Yes, this is the weirdest ive ever seen. Taken from a CD player. Just nice and compact with not much components.
First it has no power. Dismantled the unit, unplugged everything and tested the power supply on its own. While the power plugged, hearing a ticking sound on the switching transformer. Tested the port for 12V, only 5V was showing.
OK, i replaced all the electrolytic caps and ceramic caps, NO GO
Swapped the N channel transistor. Still NO GO
Soldered all the joints, NO GO
Tested all the normal diodes and SMD diodes, all gives good reading, none shot
But the thing is, all of a sudden after switched off for sometime and switch on the unit again, it will work providing solid 12V and there wont be any ticking sound and the entire set works fine . Then when you switch it off and switch on again after a while, the ticking sound will start doesn't matter with load or without load. Anyone had this issue before?
All other boards on the player is fine, the power supply is faulty on its own as it gives the ticking sound without anything plugged in to other boards.
