I have a xfx GF 6800 XT DDR3 video card with bad caps on it. The ones bad to the eye are EVERCON CAPS 1500uf 6.3v E63A (blue and gold in color). Does anyone know where I can get theis caps without having to buy hundreds of them?
Where to get EVERCON CAPS 1500uf 6.3v E63A
Re: Where to get EVERCON CAPS 1500uf 6.3v E63A
Hi Deland
Welcome to the Forum!
You probably don't want to use Evercon branded caps again. Ever.
To recommend a suitable replacement, you will need to know:
Capacity: (1500uf)
Voltage: (6.3v)
Brand: (Evercon)
Dimensions: (???) (usually diameter and length in mm will do)
Series: (???) usually a 2 or 3 letter code like LE, LA, etc
If you don't know the Series, Impedance (or ESR) and/or Ripple Current
Whether is is a Radial capacitor with wires attached or a Surface Mounted Device (SMD)
Whether is is an Electrolytic or Polymer cap. (Polymers are the metal ones with writing on top, not on the side)
The Date Code (E63A?) isn't that important.
Have fun!
KeriThe More You Learn The Less You Know!
Look on the other side of the cap for the series number as Keri suggested.
These are very short caps, correct? If the pix out there are correct, then these are radial, through hole mount.
We're a bunch of voyeurs, so pics are always appreciated.
Everson's site: http://www.evercon.com.tw/
Toastveritas odium parit
>>Lol - Evercon are another incarnation of GSC.<<
...and (probably) Sacon and Capsun
Big Pope's site reported: www.capsmod.net/forum/viewthread.php?tid=109veritas odium parit
