Please help me clean my bios. This is the bin file. Anyhelp will be appreciated
Lenovo 11E8 M70Q DIFFERENT FROM 11DT. REQUEST BIOS PLEASE
Tags: None
Re: Lenovo 11E8 M70Q DIFFERENT FROM 11DT. REQUEST BIOS PLEASE
Hi
Give this one a try.Attached Files -
Hi
If you trying to verify the contents of this file against your chip then it will be in disagreement.
Need to make sure chip is making proper contact with the programmer.
Empty chip, Blank check it.
then burn and verify.
regardsComment
Thank you
I've already completed the process that you've mentioned but after that, my m70q doesn't boot anymore
I've tried removing and placing back the battery and changing the position of the jumper wires but it's still not turning on. It's still receiving power since my flash drive led indicator was lighting up whenever i plug it in the usb slot. Is there anything that I can do to fix this?
Use different software,there`s NeoProgrammer,Colibri and ASProgrammer ,you`ll find them all posted on the forum .Choose the chip manually,don`t use Auto-Detect .The chip part number is etched on top of it,select it from the support list.Thank you
https://www.badcaps.net/forum/showpo...40&postcount=2Comment
Thank you! I've actually followed all the step on that thread but it gave me this error. I really don't know why :'(Use different software,there`s NeoProgrammer,Colibri and ASProgrammer ,you`ll find them all posted on the forum .Choose the chip manually,don`t use Auto-Detect .The chip part number is etched on top of it,select it from the support list.
​https://www.badcaps.net/donateComment
It doesn't turn on for me anymore, after trying with a CH341a, they know what I'm doing wrong in the m70q model.
Already with m710q I have achieved it successfully.
Do you know what it could be?Comment
hi
this is not programmer problem. 11E8 oem product for amazon costumer services. It uses Coreboot bios. All other models works with AMI bios. 11E8 only works with special chrome os for amazon. You can't replace bios beacuse there is very important security partition inside bios chip. you need check this pages.
https://edk2-docs.gitbook.io/underst...tel_boot_guard
https://cdn.badcaps-static.com/pdfs/...de23cefb86.pdfComment
There is two bios chip on this machine. All chips OTP function activated and some partitions erase protected. You need change 16mb chip and flash your original dump. There is no other solution for now.Comment
I already replaced the Chip, but I don't know which bios to configure since I used the ones above and it only turns on and then turns off.
Does anyone have one that works?
Thank youComment
i have same problem this bios only works from chrome os amazon, i need bin files for ec, ec bios and main bios for install windows, only whit the original file (amazon works) whit others files only power on and shutdown inmediatly(no works)Comment
Hi! May i know if there is proof of this method working without issues? i have one of these machines and really like to give an usage as for right now its idle getting dust sadly... or where i can find more info about it as per google and bing this is the only place with some info and really like to gather the info so i can give it to a technician to help me with the machine.Comment
My brother! You and I are in the same boat. I have this exact model and am searching from answers on the internet on how to wipe the operating system and install anything else (either linux or windows).
I am a layman on this area, so this is all very new to me. However, I already ordered a CH341A and as soon as it gets to me I'll start tinkering with the machine.
Apparently this is a special model where they put a lot of protections, even at a hardware level. Switching the jumper to delete/restore CMOS/BIOS didn't do anything, neither taking ou the cell-battery. And, apparently, just flashing these custom BIOS available to other models doesn't seem to work.
However, I have a couple of ideas I want to try (before attempting to downright replace the chips). If I have success doing so, I'll post on the forum.
Please, stay tuned - and also, if you get something good going, share as well!Comment
Thanks for taking your time to reply to my message, never receive an email with the reply lol but yeah its kinda hard and sad not to find any info related to this, i think next week i will try to change any physical bios chip with a friend and see how it goes, wish me luck and ill let you know if this method work.My brother! You and I are in the same boat. I have this exact model and am searching from answers on the internet on how to wipe the operating system and install anything else (either linux or windows).
by fefocaceresHi everyone,
I need some help unlocking the BIOS on a Lenovo ThinkCentre M70q Gen 2.
The admin password is set and I can’t access BIOS settings.
Here are the system details:- Model: Lenovo M70q Gen 2
- Product type: 11DT
- Serial number: MJ0GSLST
Channel: BIOS & Schematic Requests!
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
I am attempting to remove the WWAN card whitelist from my Lenovo ThinkPad T560.
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
- Loading...
- No more items.
