages in the schematic?
              Thanks again for your help
              Best regards
              • dellxps15
                • Feb 2014
                • 1596
                • italy
                bios still the original or u tried different bioses ?
                if original keep it that way.
                no apple logo on external ? both usb-c to hdmi or better usb-c to vga.
                if u tried everithing , check if notebook is seen in dfu mode.
                u can use a usb keyboard. just mainboard, usb-c hub and usb-c psu.
                • cyber47
                  • Nov 2018
                  • 11
                  Hello, sorry for the late reply!
                  Yes, as far as i know it is the original bios.
                  I have no apple logo on external, unfortunately i can only test usb-c to hdmi
                  Can you please give me a hint how i check for dfu mode on this model? i only find information about dfu mode for newer macBook Pros.
                  Thank you again for your help!
                  a little update: i found out, i have stable voltage of 1.046V at the PPVCC_S0_CPU and it is not dropping to 0.7V or something. Does this mean i have a bad cpu?
                  Best regards
                  • reformatt
                    • Feb 2020
                    • 1444
                    There is no DFU mode on T1 MAC's, only T2. What is the history of this machine? Any prior work on it (perhaps liquid damaged and already been through an ultrasonic)? Are the liquid damage indicators present or removed? Red or white if present?
                    Pay close attention to the pins around U7100, looking for any corrosion etc. Measure resistance of each coil for the CPU to ground, especially near the edges (as this is the area most often hit with liquid spillage). Also check CPU_VIDSOUT, CPU_VIDALERT_L, CPU_VIDSCLK as well for impedance/activity.
                    • mon2
                      • Dec 2019
                      • 14512
                      1) what is the voltage and current draw of the external power adapter?
                      2) what is the voltage to ground of ppbus_g3h ? Is it stable?
                      • cyber47
                        • Nov 2018
                        • 11
                        Thank you very much for your reply! I was on vacation over new year, so sorry for the late reply.
                        I don't know the history of the device, i bought it on ebay listed as not turning on. I don't see any signs of flux or other residue and the two liquid indicators i see are white.
                        U7100 has a little dust around, i cleaned it but otherwise it looks clean, i have a very low resistant to ground on CPU_VCCSASENSE_P, but i assume that is ok (around 1 Ohm resistance to ground, in diode-mode it shows zero)
                        I checked all the coils at the board again, the coils connected to PPVCCGT_CPU_PH1 are very low resistant, but also here i assume this is normal?
                        On CPU_VIDSOUT, CPU_VIDALERT_L and CPU_VIDSCLK my multimeter shows steady 1V if i connect the board to the charger.
                        Thanks again for your help!
                        Best regards
                        • cyber47
                          • Nov 2018
                          • 11
                          Hello, thank you for your reply!
                          I am sorry for the late reply, i was on vacation over new year.
                          I have 20V and after initial changes around 0.8A to 0.9A Current draw, if i have nothing connected to the board (no fans, no keyboard ...). I made a short vid for you to show you my power consumption. You can find the video here: https://youtu.be/gQxMTpfbCIo (hope this is ok)
                          PPBUS_G3H is 13.03V to 13.04V and stable, i have measured PPBUS_G3H for about a minute and the value did not change.
                          Best regards and thank you for your reply!
                          • No Lan
                            [Macbook pro A1708] [Boot loop] [Trackpad ?]
                            by No Lan
                            Hey everyone,
                            Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
                            Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
                            Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
                            05-24-2025, 03:09 PM
                          • mitchw
                            MacBook Pro M4 Pro - no keyboard / trackpad / lid sensor
                            by mitchw
                            Hello
                            I got this MacBook Pro M4 Pro to have a look at.
                            It was tiny bit liquid damaged, just the edge of the board got 1 small 10x10 mm area wet. I've seen much worse that still worked fine to be honest.
                            Since it was liquid damaged, warranty does not apply anymore.
                            Anyways it was checked at an local Apple Store and they discovered that it needs new trackpad, new top case, etc. Also it needed a new lid angle sensor which they replaced.
                            The main issue was that the screen remained black.
                            Anyways I cleaned the liquid damaged area, put the machine back...
                            09-06-2025, 07:19 AM
                          • Skrndelj
                            Apple Macbook Air M1 A2337 Trackpad problem
                            by Skrndelj
                            Hello all,
                            I am repairing a Macbook A2337 and i have a problem
                            The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
                            When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
                            I inspected the whole board and everything seems fine.
                            Can anyone help me as i didn't fiddle with trackpad...
                            06-11-2024, 04:26 AM
                          • fes_786
                            macbook pro A1706 820-00239-09 no boot
                            by fes_786
                            macbook pro A1706
                            BOARD 1: 820-00239-09 = 20v 0.125a usbc
                            BOARD 2: 820-00239-A = 20v 0.016a usbc
                            i have both these boards and they do not power up
                            on board 2 i have a short on c8006 pp1v0_sus 0.03ohm to ground
                            board 1 i have 1v on c8006
                            im new to macbook board repair so please be patient with me
                            could someone help me with which power rails to follow and what order do they turn on
                            ive been messing around with open board view and a schematic i found on this forum but im...
                            06-15-2023, 05:41 PM
                          • rynr
                            MacBook Air M2 A2681 no Trackpad
                            by rynr
                            I have been following the posts in the forum for some time now and have learned a lot. I would first like to thank you for this and hope that it will continue for a long time.
                            I received the MacBook in DFU. The recovery always failed with error 1. After some search, I was able to find a defective inductor (LT202).
                            After replacing the component, I was able to successfully complete the DFU restore. Unfortunately, the trackpad and keyboard where still without function.
                            So i measured all voltages and diodereadings on the JT400 connector. ...
                            11-04-2024, 09:56 AM
