MacBook Air 820-00165 Monterey 12.1 bios
  • reformatt
    • Feb 2020
    • 1491
    Monterey 12.1 introduced a new EFI version which is V428.60.3.0.0. The dump attached here is from a board I recently repaired off eBay so I'm not concerned about the serial number ending up distributed to the rest of the world via your chip vendor.
    I have cleaned the ME of this dump, and tested it back on the board. It was a 2015 board, but this dump can also be used on any 165 board from 2015 to 2017. Clear the PRAM after installing it.
    If you plan on working with QFN8/WSON8 chips a lot for programming, I recommend getting one of the flip top sockets off Aliexpress. Just do a search for "QFN8 /WSON8/MLF8/MLP8/DFN8 TO DIP8 universal two-in-one socket/adapter for both 6*5MM and 8*6MM chips". There are more expensive ones, but this one does the job.
  • envym
    MacBook Pro 2018 with Activation Lock
    by envym
    Hi everyone!
    I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
    I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
    06-27-2025, 08:54 AM
  • Flasman90
    Macbook Pro DFU Restore Issues
    by Flasman90
    I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
    - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
    - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
    08-30-2025, 10:27 AM
  • tobeend
    Bypass mdm macbook m2 ventura
    by tobeend
    1. RESET MACOS WITH IPSW
    a. Power off MacBook, press and hold the power button to enter Recovery
    b. Open Disk Utility, remove Macintosh HD
    c. Reboot, connect to the network to Activate Mac.
    d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
    d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
    e. Release the other keys, but keep holding the Power key for another 10 seconds
    f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
    05-26-2023, 07:18 AM
  • SarcasticOP
    General question about MacBook power rails for repair.
    by SarcasticOP
    I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
    • PPBUS_G3H (12.6V-12.8V)
      • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
    • PP3V42_G3H (3.42V)
      • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
    • PPVRTC_G3H (3.3V)
      • This
    12-12-2024, 05:50 PM
  • obelix24
    A2941 Macbook air 15” - 5V 0a
    by obelix24
    I’m working on one macbook air 15” m2 that was water damaged.
    keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
    i’ve put macbook in shelf and order new screen so i can fully repair it.
    Now i got the screen and macbook stays at 5v 0a.
    i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
    i don’t have schematics so i don’t know where to start can someone help me?...
    03-27-2025, 01:19 PM
