Duratech TS-1574 hot air rework station - LCDs not working properly
  • Agent24
    I see dead caps
    • Oct 2007
    • 5037
    • New Zealand
    I recently got up a Duratech TS-1574 quite cheap. Originally from Jaycar no doubt
    They sold it apparently because the iron was not working, but this does not matter as I already have 3 other irons anyway (I think the heater is stuffed but not 100% sure)
    The real issues is that is seems the LCDs have issues - some segments not displaying properly (see attached photo)
    This is only apparent on the "set temperature" part, not the "current temperature" readout.
    Also, the backlight of the left display is much dimmer than the other, though this is hardly much of an issue...
    Has anyone heard of this happening before, or is there any likely issue to cause this in LCDs?
    -David VanHorn
    • 31198
    Re: Duratech TS-1574 hot air rework station - LCDs not working properly
    that stuff is also sold as "Duratool" and some other names,
    it's very good when it works, but the soldering isnt always the best.
    check the soldering.
    • Agent24
      I see dead caps
      • Oct 2007
      • 5037
      • New Zealand
      Dry joints you think? I guess it doesn't help that it was sitting around doing nothing for the last 6 months, I just discovered...
      -David VanHorn
        • 31198
        dry joints?
        more like crap joints!
        and dont dismiss the backlight issue - that's a big red flag that the power isnt getting where it should in that board!
        • Agent24
          I see dead caps
          • Oct 2007
          • 5037
          • New Zealand
          I've opened it up and took some photos of one of the control boards.
          I had to shrink the photos to attach them so the full size originals are on Flickr as well
          http://www.flickr.com/photos/agent_2...7624328897833/
          I don't really have much experience in spotting crappy soldering, but to me these seem to look OK.
          What do you think?
          -David VanHorn
          • Agent24
            I see dead caps
            • Oct 2007
            • 5037
            • New Zealand
            Also, checked voltage to the backlights: 3.04v on the good one and 2.96v on the bad. I'm guessing the light is either stuffed or there is something else wrong...
            -David VanHorn
            • smason
              • 1652
              Bad solder joints in a soldering station? That's like putting bad caps in an ESR meter.. Oh wait, that's been done...
              • Agent24
                I see dead caps
                • Oct 2007
                • 5037
                • New Zealand
                Looks like I missed what is probably a critical piece of information.
                When the iron or hot air is turned on, the LCD gets self-tested for about a second. During this time, all segments are turned on.
                On both LCDs, all segments are fine during this startup test. (can't believe I didn't notice this before!)
                I did try resoldering the connections on the LCD, but it didn't change anything.
                I guess the problem lies with the controller or LCD driver IC and\or connections rather than the LCD itself.
                What now?
                -David VanHorn
                  • 31198
                  well does it all work other than the lcd's?
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5037
                    • New Zealand
                    The hot air works, it certainly does get hotter as the temperature is increased via the controls at least. No idea if the temperature is accurate though.
                    If not the soldering or LCD itself, what's the next likely suspect?
                    Can't test the iron however. The station is supplying power but the iron doesn't heat up, and the heater which should measure a few ohms is infinite. I guess that fault explains itself!
                    There was something odd about the power though. At ZhongDi's website (I believe them to be the OEM), the iron (http://www.china-zhongdi.com/zd-912.htm) is described as being 24v AC.
                    Looking at the circuitry, the iron is powered from the 26v winding of the transformer, which goes straight to a bridge rectifier and gets switched with a MOSFET. The output when measured was DC.
                    Does the use of DC actually matter?
                    I found that I can get a new iron from somewhere like this: (http://www.komerci.de/shop/product_i...78&language=en) The price is good. Only problem, they won't ship to NZ!
                    -David VanHorn
                      • 31198
                      the iron is 24v but 30v dc wont harm it.
                      here is a test,
                      put a cigarette lighter under the tip and see if it registers the temp increase on the display.
                      you can use any 24v iron with a thermocouple just by changing the plug.
                      i like xytronics 60w irons.
                      • seanc
                        • Nov 2008
                        • 1319
                        I've one of these types of stations, only have the iron on mine, nice to know there's a few other 'brands' out there and that I can swap irons/tips.
                        Any tips for removing the beeper? It'll be OK without it surely...
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5037
                          • New Zealand
                          here is a test,
                          I tried multimeter across the thermocouple pins and heated the iron with the hot air gun, the resistance decreased. I think that's working, but the heater isn't (as I said, measures infinite resistance, or at least over 200Mohm, the limit of my meter.)
                          I thought of changing the plug but figured the thermocouple would be different and would result in an inaccurate temperature readout, I tried to find spare irons on eBay but could only find 50 Watt ones.
