Badcaps.net Forum
Go Back   Badcaps Forums > General Topics > General Capacitor Questions & Issues
Thread Tools Display Modes
Old 07-17-2012, 06:21 AM   #21
Uranium-235
Muffins
Uranium-235's Avatar
City & State: tehas
My Country: US
Line Voltage: 120VAC 60Hz
I'm a: Professional Tech
Default Re: Nichicon HM/HN/HZ scheduled for discontinuation
lots of power supplies have > 16V caps, and most polys have really low capacitance at such high voltages. This can throw things off on power supply type circuits
we don't have to find a certain brand series, just any series that is equivalent in specs (and reliability). This is why i'm making the cap database. zeerrrg let me ask you guys a question, is M ohm ohms / 100 or 1000
__________________
Uranium-235 is offline   Reply With Quote
Old 07-17-2012, 07:47 AM   #22
mariushm
City & State: Romania
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
M would be MEGA (one million) ... m would be milli
milli - a thousand
it's subdivisions of SI units ... 1 meter = 10 decimeters = 100 centimeters = 1000 millimeters
1 inch = ~ 2.54 cm
mariushm is offline   Reply With Quote
Old 07-17-2012, 09:14 AM   #23
PeteS in CA
PeteS in CA's Avatar
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
Quote:
No, HV is miniaturized HD ...
At my, now, previous employer I compared HD with HE for a very different usage than what folks here do. I was not impressed. Then again, I was subjecting the things to 7X-10X (not a typo!) the rated ripple current, not anything like P/S or VRM usage. Generally, Nichicon PW, PA & HE, Panasonic FC & FM, Rubycon ZL, and UCC LXZ and KZE series did best in my torture test. That was over 3 years ago, BTW.
__________________
PeteS in CA
Where might is right
There is no right.
- Sophocles in "Antigone"
All that is gold does not glitter,
Not all those who wander are lost;
- J.R.R. Tolkien, The Fellowship of the Ring
PeteS in CA is offline   Reply With Quote
Old 07-17-2012, 10:51 AM   #24
ben7
Capaholic
ben7's Avatar
City & State: Trenton, NJ
My Country: USA
Line Voltage: 240/120V 60Hz
I'm a: Hardcore Geek
Quote:
Did anything blowup in your torture test? And how did you torture them?
Its a shame that they are discontinuing them.
__________________
Muh-soggy-knee
ben7 is offline   Reply With Quote
Old 07-17-2012, 12:20 PM   #25
mockingbird
mockingbird's Avatar
Pete, are you sure you are recalling the results of your tests correctly??? HD should be precisely equal in spec to ZL, KZE and FM... I am very surprised at what you're saying. Are you suggesting that HD is a dud series??? I find this difficult to believe, as it has a proven track record.
I'm not familiar with Nichicon PA, it's probably a discontinued series, but PW is equivalent to Panasonic FC and UCC LXZ... These are refered to as "borderline" low-ESR caps... HE is a step up between HD/FM/ZL and and the borderline low-ESR series of caps... UCC has an equivalent series - "KY". These are both proven series with good track records, but not as impressive in spec as Nichicon HD!
__________________
...Their plight, in fact is even worse, they don't realize that they're cantonists, they think they're free men. What a slavery that is - to confuse slavery for light, and bitter darkness for bright light.
-Rabbi Menachem Mendel Schneersohn
mockingbird is offline   Reply With Quote
Old 07-17-2012, 01:06 PM   #26
RJARRRPCGP
City & State: North Springfield, Vermont
My Country: USA
Line Voltage: 118-127V 59-63.5 Hz-> actualizo: pérdido de voltaje
I'm a: Knowledge Seeker
Quote:
PA appears to not be discontinued. And it has lower ESR than PW.
But looks like the ESR is still too high for motherboards, at least for many motherboards.
__________________
MSI B450 Tomahawk
Ryzen 7 "Matisse" 3700X
16 GB Corsair Vengeance LPX DDR4 SDRAM
XFX Radeon RX 580 8 GB
eVGA Supernova G3 750W
Received on November 4, 2019:
MSI GF63 Thin 9SC-649US
"Don't eat yellow snow!" -Salem
RJARRRPCGP is offline   Reply With Quote
Old 07-17-2012, 01:20 PM   #27
mockingbird
You're right, I just pulled the spec sheet off their site.
It's very close to Nichicon HE:
6.3v 2200uF 10x25mm
Nichicon PA:1680 0.033
Nichicon HE:1650 0.042
Old 07-17-2012, 01:22 PM   #28
RJARRRPCGP
My Country: USA
6.3v 2200uF 10x25mm
Think the ESR is still too high for motherboards?
Old 07-17-2012, 01:28 PM   #29
mockingbird
Motherboard grade caps and regular low-ESR caps are in two completely different classes.
Ultra low-ESR caps have a unique electrolyte, there's probably some really expensive element in it that drastically changes and improves its properties compared to ordinary caps... Look at any ordinary cap and then look at it's motherboard-grade series equivalent. The ripple rating is often drastically higher and the ESR always far far lower, and all this with often significantly lesser dimensions!
