Topcat's Ultimate Pentium 4 Retro Gamer!
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    I'll open this build with the comment that the Pentium 4 processor was probably my least-favorite CPU; even in Xeons. Netburst processors were hot-running and quite unimpressive performers considering the high clock speeds....but they were capable to a certain extent.....and are now entering the peculiar era of 'retro-ness'.
    With that said; I was given THIS LITTLE JEWEL last Friday....a gaming rig built on the very CPU I liked the least....but there were some interesting things in it to say the least....and I really don't have a really good P4 retro gamer in my fleet....so....hmmm...yea...lets have a little fun with this! If I trash it, I probably wouldn't get upset at all....So why did I make a new thread rather than just add it to the 'weird build' thread since it seemingly an insignificant build?! I dunno...but some mods were done; so it's not 'stock' anymore. Maybe that and the fact it has such a killer GPU will be enough to set it apart and qualify it for a thread of its own!
    Just a quick recap of the important stuff in it:
    Gigabyte GA-8PENXP v2.0
    P4 Northwood @ 2.6GHz
    2GB RAM
    eVGA GeForce 6800 Ultra 256mb
    Bunch of unknown size IDE HDD's
    Chieftec case, not sure what model it is.
    ...and here we go!
    It's time to start taking this thing apart. I don't know if I'll be reusing this case....my OCD is already going ballistic over the missing door; but the case is otherwise in pretty decent shape. I do not have any good quality beige cases of that era to put this in....so the case may be a problem at some point.....but I'm a long way from case selection, I have time to ponder that one.
    The best part of this build is the eVGA GeForce 6800 Ultra 256mb GPU....and an Audigy2 sound card.
    As I was pulling it apart, I found a dial-up modem....yawn yawn, not uncommon for a system from 2003...but there was also a PCI NIC.....which raised concerns the onboard was bad....another thing common to find around this area due to surges & lightning strikes.
    It has 2gb RAM, not a single stick matched and they're the wrong speed (PC2100 & PC2700)....not a single stick of PC3200, which is what it needed....
    I test fired it on the bench, I wanted to test the onboard NIC; which is 100% in working condition....not sure what the second one was all about....maybe it was some weird network config they had going.....don't know and don't care....the one that counts works! Also peeked at the CPU.... A Northwood @ 2.6GHz.... Boggles my mind why they put such a lame CPU and a bunch of slow mis-matched memory in this thing, but such a kick ass GPU....
    While I had it set up for testing, I also flashed the BIOS with the last release. It still had the first release on it.
    Now comes the fun. It needs some recapping!!
    This thing is filled with Nichicon HM series from their 'rotten years'... None of them were bloated or vented.....but get a load of this!!
    None of them were even close to their tolerances. The one above actually started off around 7300uF and trickled down a little. The 1000uF caps I checked as I pulled ranged from ~1300uF to ~1600uF. ESR was also reading out of spec (high). It's a wonder it worked at all....but I didn't have any real loads on it when I checked it. FWIW, the Sanyo WG's were in spec, it was only the Nichicons (majority) that were out.
    Anyway, here's where the fun starts.....lets polymod this thing!
    The secondary VRM module first....
    ...and of course the motherboard...
    Now time to refurb the fans....
    The motherboard was disgustingly filthy. I did hotwash it, blast the water out with the air hose, and then let it sit under a heat register for an hour or so while I finished the fans.
    Fans & VRM done.
    Now for the GPU, which is just as crudded as the motherboard was..... I didn't hotwash it, as it's easier to clean with small brushes & compressed air; far less crevices for shit to live...I really didn't want to wet this if I didn't have to.
    Heatsinks removed to reveal the trash thermal paste they used has comletely dried out.
    Disassembling the fan.
    The remaining dried out crud cleaned off.
    Back side of the PCB cleaned off.
    Sinks washed off & dried.
    Washed the fan & housing out. I also stripped & repacked the GPU fan bearings.
    GPU going back together.
    ...and done!!
    Now time to test fire it and see if the magic smoke wants to be released!!
    Nope, it POST'd and ran!! ...and I was very happy to see that; considering all that had just been done (especially the GPU)! The only glitch I noticed, the VRM fan is temperamental. Even after servicing, it doesn't always start on it own. It's spinning free, but sometimes it needs a little nudge, then it takes off....
    That's all for today....I'll tackle that power supply next..... I also want to get a better CPU and the correct speed RAM for it in larger modules. I have plenty of PC3200, but only in small denominations..... Stay tuned!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Topcat's Ultimate Pentium 4 Retro Gamer!
