Philips 55PUS6262 no picture
  • mrsith
    • Mar 2021
    • 146
    • Wielka Brytania
    Hi. I have seen a thread with this TV model, but the solution wasn't applicable to my set unfortunately.
    I got the set very cheap with problems on the right side of display - it was flickering and fuzzy with whitish noise. After a bit of play I have noticed that the set is fine with only left LVDS plugged in - but, unless I pressed the LVDS connector (on either side which is strange), there were some purple artifacts appearing. Decided to replace T-Con with both LVDS tapes (suspected bad tapes). After replacing them - same effect, with purple artifacts disappearing when pressing LVDS conn. After a bit of playing it stabilised though - artifacta disappeared.once and for all, so I have half screen working fine.
    Found a post on badcaps with this model - tried updating the software but as expected - no change.
    Tried the cut tape, my beloved method - either no picture at all, or flickering white screen that blinks faster and faster then shuts off (just the bad side).
    Ohm-measured caps on LCD panel board - there are 12 ~34ohm caps, 10 of which are situated in the same.locations next to bond tapes. There are no other SMD's on board rather than caps and resistors. All the ICs, testpoints etc are on T-Con board.
    Not sure where to look next. I'd suspect something bad on T-Con, but it has been replaced. Could you please guide me what should my next step be?
    Many thanks and kind regards
  • nomoresonys
    • 12276
    • U.S.
    Re: Philips 55PUS6262 no picture
    did any of those 12 caps test shorted?
    • nomoresonys
      • 12276
      • U.S.
      34 ohm seems pretty low.
      • mrsith
        • Mar 2021
        • 146
        • Wielka Brytania
        All of them had ~008 on one side and ~040 on another (diode testing). For some reason my multimeter doesn't beep at all.
        The rest of the caps rise to infinite ohms as they should so I'm pretty sure something shorts them. Seen some guides on what to measure but all of the IC's and testpoints are on T-Con board which has been replaced.
        • nomoresonys
          • 12276
          • U.S.
          well maybe put it in diode/continuity mode, put probe on each end of cap if it reads 000 or close it's probably shorted.
          • nomoresonys
            • 12276
            • U.S.
            in diode mode you can put one probe on ground, the other on either side of cap, should probably read close to 000 on one side and I or l on the other, if you get close to 000 on both sides it's probably shorted or there's a short nearby.
            • mrsith
              • Mar 2021
              • 146
              • Wielka Brytania
              Like I said, in diode mode (ground-cap testing) I am getting ~040 on one side and ~008 on another, on all of low-ohmed caps. I'll check probing on both ends on cap then.
              • nomoresonys
                • 12276
                • U.S.
                those readings are not what I get when testing. ARE you testing as posted in #6?
                • mrsith
                  • Mar 2021
                  • 146
                  • Wielka Brytania
                  Had to slightly calibrate my multimeter, but finally I have somewhat normal readings:
                  Cap leg to leg diode - healthy caps show ~670 or above, all of the 12 sketchy ones ~035.
                  Cap leg to ground - healthy are ~600 one leg, 000 other, sketchy ones ~030 / 000
                  Still not sure how to identify le source of the problem properly.
                  • nomoresonys
                    • 12276
                    • U.S.
                    can you post a good picture of those? do any of them get hotter than the others, sometimes it's only one bad cap, if they are big enough to work with, maybe remove one on the end and test it out of circuit, see if you have the same readings.
                    • mrsith
                      • Mar 2021
                      • 146
                      • Wielka Brytania
                      I'll grab a thermal camera from my friend and try to locate the bad guy then. Will post the pics tomorrow.
                      • mrsith
                        • Mar 2021
                        • 146
                        • Wielka Brytania
                        There are pics attached - encircled bad caps, one shows place from which I desoldered a bad cap (didn't change anything). Most of them are in pairs, small + big just next to each other. Just differs slightly on either end of the board.
                        I didn't manage to get ahold of thermal cam today, so I've used a pistol-type thermometer, no place on board seemed to be warmer than 19.x°C, not a single piece warmer than the others around. Used my fingers to confirm that 😁
                        • nomoresonys
                          • 12276
                          • U.S.
                          ok, did you test that cap now that it's off the board? test the pads it was soldered to also.
                          • mrsith
                            • Mar 2021
                            • 146
                            • Wielka Brytania
                            Sorry for late response.