Old 07-17-2012, 05:28 PM   #30
PeteS in CA
My memory is OK mm, though I appreciate your concer . The torture was the extreme ripple current at which I ran the things - 7-10X the rated ripple ccurrent, ~22 hours a day, 7 days a week until the things vented (or as happened with a couple of 12.5mm diameter parts, the lead wires fused). Evidently, when you go that far beyond the ripple current rating, the ESR is not the critical factor in how long they lasted. What is, I'm not sure. It's worth noting that all of the series that did well, relatively,nwere 5000 and 10000 hour rated series. Nichicon HD, UCC KZG and KZH, and Rubycon YXG and YXH did poorly.
Nichicon P* and H* series have different electrolyte types; ditto UCC LX* vs. KZ*; ditto Panasonic FC vs. FM. Rubycon is "all in" with the electrolyte type used in H*, KZ* and FM where low Z caps are concerned.
Old 07-17-2012, 05:33 PM   #31
PeteS in CA
If you need a useless fact to complete your day, there was a Nichicon PA series back ca. 1980. It was, for the time, a low ESR series, matching against UCC's RX series and Sprague's 672D series. The current PA series came out, IIRC, in 2008.
Old 07-17-2012, 08:44 PM   #32
mockingbird
Fascinating...
I'm not surprised with KZG and YXG/YXH. KZG is known to use an inadequate electrolyte and YXG/YXH have a mediocre spec. I'm curious about KZH but I'm seriously puzzled with HD which is spec for spec identical at least in classification to KZE yet you say KZE outlasted HD in the torture test. Care to speculate? Also, may I ask where you sourced your KZH? I've not seen that stocked anywhere (Or Nichicon PA for that matter).
Old 07-17-2012, 08:57 PM   #33
c_hegge
c_hegge's Avatar
City & State: North Coast, NSW
My Country: Australia
Line Voltage: 240V 50Hz
Quote:
Originally Posted by Shocker View Post
By the way, the table says you replaced the 220µF 16V RLS on the -12V with 330µF 6.3V SEPs.
That was a mistake. I have fixed it. If you look at the picture, you can see that the SEP next to the blue (-12V) wire is 16V
__________________
c_hegge is offline   Reply With Quote
Old 07-17-2012, 10:05 PM   #34
mariushm
Fascinating...
Keep in mind he's talking about particular tests, done with 7-10x the ripple the caps are rated for.
He's not talking about performance of the capacitors at the rated specs so you can't form an overall conclusion about them.
Old 07-18-2012, 10:02 AM   #35
TCKTMB
Here is what I got from my contact at Nichicon:
The main reason is that all our comp has already decided to discontinue water base series and now their customer are searching for another supplier
We will not accept orders in those 2 series . The only water base parts we will still manufacture HD and HE series.
Rick Massett
Nichicon (America) Corporation
TCKTMB is offline   Reply With Quote
Old 07-18-2012, 10:13 AM   #36
ratdude747
Black Sheep
ratdude747's Avatar
City & State: Madison, IN
My Country: USA
I hope this doesn't put Topcat out of buisiness. This really sucks.
__________________
(Insert witty quote here)
ratdude747 is offline   Reply With Quote
Old 07-18-2012, 11:55 AM   #37
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
My Country: United States
Line Voltage: 240V @ 60Hz
It's not looking good....but we'll see what transpires... I could always continue on with Panasonic from digikey or mouser....but I'd no longer be able to remain competitive....so yea, that's not a good choice either. Panasonic wouldn't even talk to me, I tried back when Rubycon dumped MBZ and MCZ.
__________________
<--- Badcaps.net Founder & Owner
Badcaps.net Services:
Premade Capacitor Kits
Badcaps.net Capacitor Master List
Motherboard Repair Services
If you've come here in search of replacement capacitors or repair services, please use the links above.
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is online now   Reply With Quote
Old 07-18-2012, 01:14 PM   #38
PeteS in CA
My employer at that time was a noticeable share of Nichicon's North American sales. We had Nichicon people coming to us from their main office in IL. Ditto for UCC. Rubycon had a local sales guy; Panasonic was rep'ed by a Mfr's Rep outfit. So, except for Panasonic, samples for my testing came directly from the companies.
TCKTMB's contact's info is less than clear to me. I wonder if the meaning is that MB mfrs and computer companies are switching to polymer caps. If that is what's happening, look for similar moves from UCC and Panasonic. And if that's what is happening, then people who do repairs on "older" equipment are going to be in some difficulty.
Old 07-18-2012, 01:34 PM   #39
Topcat
The Boss Stooge
Topcat's Avatar
FWIW, if this does kill off badcaps.net, it won't be for a while. I have a decent stash right now, and in conjunction with a good friend of mine, we're working to put in an emergency order before they stop production....just hoping they accept the order. April 2013 will be the official 10 year anniversary of Badcaps.net. The business was started in 2001, but I registered the domain name in April 2003. That's a pretty good run for any small business! ...and if the business dies or I sell it, fear not, the forum will ALWAYS remain!
Old 07-18-2012, 03:14 PM   #40
c_hegge
c_hegge's Avatar
@ Topcat, have you tried sourcing Sanyo/Suncon WG caps?
My concern with using Pannies from Digikey or Mouser is that they don't sell the FJ series (which is equivilant to Nich HM and Ruby MCZ), so they may not be a suitable replacement for all boards. In any case, though, you would still be competitive enough for international orders, as Digikey and mouser charge $50 or so for overseas shipping bs $8 from here.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
