Those are for Windows installs I need a self-boot program.
Anyway I think that's not the problem. Moved the drive to the secondary port and managed a full install of Ubuntu but of course it won't boot from there. Loaded up the Live CD again and when I went back to it shortly thereafter the laptop was off. Loaded live-boot Memtest and came back 15min later and again laptop was off.
Something is seriously screwy, maybe one of the bga's needs a reflow/reball ??
you should be able to set he bootdrive in the bios.
unless it's one of thoe half-ass INSYDious ones.
Ya the boot order is very simple and does not specify booting from Primary or Secondary.
I believe this was formatted as one partition originally.
I do remember now what happened last time I messed with this. The drive was not seen by the system so I moved it to the secondary bay and that allowed me to install Win7 to it but it wouldn't boot from there. Moving the drive back to the Primary bay gives the "No OS Found" message.
Gonna mess a little more with this in a bit.
The point of deleting and formating all partitions is not to have the whole drive as one partition, but to remove any left over bootloader files.
Update: removed the ssd from the system and still could not boot the Ubuntu Live CD fully. By that I mean I get to the desktop but soon after the system freezes and becomes unresponsive.
To rule out ram I used two pieces (3gb) from another lappie which is running the live cd fine. No change.
But dig this. I downloaded Lubuntu for another older pc I have and tried that out on the dv9000. Works like a champ !
I would think the Nvidia driver is the same for Ubuntu and Lubuntu but can't be sure. What do you think ?
God damn I just had an epiphany !! I would bet my left arm the system doesn't have enough memory allocated to the gpu in the bios. I will try that in the morning!!
As for the ssd I'm about ready to fire that out the fucking window.
^ both use the same driver, nouveau. unity was always crappy with lower end, or older graphics. what SSD? my compaq CQ57 wouldn't work with an OCZ, but it worked fine with a sammy evo pro.
Have you tried using something like hiren's boot cd to windows?
It has a lot of usefull tools that can get your os to boot.
First try restoring the BOOTMGR and the NTLDR. If that doesn't work try changing the active partitions. And if all else fails why not try installing windows from another pc, then install the chipset and sata drivers or if they can't install just place them in the windows drivers folder with some live os from hirens boot cd of through another computer.
P.S. One of the tools in the live cd had an option to force boot a drive, but I don't remember which one and I don't have it with me right now to check. :P
I am going to keep working at it. I'm not trying to recover anything just trying to get a fresh install to boot from the primary hard drive bay. Should be a nno brainer but it's not.
