I'm working on this cheapo Magnavox LCD, and I was wondering if anybody had any troubleshooting pointers. What happens is that when anyone tries to turn it on, the red light blinks, the screen turns on, and the splash screen appears, but then it turns off. Nothing looks obviously bad on the power supply board or mainboard. Any ideas?
Magnavox 46ME313V/F7 LCD shuts off immediately after displaying splash screen
Re: Magnavox 46ME313V/F7 LCD shuts off immediately after displaying splash screen
I had the exact same problem with an 50" emerson that uses same pcb board (BA4GU5G0201 3), after trying power board from another set, and disassembling the screen to check for bad leds I took a chance and ordered in a mainboard from a 40" magnavox that looked the same and had the same pcb model number, same plugs, etc just different part number on the stickers for 20$ on ebay(the right board was 70$ which was more than i was willing to spend) and other than needing a magnavox remote control now it worked great. So I'd say your problem is mainboard also.
The quest for cheaper repairs
Originally posted by cyricdark View PostI had the exact same problem with an 50" emerson that uses same pcb board (BA4GU5G0201 3), after trying power board from another set, and disassembling the screen to check for bad leds I took a chance and ordered in a mainboard from a 40" magnavox that looked the same and had the same pcb model number, same plugs, etc just different part number on the stickers for 20$ on ebay(the right board was 70$ which was more than i was willing to spend) and other than needing a magnavox remote control now it worked great. So I'd say your problem is mainboard also.
you would be better seeing what is putting it into protection and shutting it down .
it could be almost anything if indeed is protecting itself .might just be a bad solder joint maybe not . few voltage checks should get you on the way if you are up for that sort of thing ?
most likely a capacitor not charging fast enough because its no longer good .
voltage checks should be a big help . no use guessing unless its a well proven fault with a certain boardLast edited by petehall347; 01-11-2017, 06:47 PM.
just a little progress...
After finally getting a working board, I'm having slightly better luck with this thing, but not much. It now boots past the splash screen and shows the channel number in the corner, but then immediately shuts off after that.
I get a fairly low-res Emerson emblem followed by the channel number in the corner before it calls things quits. Any ideas as to what else might be ailing this sorry thing?
Re: Looking for protection jumpers
Originally posted by SurrealMustard View PostWhere would those be located?Never stop learning
Check the DCV on those jumpers when TV is OFF, black probe on chassis and leave the red probe on one of the jumper and turn on the TV and see what you get then wait a few seconds to see if reading changes, do the same for another PROTECT jumper.Never stop learning
Results!
Originally posted by budm View PostCheck the DCV on those jumpers when TV is OFF, black probe on chassis and leave the red probe on one of the jumper and turn on the TV and see what you get then wait a few seconds to see if reading changes, do the same for another PROTECT jumper.
PROTECT3 measures .1volt while it is booting up and displaying the splash screen, then jumps to .5volt (or so) for a fraction of a second as it shuts off. After the television shuts off, PROTECT3 drops to zero.
PROTECT1 registers absolutely nothing at any time.
Is that normal behavior?
Originally posted by Andrew F. Ali View PostCheck the DC voltage....I suspect a Backlight fault, though
best way forward?
If it makes any difference, I tested this with the backlights disconnected and got the same symptoms, (sans backlights, of course) if that makes any difference.
Based on these findings and the aforementioned measurements, what would be the best way forward with this? Just dive in and check the backlights?
Tested lamps.
Well, I finally broke down and tore this thing apart. Turns out that there is some kind of issue with backlights not lighting up. The weird thing, however, is that after testing each lamp in the middle row individually with the multimeter, I found that they all light up and work. Does this mean that I've got a bad power supply?
No voltage at middle string
Originally posted by CapLeaker View Postagain, fire the PSU up and measure the DC voltage of each back light string on the connector at the PSU with the LED's connected.
On this TV PSU, each string has its own control ic, etc. IC1301, IC1201 and IC1101. Each has its own circuitry to control one string each. Now you have to find out which circuit isn't working. I am guessing the one with IC1201 since it is the middle one, but you have to verify that.
What part numbers does IC1201, Q1201 and Q1202 have? Check D1202 Q1201 and Q1202 for a short.
