"HERMEI" e-cap in HP L1502 LCD Monitor
    There are 3 spoilt HP l1502 LCD monitors in my R&D office. It's been left at a corner for quite long time.
    Yesterday I tried to troublesoot the monitors and I found many bloated caps and a burnt zener diode. After I replaced all those faulty components, all three monitors are coming back to life !
    Re: "HERMEI" e-cap in HP L1502 LCD Monitor
    I woud replace every capacitor on that board,regardless of value except for the main filter on the primary side.Wow that zener is a toasty critter,also check any other diodes and and I noticed you have a regulator on the board also,once you have the power supply working again I would check the output, against the specs to make sure the reg is working properly.You can go to www.datasheet4u.com and put in the device number and get a pdf datasheet with the specs.Those are some nasty caps
      Identical layout and caps as a Dell 15" LCD I fixed. There must only be like 3 companies that make LCDs.
        Voltage regulator IC is fine, other diodes also OK. I believed it is the bloated "HERMEI" e-cap that caused the failure. High ripple voltage might have overloaded the zener diode.
          HERMEI caps are apparently known crap and used a lot with these types of monitors
          from posts Ive read...
          If you got anymore hanging around I rip them all down and recap...sounds like its only a matter of time.
          Cheers
          You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
            just fixed several hp like that.
            all the hermei caps were blown.
            they were purple.
              Yeah the same purple that Oscon uses.
              I found bunch of these in a Dell LCD monitor even though they were not bulged I replaced them with Pana FCs since I remembered reading about them.
              Whats with those weird turtle shell vents?
              The Hermeis on the Dell had standard X shaped vents.
                The same "power board 715L1034-1" circa October 2003 with potentially faulty HERMEI caps has been used in quite a few LCD monitors e.g. HP1502, Compaq FP15 & FP5315, Iyama PLE383, Dell ?, etc. I had the same problem as everybody else: see my post under "Compaq/HP FP15"
                Vince
                  Good to know.
                  Dead monitors come cheap!
                  Mann-Made Global Warming.
                  - Dr Seuss
                    Thanks for the pix and info- helped fix 5216b1hp board
                      i need schematic hp1502...
