Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Old 05-04-2019, 02:02 PM   #1
Quaddro
Tukang Kentu
Quaddro's Avatar
City & State: Yogyakarta
My Country: Indonesia
Line Voltage: 220VAC 60Hz
I'm a: Hobbyist Tech
Default Thermaltake 450 lite with burnt/exploded 5vsb ic
Hello everyone.
My friend gave me a dead power supply, thermaltake litepower 450 watt, with model number LT-450NL2NK.
after i open the case, i found a burnt IC in 5vsb area.
The problem is, i don't know what is the ic serial.
i tried to googled it, but i still can't found the same board type or OEM of this psu, so i cant found the type of burnt IC.
What is OEM this psu use?
And what is the type/serial of IC used in 5vsb?
Thanks alot.
Quaddro is offline   Reply With Quote
Old 05-05-2019, 09:08 AM   #2
R_J
City & State: ☻
My Country: Canada
Default Re: Thermaltake 450 lite with burnt/exploded 5vsb ic
Can you provide a better picture of the bottom of ic1? to be able to see the traces and components connected to the ic1
I am so far guessing it could be a OB5269CP
R_J is offline   Reply With Quote
Old 05-05-2019, 11:13 AM   #3
Quaddro
Tukang Kentu
Quaddro's Avatar
Hi, thanks for the response..
ok, this is the picture.
Old 05-05-2019, 01:33 PM   #4
Quaddro
Tukang Kentu
Quaddro's Avatar
Forget to include Product number..
This one is thermaltake litepower 450 watt with Product Number: W0423
Old 05-05-2019, 01:43 PM   #5
R_J
City & State: ☻
My Country: Canada
I guess it won't be OB5269CP, this ic uses an external mosfet.
Old 05-06-2019, 06:15 AM   #6
SoporteHR
City & State: Barquisimeto / Lara
My Country: Venezuela
Line Voltage: 110VAC 60Hz.
Hi, I have a Thermaltake TR2 600W
In the primary, use a TNY176PN 7-pin IV, maybe your source uses an equivalent.
SoporteHR is offline   Reply With Quote
Old 05-06-2019, 08:25 AM   #7
R_J
City & State: ☻
My Country: Canada
Its not a TNY176PN either, wrong pinout, I can find lots of ic's that its not but can't seem to find which one is used here,
It's also not a BH170A
Old 05-06-2019, 10:20 AM   #8
Quaddro
Tukang Kentu
Quaddro's Avatar
Yes, this one not TNY series. Because TNY using 7 pin.
What is the oem this psu using?
Usually thermaltake using solytech for their low end, but i think this one use atng, based on the type of heatsink.. idk.
The ic of mystery...
Old 05-06-2019, 10:46 AM   #9
R_J
City & State: ☻
My Country: Canada
What are the other ic's in the primary? and what is that one in the secondary? sometimes searching for known ic's might point towards a similar schematic that has the correct standby ic.
I see this 8 pin has pins 7 & 8 connected together and 3 & 4 connected together. sometimes these 8 pin ic's will have pin 7 but it is not used
Old 05-06-2019, 04:52 PM   #10
Quaddro
Tukang Kentu
Quaddro's Avatar
Hello..
There's no other ic in primary. Just that one.
And in secondary using Weltrend wt7525 as supervisor.
Old 05-07-2019, 09:07 PM   #11
leotron
City & State: Colonie
My Country: Offworld
Hello there, check for reviews in the internet for some information like these ones. Some of them have photos that you can see the IC or the resistor values, etc.
https://www.hardocp.com/article/2009...power_supply/3
https://www.hardwaresecrets.com/ther...supply-review/
Also I found this website that has a lot of ATX Diagrams. http://publikz.com/projects/atx/
Good luck
leotron is offline   Reply With Quote
Old 05-08-2019, 02:24 AM   #12
Quaddro
Tukang Kentu
Quaddro's Avatar
Good luck
Hello Mr. Leo, thanks for the response.
Unfortunately, the link that you given is based on fsp apfc machine.
So it's different than this one.
This thermaltake litepower 450, has the product number W0423.
The same board is shown in https://www.pbtech.co.nz/product/PSU...GEN-2-500W-OEM
and
https://www.newegg.com/Product/Produ...82E16817153279
But there's no review about this unit, so i still don't know about the5vsb ic
Old 05-08-2019, 06:04 PM   #13
leotron
It's OK, maybe you can write us down the other IC id numbers so we can use it to search on the web.
Old 05-09-2019, 05:30 AM   #14
Quaddro
Tukang Kentu
Quaddro's Avatar
The primary side only use single ic in 5vsb area.
The other ic is in secondary, weltrend wt7520 with the function as supervisor.
I'll try to draw some schematic for 5vsb section.
Maybe it'll help to determine the right ic.
Old 05-11-2019, 10:10 PM   #15
CapSwapper
City & State: CA
Thermaltake PSU's are crap. I just bought the 600w for $17 out of curiosity and its full of CrapXon capacitors. It even has CrapXon as the main primary. So much for "high quality components"
CapSwapper is offline   Reply With Quote
Old 05-12-2019, 12:56 AM   #16
Quaddro
Tukang Kentu
Quaddro's Avatar
yeah, especially this thermaltake lite. passive, ancient topology etc..
so much crap on one "international" brand.
but the goal is to fix something broken.
if i can fix it, well, will be a nice addition of my psus..
Old 05-12-2019, 03:15 AM   #17
stj
stj's Avatar
City & State: Europe
does the pinout match a TOPSWITCH or a Viper ??
stj is online now   Reply With Quote
Old 05-12-2019, 05:08 AM   #18
Dan81
SNES-powered
Dan81's Avatar
City & State: Romania
My Country: Bacau
Line Voltage: 230VAC 50Hz
The two Thermaltake PSUs I have are both CWT ISO platform (which I'm not even sure of how much it can do) and while one of them has TEAPO caps (which AFAIK are decent), the other is filled with Fuhjyyus.
So much for a PSU that not only wants to be "cool" but also power a beefier GPU w/ 6pin connector (both have 1x 6-pin 12V plugs)
Main rig:
Gigabyte B75M-D3H
Core i5-3470 3.60GHz
16GB DDR3-1600
Samsung SH-224AB DVD-RW
Delux MG760 case
Dan81 is offline   Reply With Quote
Old 05-12-2019, 11:17 AM   #19
Quaddro
Tukang Kentu
Quaddro's Avatar
i've already make a simple drawing about the connection of the ic with the other components.
Maybe it can help to find out about this ic serial id.
Old 05-12-2019, 12:06 PM   #20
R_J
City & State: ☻
My Country: Canada
Its close, pins 7&8 connect directly to the transformer primary, the diode is in series with the [cap. across the resistor] and are connected across the primary of the transformer.
D1 anode comes from the transformer run winding and the cathode connets to R3? (10Ω) to pin 2 (C1 or is it C3?) connects from pin 2 to ground