    What type of grease did you use to repack the GPU fan bearing? I ask because I had a similar problem with a House fan running slow. I am sure they are different bearings. With the house fan it has an oil impregnated sleeve they called a bearing and ended up being worn out by about 5 1/2 years. I then use Permatex anti-seize lubrication 80078 on the sleeve and the shaft. And the fan is still going 3/4 a year later. This lubricate holds up to 1600F but around 400F it starts to turn to a paste.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      Third paragraph in this post:
      https://www.badcaps.net/forum/showpo...8&postcount=13
      Team : 49813
      Join in!!
      Team Stats
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        Originally posted by Topcat
        Zep 2000 is very popular. Even the manufacturer is out of stock. Interesting article. Thank you.
        The anti-seize I was told by a Korean War Veteran Marine that anti-seize can be put underwater indefinitely and when one goes to undue it there is no problem even in salt water. I used SeaFoam penetrating oil to spray all the crude off.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16959
          No problem. Zep2k is wonderful stuff! Pricey, but a little goes a long way. It's probably out of stock for the same reason a lot of other things are.... I've been reviving fans with it for over a decade, I've never had to redo one again later on.
          Team : 49813
          Join in!!
          Team Stats
          • keeney123
            Lauren
            • Sep 2014
            • 2536
            And this works on a house floor fan the same way?
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16959
              That I couldn't say...but I'd render a guess that if you can get this stuff into the bearings or sleeves, it would do fine.
              Team : 49813
              Join in!!
              Team Stats
              • Dan81
                SNES-powered
                • Oct 2013
                • 1866
                • Romania
                Welp, guess my 8IG1000 Pro + Prophet 3D 9700 Pro are no match for this monster
                Main rig:
                Gigabyte B75M-D3H
                Core i5-3470 3.60GHz
                16GB DDR3-1600
                Samsung SH-224AB DVD-RW
                Delux MG760 case
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16959
                  I had to take this off the bench to work on other things....but before I did, I did some experimenting. The 2 extra RAM slots don't come without a little kryptonite. Even Gigabyte's site warns of this; slowdown in memory speed if the additional channel is used on each bank....so I wanted to see how much..... It drops from 200 to 160 per channel according to memtest....that's pretty significant. I also tested it with 4gb RAM, 2 1gb modules in each bank. POST screen sees 3.3gb. I found 4x 512mb OCZ PC3200 DIMMs in the pile, that has it at 2gb running @ full speed; 400MHz interleaved between both channels per bank....I'm fine with that. A gaming rig of this era running XP Pro and age-specific games will rip on this. More as this develops further.
                  Team : 49813
                  Join in!!
                  Team Stats
                  • Dan81
                    SNES-powered
                    • Oct 2013
                    • 1866
                    • Romania
                    I've been reading your original post - your monster of a 8PENXP seems to have had Nichicons gone bad all around.
                    My 8IG1000 Pro surprisingly had only one HM go bad over the first DIMM slot. The rest of the board had OST RLS and RLX all round the CPU and AGP sections, and more OG HM caps inbetween PCI, ATX plug and right on the corner of the board, near the USB headers.
                    i just went ahead and yeet'd the hell out of every HM I could lay my eyes on, and put some 2007/08 OST RLX in their place. I figure those being 1000uF, they're usually okay for the most part (never had any go bad from these. None at all.).
                    Oh, and while doing a whole Texas Chainsaw Massacre out of those HMs, I also added some KZGs to the pile, installing some Ruby MBZ in their place on the mobo. Up next would probably be replacing the low VRM side with MBZs as well, though it seems whoever recapped it with OSTs didn't have any issues with it, and it's been an almost 24/7 running machine.
                    Tip: For the VRM fan (and any sleeve bearing fan for that matter), use some bicycle oil. I had to use such oil on my 8IG1000's fan and it quickly sprung back to life.
                    Main rig:
                    Gigabyte B75M-D3H
                    16GB DDR3-1600
                    Delux MG760 case
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16959
                      None were bloated, but all I checked were severely out of tolerance.
                      I polymodded mine where it counted....the rest done in Rubycon ZLH.
                      I use grease in them. This fan seems to have some electrical issues.
                      I found a P4 Prescott 3.2GHz 1M L2! That should do it! I found a couple 3.4's, but priced more than I was willing to spend; cheapest was $100!! I got the 3.2GHz for $22. 200MHz from a netburst CPU will yield very little (if any) improvement, the 3.2 will be plenty!
                      Team : 49813
                      Join in!!
                      Team Stats
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16959
                        I was scouting some parts last night for a customer build when I stumbled upon something very peculiar that would work on this build; which will take this build in a very different but neat direction!!
                        Team : 49813
                        Join in!!
