Re: Testing a transformer
We have to determine why the fuse blew...
Step 1
Replaced fuse. Plugging in board blows fuse F201. Replace fuse and Go to Step 1B
Set VOM Multimeter to 2k OHM scale:
Step 1B
Resistance on Diode Bridge BD201 (2KBP06M):
1-2, 1-3, 1-4, 2-3, 2-4, 3-4 (Pin 4 is at the top, Pin 1 at the bottom, 3-prong socket facing me)
(Red <+> lead on lower pin number, OHMs) 1.03k,0.0,958,open,1.05k, 953
(Black <-> lead on lower pin number, OHMs) open, 0.0, open, 1.02k, open, open
Pins 1-3 are shorted.
Step 2.
Resistance of Power FET Q201 (Reads B 644 / FQP / 8N60C, a FPQ8N60C?)
1-2, 1-3, 2-3. (Pin 2 is across the slot from the other two pins)
(Red <+> lead on lower pin number, OHMs) open, 1.96k, open
(Black <-> lead on lower pin number, OHMs) open, 1.09k, 945
Q201 is OK
Step 1B1. Electrical continuity check. Set VOM Multimeter to audible or an OHM scale:
Trace each flat prong to Pin 3 of diode bridge BD201
OK left side, OK right side.
Need for BD201 replacement at the very least.
Thank you. This gives me hope for repairing this monitor. Sorry for the delay in answering. Should I obtain any other component?
Step 1
Step 1B
Step 2.
Q201 is OK
