Hello. Have this Asus X55ld that have not working touchpad. dont have schematic or boardview so anybody know where to start searching for fault?
Asus x555LD touchpad not working
Re: Asus x555LD touchpad not working
Did you check in control panel if its enabled
Does it show up in device manager
I had Asus where guy was using aftermarket charger and in that case was trackpad issueLast edited by Jesse James; 04-02-2019, 02:43 PM.
first download the boardview from this thread:
https://www.badcaps.net/forum/showthread.php?t=60549
then, follow the procedure mentioned in this thread to find the cause of the problem:
https://www.badcaps.net/forum/showthread.php?t=75720
DRIVERS! I had same problem, trackpad wont work. Bugged drivers or something windows related.
Uninstall drivers from device manager and remove trackpad software. Restart PC, it should install generic drivers.
this asus notebook is total garbage. GT820M throttles with fresh thermal paste. Trackpad problems. Stupid motherboard design.
Originally posted by ktmmotocross View Posthave spare flex. little longer but same wide.
grounding tape?Last edited by SMDFlea; 04-08-2019, 04:19 AM.
Originally posted by ktmmotocross View Postsolder a wire from big ground pad to gnd of board but nothing changed
Originally posted by ktmmotocross View Postno, dont have
Try booting latest hirens CD with linux or mini windows 7/10, they should have generic drivers. To test if it's windows/drivers problem.
because in my case it was exactly it - Drivers.
