macbook pro A1706 820-00239-09 no boot
  • fes_786
    • Jun 2023
    • 6
    macbook pro A1706
    BOARD 1: 820-00239-09 = 20v 0.125a usbc
    BOARD 2: 820-00239-A = 20v 0.016a usbc
    i have both these boards and they do not power up
    on board 2 i have a short on c8006 pp1v0_sus 0.03ohm to ground
    board 1 i have 1v on c8006
    im new to macbook board repair so please be patient with me
    could someone help me with which power rails to follow and what order do they turn on
    ive been messing around with open board view and a schematic i found on this forum but im stumped
    thanks
  • mon2
    • 14675
    Re: macbook pro A1706 820-00239-09 no boot
    You have 20V being negotiated which is a good start and confirms that the CD321x TI ACE controllers are functioning correctly.
    Review the voltage to ground of PPBUS_G3H. Measure (carefully) on each side fuse F7000.
    • fes_786
      • Jun 2023
      • 6
      board 1 = 13.07v on both sides of F7000
      PBUS RAILS:
      PPBUS_G3H = (13.1V schematic) (measured= 13.07v)
      PPBUS_HS_CPU = (13.1V schematic) (measured= 13.06v)
      PPBUS_HS_OTH5V = (13.1V schematic) (measured= 13.07v)
      PPBUS_HS_OTH3V3 = (13.1V schematic) (measured= 13.07v)
      PPBUS_S4_TPAD = (13.1V schematic) (measured= 13.06v)
      PPDCIN_G3H = (20V schematic) (measured= 20v)
      3V3 G3H RAILS
      PP3V3_G3H = (3.3V schematic) (measured= 3.416v)
      PP3V3_G3H_SMC_ISNS = (3.3V schematic) (measured= 3.416v)
      RTC RAILS
      PP3V0_G3H = (3.0V schematic) (measured= 3v)
      IMVP Rails (down???)
      PPVCC_S0_CPU = (1.5V schematic) (measured= 0.2v)
      PPVCCSA_S0_CPU = (1.5v schematic) (measured= 0.2v)
      PPVCCGT_S0_CPU = (1.5v schematic) (measured= 0.2v)
      CPU VCCIO Rails
      PPVCCIO_S0_CPU = (0.95v schematic) (measured= 0.96v)
      CPU EDRAM Rails (down??)
      PPVCCEDRAM_S0_CPU = (1.05v schematic) (measured= 005.7mv)
      PCH Prime Core Rails
      PPVCCPRIMCORE_SUS_PCH = (1.0v schematic) (measured= 1.0v)
      1V2 Rails
      PP1V2_S3 = (1.2v schematic) (measured= 1.2v)
      PP1V2_S3_CPUDDR = (1.2v schematic) (measured= 1.2v)
      PP1V2_S0SW = (1.2v schematic) (measured= 1.2v)
      0V6 Rails
      PP0V6_S0_DDRVTT = (0.6v schematic) (measured= 598mv)
      PP0V6_S3_MEM_VREFDQ_A = (0.6v schematic) (measured= 0.6v)
      PP0V6_S3_MEM_VREFCA_A = (0.6v schematic) (measured= 0.6v)
      PP0V6_S3_MEM_VREFDQ_B = (0.6v schematic) (measured= 0.6v)
      1V8 Rails
      PP1V8_SUS = (1.8v schematic) (measured= 1.8v)
      PP1V8_S4 = (3.3v schematic?) (measured= 1.8v)
      PP1V8_S3 = (1.8v schematic) (measured= 1.8v)
      PP1V8_S3_MEM = (1.8v schematic) (measured= 1.8v)
      PP1V8_S0 = (3.3v schematic?) (measured= 1.8v)
      1V0 Rails
      PP1V0_SUS = (1.0v schematic) (measured= 1v)
      PP1V0_SUSSW = (1.0v schematic) (measured= 1v)
      PP1V0_S3 = (1.0v schematic) (measured= 1v)
      PP1V0_S0SW = (1.0v schematic) (measured= 1v)
      T208 Rails
      PP3V3_S5_T139 = (3.3v schematic) (measured= 3.3v)
      PP3V3_S4_SOC_PMU = (3.3v schematic) (measured= 3.3v)
      PP5V_S0_T139 = (5v schematic) (measured= 5v)
      5V Rails
      PP5V_S5 = (5v schematic) (measured= 5v)
      PP5V_S4 = (5v schematic) (measured= 5v)
      PP5V_S4SW = (5v schematic) (measured= 0v)
      PP5V_S4SW_ISNS = (5v schematic) (measured= 0v)
      PP5V_S0 = (5v schematic) (measured= 5v)
      PP5V_S0_KBD = (5v schematic) (measured= 5v)
      3V3 Rails
      PP3V3_S5 = (3.3v schematic) (measured= 3.3v)
      PP3V3_SUS = (3.3v schematic) (measured= 3.3v)
      PP3V3_S4 = (3.3v schematic) (measured= 3.3v)
      PP3V3_TBT_X_S0 = (3.3v schematic) (measured= 3.3v)
      PP3V3_TBT_T_S0 = (3.3v schematic) (measured= 3.3v)
      PP3V3_S4_BT = (3.3v schematic) (measured= 3.3v)
      PP3V3_S4_TPAD = (3.3v schematic) (measured= 3.3v)
      PP3V3_S4SW_SNS = (3.3v schematic) (measured= 0v)
      PP3V3_S5_SSD_LB = (3.3v schematic) (measured= 3.3v)
      PP3V3_S5_SSD = (3.3v schematic) (measured= 3.3v)
      PP3V3_S4_MESA = (3.3v schematic) (measured= 3.3v)
      PP3V3_2V7_NAND_VCC = (2.7v schematic) (measured= 2.7v)
      PP3V3_S0 = (3.3v schematic) (measured= 3.3v)
      Missing the following =
      CPU EDRAM Rails
      sorry for long post ...... i thaught i might aswell measure them all
      board 2 = 13.09v on both sides of F7000
      board 2 i think i will make a new thread
      • fes_786
        • Jun 2023
        • 6
        R7103 - ALL_SYS_PWRGD = 3.27v
        u7800
        pvccio_pgood = 3.3v
        p1v8sus_pgood = 3.3v
        cpu_vccst_pwrgd = 1v
        s5_pwrgd = 3.3v
        p5vs4_pgood = 3.3v
        cpuvr_pgood = 3.3v
        p1v0pch_pgood = 3.3v
        p1vsus_pgood = 3.3v
        could u7210 & u7220 be faulty?? or cpu dead??
        according to all those readings it should boot up???
        • fes_786
          • Jun 2023
          • 6
          Looking under thermal camera
          A section of the cpu gets hot around 40c so im guessing if the cpu rails were shorted to ground by a cap cpu wouldn’t b getting power to heat up
          I think cpu is fried internally and shorting thats why cpu rail gets pulled to 0.0057mv
          140ma draw on usb
          If anyone has any ideas or thinks it’s something else then please say otherwise boards going on spares pile
          Now going to test BOARD 2 see if that 1 i can fix