                        Team Stats
                        • Uranium-235
                          Comrade Glimmer
                          • Aug 2007
                          • 5045
                          • US
                          A retro gaming system for me would be like a pentium 3 with a geforce 3. That is what I had in high school. 667/gf3 ti 200
                          though I would want to up it to a socket 370 vs the original slot 1.
                          Though it originally came with a voodoo 3 2000 agp. Maybe I could...run my 5500, it was released in 2000, about the same time as the computer I had.
                          too bad I can't put my geforce 4 4600 in it, it was in 2002, too late for the computer I had
                          would also have to put windows 98 on it lol
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16959
                            It would be close enough. If the hardware is ~a year or so apart, it works. The voodoo3 is the best all-around 3dfx GPU; and is my favorite. It would play all the glide games smoothly at resolutions appropriate for them at the time. The V5500 would too, at higher resolutions....but most of those old games weren't intended to be ran that high, and had other issues that went along with it; such as text being way too small....but they would run none the less.... I have one V5 system here, just for nostalgic reasons I suppose.....but the crazy money people think these are worth is getting absurd.....but supply & demand I suppose; they don't make 'em anymore!!
                            If you're running your V5 instead of it sitting in a stinky storage unit, my soul is happy for it.
                            Team : 49813
                            Join in!!
                            Team Stats
                            • Per Hansson
                              • Jul 2005
                              • 5895
                              • Sweden
                              There actually is a guy that has remade several of the old Voodoo cards.
                              It can be done because there was a surplus of VSA chips left over when 3Dfx went bankrupt
                              They can be bought in the hundreds on auction sites still today...
                              https://www.techpowerup.com/forums/t...eering.278724/
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16959
                                If "anthony" ever decided to market those, they would sell faster than he could build them..... I'm guessing he's not probably because of ownership issues....but impressive none the less!
                                Team : 49813
                                Join in!!
                                Team Stats
                                • Uranium-235
                                  Comrade Glimmer
                                  • Aug 2007
                                  • 5045
                                  • US
                                  I would never put it in storage, too hot
                                  I also have a voodoo 3 2000
                                  Have you heard of glide wrappers? I used it to play Descent III. You can actually wrap it for the vulkan API
                                  Yeah I heard someone made a V5 6000 with four VSA chips
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16959
                                    Yea, a lot of enthusiasts created them after the fall of 3DFX to make glide games run on non-3DFX cards; the only prerequisite is the card support OpenGL, which pretty much all better ones did....for example, Diablo2....which was written for Glide acceleration and performed horrible on D3D. The Glide wrapper allows it to run in Glide (through switches at startup) even on modern hardware, and it plays beautiful! The only GPU's I've seen wrappers not play nice with are embedded Intel HD / IGP's.
                                    For games natively supported by glide, on a 3DFX card you wouldn't need this. You wouldn't be running your 3DFX cards on anything newer than XP, and XP drivers for 3DFX were sketchy at best, as they got bought out very early in the XP era....wasn't a lot of support. Win2k is a great OS for your 3DFX cards.
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      • Bulgaria
                                      Me too initially. But now I've come to appreciate them quite a bit more. They are the ONLY CPUs from that era that can still be used on the web today (if armed with a little patience, of course.) OK, sure, the socket 939 Athlon 64 X2 are better... but those came just a tad later and they still do worse than P4's on video encoding/decoding (including online, unless Windows 7 and FF Quantum is used - then the two cores of the X2 obviously will win over the P4's, with or without HT.) So the P4 architecture held up quite well, despite everyone's expectations (or lackthereof.)
                                      I think it's the motherboard (well, OK, and the GPU too ) here that really sets it apart with the modular VRM module and 6 RAM slots. In case of the latter, I have not seen or heard of such a beast before. Very very interesting!
                                      Reminds me of that one motherboard with the vacuum tube for the audio circuit. I'm sure many of you here know which one I'm talking about (sorry that I don't recall its brand and model at the moment.)
                                      Anyways, I really liked the amount of diversity of features in that particular era. Almost every manufacturer has tried something that wasn't tried before, just to make a mobo that will stand out against the others.
                                      If it's missing - make it!
                                      Beige case would probably be a little "too retro" for this build. XP era was the "silver" case era, more or less... and IIRC the first time when people started doing cases with see-through windows, lights, and etc. So I think this case here could fit the bill with a little custom fabrication.
                                      https://www.badcaps.net/forum/attach...1&d=1646704260
                                      Nice!
                                      It's not only nowadays that these are worth a lot of money. Even back then, someone spent a good chunk of money on that 6800 Ultra. Though I think at one point, the AGP variants were considerably cheaper than the PCI-E ones, simply because AGP was getting outmoded and considered "legacy". Funny how time reverses things.