                            The pads are showing sort, I am not getting anything when trying to measure caps outside the circuit. I'll continue desoldering them one after one in hope that the short will disappear along with one of them.
                            • mrsith
                              • Mar 2021
                              • 146
                              • Wielka Brytania
                              My hopes were answered, the short is gone along with one of the caps. Grabbed one looking the same from spare T-Con board from this TV, and got healthy measures on all components. Tried to turn the TV on but still no picture. After disconnecting bad side LVDS, I am getting half picture with purple artifacts again, and again they react on pressing the LVDS connector or the tape itself. I'll try playing around with this to get a stable half good picture, then I think I'll try scotch taoe method again, maybe without the short it'll work? Also will doublecheck everything with DMM again.
                              • nomoresonys
                                • 12276
                                • U.S.
                                sounds like a solid plan of action.
                                • mrsith
                                  • Mar 2021
                                  • 146
                                  • Wielka Brytania
                                  So, the half picture kinda stabilised after a bit of play, if I mess around the tapes or the TCon itself it likes to wiggle some purple stuff on the screen. Decent enough for tests though.
                                  Cut tape method didn't return any joy unforunately. I noticed however, that with only bad side connected the TV shines white on good side with no picture on bad one. With the short present, it was all black, so it's a tiny step forward I guess.
                                  Any advice where should I look further? Many thanks in advance!
                                  Edit: I did some measurements. Got 3.3v on VCC, 1.65v on VCC18, 16.6v on VDD. VGH even and odd both jump between 28 and -7v every couple of seconds. VGL_2 is missing entirely.
                                  • nomoresonys
                                    • 12276
                                    • U.S.
                                    maybe check the caps on the tcon if you didnt, test same way as the others.
                                    • nomoresonys
                                      • 12276
                                      • U.S.
                                      ok, so if you have 2 tcons to work with maybe try the original, you can see if there's a difference in those vgh readings and such.
                                      • mrsith
                                        • Mar 2021
                                        • 146
                                        • Wielka Brytania
                                        The original TCon was used as a source of caps so it won't be relevant. Didn't find anything wrong or unusual on the new one, everything I measured seems OK.
                                        Is there any chance that the original short on panel caused some IC on both tcons to fail?
                                        BTW the voltages are the same with only good half of the screen connected.
                                        • Rauni
                                          Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
                                          by Rauni
                                          Hello, this is my first post on this forum, and my first attempted to repair a TV.
                                          My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
                                          Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
                                          Read also that we should test what happens if we...
                                          10-01-2023, 12:06 AM
                                        • Schwoin
                                          Philips 243v5lhsb00 Monitor Picture too bright
                                          by Schwoin
                                          Hey everyone,
                                          the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
                                          While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
                                          you can see them on the top half of the photo.
                                          At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
                                          03-21-2023, 12:40 PM
                                        • madyoyo
                                          Philips 37pfl560: Yellow picture
                                          by madyoyo
                                          HI.
                                          I have a weird problem with an old Philips 37pfl560 TV i put out of storage: the picture have a noticeable yellow hue, and its not caused by the settings (did a factory reset). I've never seen this before. I will try to get a photo with a real camera, with my phone its hard to see because of automatic white balance, but in real live the whites are really yellow.
                                          Anyone have an idea of what can cause this? Can CCFL tubes get "warmer" with time? This tv have several analog inputs,so its nice for retrogaming....
                                          05-30-2025, 10:16 AM
                                        • mecha1166
                                          Un70nu6900 taped lvds, how to fix washed out 1/2 picture?
                                          by mecha1166
                                          I am getting these 70 inch Samsungs daily. Dead set light comes on goes off, dark screen. Tried taping the problem lvds cable pins 13 to ? pin, used about 9 mm scotch tape. Picture comes on, no distortion lines, looks good, but 1/2 of screen is washed out. Problem seems to always be the last little strip on the bottom. Has anyone found what is actually the problem? Possibly one of three diodes there? I have a pic but it is washed out on 1/2. Anyony had success in fully restoring the picture? Thanks.
                                          07-03-2024, 05:03 PM
                                        • charlesdutcher
                                          No picture issue in Philips Chassis FTL2.1
                                          by charlesdutcher
                                          My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
                                          Is there someone having any symptom like this? How to fix it?
                                          Thanks in advance!​
                                          08-06-2024, 09:55 PM