                          Any tips on finding a 60 Watt?
                          The beeper on mine is a little piezo thing on the control board behind the LCD. You would have to slide the backlight out from behind the LCD to get at the solder joints. I imagine just desoldering it would be OK.
                          -David VanHorn
                            • 31198
                            thermocouple isnt resistive, it generates volts.
                            try again - set your meter to read mv
                            do you have any xytronics dealers in NZ or close by?
                            as for a beeper - what does it do?
                            mine - the next model down, doesnt beep unless i press the buttons.
                            • seanc
                              • Nov 2008
                              • 1319
                              Mine beeps when I turn it on and press buttons. It's annoying if I'm pressing buttons late at night/early in the morning.
                                • 31198
                                ok, you can disconect it, or try different resistors inline to lower the volume.
                                • agronaught
                                  • Mar 2011
                                  • 1
                                  I know this is an old thread, but...
                                  I picked up one of the jaycar rework stations on the cheap and fixed the broken air tubing. While you do get what you pay for it's not bad for the price.
                                  There are parts available although mainly in the UK, and stocked by farnell (element14) over there.
                                  Jaycar product: TS1574 AKA ZD-912
                                  farnell: http://uk.farnell.com/duratool/d0067...360?Ntt=ZD-912
                                  element14 l have a number of spare parts listed, I haven't found any suppliers locally (.au) though.
                                  manufacturer: http://uk.farnell.com/duratool/d0067...360?Ntt=ZD-912
                                  I think I'll stock up on tips in case jaycar drop the line altogether, and save my pennies for a better system if/when this one dies.
                                  Cheers.
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 5037
                                    • New Zealand
                                    I know Farnell UK stock them, but it's useless because I tried contacting them and they said they wouldn't ship them because they weren't certified for use in New Zealand or some crap.
                                    The parts turn up on eBay from time to time, I might buy a new iron for it if I can justify the cost vs the fact I already have 3 irons which do work. Other problem is that the tip selection is pretty pathetic (again due to the above problem)
                                    Only reason I can see to get this one going is that it's rated for 60 watts while my (again Duratech) Hakko knockoff is 50 watts (supposedly)
                                    Though for desoldering capacitors a proper desoldering gun would probably be better, I see those are even higher power... 80 or 100 watts or so.
                                    -David VanHorn
                                    • shahnld
                                      wds-580 rework station issue
                                      by shahnld
                                      Good day.
                                      i received used bga rework station wds-580 which was not going above 300c despite the parameter was set to 350c, Everytime beeps at 300c so i did a factory reset and by mistake washed data and log etc. now the station boots to a white screen.
                                      Does anyone has a firmware for this station and want to share with me. i will really appreciate any help possible..
                                      kind regards...
                                      03-28-2024, 01:14 PM
                                    • minimania
                                      Need Schematic for jbc am6800 rework station
                                      by minimania
                                      hi all im looking for a Schematic for jbc am6800 rework station
                                      mine has stopped working fully
                                      it started with turning off when switched on then after a few off and ons it worked sort of for awhile
                                      now it wont turn on at all...
                                      01-28-2025, 03:44 PM
                                    • shahnld
                                      Seamark ZM-R6200 Rework station
                                      by shahnld
                                      Good day Experts.
                                      I have recently aquired a rework station SEAMARK ZM-R6800,. Is there anyone using this or some other similar station and give me some info about profile temp curve etc for removing leadfree soldered gpu chip..? just 1 profile will be enough to get started.
                                      Kind regards
                                      01-24-2024, 10:55 AM
                                    • petemanuk
                                      Help with IR6500 rework station
                                      by petemanuk
                                      I been playing with a recently acquired IR6500 rework station and watching lots of YouTube tutorials to see how to use it with not much success. I’ve only recently joined badcaps but going through the forums there is a lot of knowledge here, so though it best is if I ask my question here.
                                      1. Firstly is the IR6500 any good for BGA rework or should I be spending my money on a better one.
                                      2. The instruction manual is pretty useless on explaining how to set the PID loops (no information at all!!) both top and bottom heater for th Kp, Ki and Kd...
                                      10-14-2022, 12:31 AM
                                    • Peter_1402
                                      Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
                                      by Peter_1402
                                      Hi Everyone,
                                      I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
                                      1. Soldering iron works great
                                      2. There is a burnt mark on the hot air gun handle.
                                      I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
                                      Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
                                      Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
                                      Reed switch tested ok with a magnet.
                                      From the above test, I can conclude...
                                      07-12-2025, 11:50 AM