                                      LOLz. Was the 2.6 NW an HT variant, at least? Maybe the owner/builder figured they could get a cheap CPU and OC it with that mobo?
                                      While working at Microcenter some years back, I remember one of the lamest builds I had to put together - this person bought the most insane-expensive overclocking motherboard (had dip switches for every single voltage and clock imaginable - something not exactly typical at all for an Intel 7th gen i-series mobo) and the slowest-clocked and completely locked i5 CPU. It just made no sense why they wanted to put that build together. I don't recall what they had picked for the GPU, but it didn't match the build either. Whatever, the customer is always right, right?
                                      Nice work!
                                      Not sure if intentional, but I like how you matched the blue Nichi LFs to the PCB color of the mobo.
                                      Yellow Fujitsu "bumblebees" also look good on these older boards, BTW.
                                      I always find this to be the case with the "gamer" builds - always food and spilled drinks everywhere on the case... occasionally accompanied by excessive pet & human hair... and an over-the-top "aroma" of "air fresheners".
                                      Yeah, that's pretty bad... though I've seen a lot worse too.
                                      At least it's not "tar-dust" - household dust mixed with cigarette smoke.
                                      Actually, for some reason, I do like that smell - reminds me very fondly of the smell of internet cafes back in the late 90's and early 2000's.
                                      Actually, the thermal paste isn't/wasn't trash at all on these GPUs.
                                      The main problem is the heatsink size - it's way way WAY too small for the 80 Watts of heat that this GPU chip outputs. Come to think of it, that's more or less how much that 2.6 GHz Northwood outputs when maxxed out. Try putting the heatsink from this GPU onto the CPU and see how hot it runs. It will hit 70+ Celsius easily and settle around the lower range of 80 Celsius... which is a shame, because the heatsink on this 6800 Ultra has a very unique look/picture. But nVidia just couldn't be bothered to do better. Funny, though, they did make the VRAM's heatsink almost as big as the GPU's, and the VRAM isn't the one that's dissipating that much heat.
                                      If you have a spare Zalman VF-1000 heatsink or similar, that should do the trick here for this card... even if it does ruin the card's cool original look a little bit. Worth it, though - it's a 6800 Ultra.
                                      When you spin it by hand without it being powered, do you see it slow down instantly or does it rotate freely and slowly come to a stop, with a bit of wobble at the end? If the former, you might want to try switching it to machine oil. I've had problems with sleeve bearing fans starting when using grease for the lubricant. If that's not the case, maybe check/replace the fan's driver IC (if easy enough to take apart only, of course.) Or maybe one set of windings is open on the stator?
                                      Sweet!
                                      Looking forward to the pics/recapping.
                                      Hey, nothing wrong even with just 4x 256 MB modules for a total of 1 GB. Back then, 1 GB was considered "rich" and would run pretty much everything. I don't remember anyone having more than 1 GB back in those days. Most people were still on 512 MB in the XP era... and the few cheap bastards like myself on 256 MB
                                      WTFLOL?!??! These P4 CPU are now actually worth SOMETHING???!
                                      4-5 years ago, you could literally get a pound of them on eBay for about $5. Sure those were the "scrap" CPUs, meant for gold smelting and whatnot, which meant you'd get a bucket full of CPUs with bent pins and dirty with thermal compound. But you could find some "gems" that way.
                                      That's how I got my two 3.2 GHz P4 Prescotts. I plan on installing one in my current Optiplex 170L as a "retirement gift" ... though I might actually do that soon, just to get a little more use out of it. Not sure if the extra 400 MHz will net me much, though. The other is planned for an Optiplex GX270 build, since it has an AGP slot.
                                      Anyways, the only reason I bought one of these scrap CPU lots before was because I saw an A8-6600k CPU in it and wanted to build an FM2 PC. At the time, the A8 CPUs were going for quite a bit still, so I figured if I just fix the pins, I'd have a good working CPU. Unfortunately, that did not happen. Of all the CPUs that I got in that lot (mostly Pentium 4's, but also a few socket 462's), the A8 AMD CPU was the only one that -didn't- work. LOL.
                                      But I guess with these crazy prices for the P4 CPUs, that's OK. If I sell just one of them for $20, I'd have gotten all of my money back from that auction, plus some more.
                                      • Uranium-235
                                        Comrade Glimmer
                                        • Aug 2007
                                        • 5045
                                        • US
                                        I see Pentium 4's on ebay for basically nothing (sold items)
                                        I see Pentium D 965 Extreme editions put up for 500+ but not in any completed sales. I think I'll hang onto mine
