Hello All,
I got a four year old P31 Neo V2 equipped with TK, Ost, G-Luxon and one Teapo. By now 16 out of 19 of the small TK ATWY 1000uF 6,3V TK caps have bulged.
The problem is, I cant manage to find any datasheet mentioning these. This one is all I found. But, the caps MSI used here are 8mm in diameter and I would guess 11,5mm high. What would you suggest to use as replacement?
I guess it would be wise to change the other TKs aswell. They are in primary CPU VRM and primary aswell for RAM, I think. What would you do with the shiny cyan Ost near the CPU and the 8mm G-Luxons for USB 5V?
I wonder if it will be worth it, probably not if I had to change just every singe cap on that board. The PC is on light, only private use and decently cooled. So these TKs really could not stand anything. Who knows they would have gone awry if stored in a warehouse, aswell.
Here is the complete List for MS-7392 Ver. 1.2
19x - TK ATWY 1000uF 6,3V 8mm/11,5mm - everywhere
7x - TK ATWB 1000uF 16V 8mm/20mm - VRM
11x - Ost RLA 680uF 4V 8mm/9mm - CPU VRM sec.
4x - G-Luxon LU? 470uF 10V 8mm/11,5 or 12mm - USB
1x - Teapo SZ 470uF 16V 8mm/11mm - near PCIe 16x
1x - Ost RLG 470uF 10V 6,3mm/11mm - above Southbrigde
Any ideas, suggestions and datasheets are very welcome.
Cheers, A.
Cheers, A.
