Xbox One Power Issue
    Hoping to get some troubleshooting ideas from you all. Unless someone has had this problem before and knows the solution.
    The issue:
    I press the power button or eject button to turn on the unit. The xbox turns on and plays its start up chime then probably 1-2 seconds later the unit plays the chime again and turns off. It does this no matter how I turn the unit on.
    All the videos and issues I've seen online deal with the unit turning on but then just shutting off but without any noise, etc. Mine seems to be actually shutting itself down properly but only a couple seconds after turning it on.
    Any thoughts or troubleshoot ideas I could start doing to narrow down where the problem could be coming from?
    Re: Xbox One Power Issue
    Does the Cooling fan start?
      Woops! I forgot I poster on here.
      Yes, the fan actually starts up when I press the power button.
      It also will turn on for a split second when I first plug the console in. The light on the power supply turns white for a couple seconds, the fan spins up, then the light turns orange again. It'll do this like 3 times before turning completely off. Then I press the power button, fan spins up and a second or two later the console chimes off.
        Post some pictures of the board in the power supply
        Let see what you have
        9 PC LCD Monitor
        6 LCD Flat Screen TV
        1 Dell Mother Board
        15 Computer Power Supply
        All of these had CAPs POOF
          Have you found a solution to this problem. I have one with the exact same issue. I have tested so many components on the board it's not even funny.
            Take some pictures of the switching power supply the front and back of the board please make sure that the pictures can be enlarged and you can read the text
            9 PC LCD Monitor
            1 Dell Mother Board
              I have nearly the same issue but without any spinning of the fan. After the power on chime it has a white light for 5-6 seconds and then plays the off chime and turns off. In between hard drive spins and disc eject beeps.
