samsung ue55ju6800 problem with brightness
    Re: samsung ue55ju6800 problem with brightness
    According to SJ, the LCD panel is backlit, but since we do not have any pictures form OP, we cannot verify if that is true or not. Based on OP pictures, it looks like one set of the LED string is not driven the same as the other set of the LED string.
    https://www.shopjimmy.com/samsung-bn...ght-strips.htm
    https://www.shopjimmy.com/catalogsea...ung+ue55ju6800
    • budwich
      • Jul 2015
      • 3097
      my "poor search" and "untrusted site"... shame on me...
      I followed this:
      https://www.displayspecifications.com/en/model/9db6434
      • jjanssen7
        • Nov 2012
        • 252
        This is fun, diagnosing his set without him being here! I'll weigh in again if I get another unit with this symptom.
        • george_gpu
          • Dec 2015
          • 77
          • greece
          good day
          wait for me , i will post new pictures
          • george_gpu
            • Dec 2015
            • 77
            • greece
            Good afternoon
            Sorry for delay reply
            I take some photos
            As you see from power supply to red connector(led bar) i have in first grey cable 310volt ,second gray 100volt and 3 grey 290 volt is that allright?
            • budwich
              • Jul 2015
              • 3097
              I think you need to measure across the "+" to "-" as labeled... those are "driving pairs" for the backlights.
                Your TV has two LED driver circuits, and two LED strings.
                https://www.badcaps.net/forum/attach...4&d=1564065956
                https://www.badcaps.net/forum/attach...7&d=1564065956
                Do you see the two resistors (R9167, 9169) by the LED connector? As you can see, they are labeled for using as the test point, so with the TV turned off, keep the DC Volt meter probes (polarity does not matter if you use DMM) on the two legs of R9167 then turn on the TV while watching the meter and then wait 10 seconds to see what the Voltage changes to, repeat the same test on R9169.
                https://www.shopjimmy.com/samsung-bn...-led-board.htm
                • Diah
                  • Feb 2013
                  • 6614
                  Originally posted by budwich
                  gamma chip problem... Maybe.
                  +10
                  from his photos the darkness straight its tell not LED issue
                  https://www.badcaps.net/forum/showpo...43&postcount=3
                  • nomoresonys
                    • 12323
                    • U.S.
                    #29
                    Ok, so do test in post 27, will it be another 2 weeks before your next post?
                    • R_J
                      • Jun 2012
                      • 9631
                      I would say it is the top led srtring is bad, either bad connection from the horizontal led strip to the vertical distribution strip or intermitint led on the top strip.
                      You said the fault is intermintint, so try tapping the rear (metal) of the panel where the upper strip is attached.
                      • budwich
                        • Jul 2015
                        • 3097
                        I am having trouble understanding how this problem could be a backlight issue. You indicate that the panel has only two strings.... so "basic math" would indicate that half the screen would be in trouble. Yet look at the first pictures that the OP posted. It is at best 1/3 of a screen... maybe even 1/4. I don't see how that relates to one of two strings being in trouble.
                        • R_J
                          • Jun 2012
                          • 9631
                          There are 18 strips in the panel (according to SJ) There are 2 connected together to form 1 horizontal strip. Each of the 9 strips are connected to 1 vertical connector strip. If one strip is going out it may not trigger an error to shut down the backlight.
                          I could be wrong but I don't see how any other board would cause this fault
                          It looks like one string is 4 strips (168v) and one string is 5 strips (210v)
                          The power supply lists (2D) 227v & 182v for each string
                          It should be easy to check the voltage across the string when it is working and not working
                            https://www.badcaps.net/forum/attach...5&d=1562666779
                            It looks like some of the LEDs are shorted out, especially at the top right corner you see dark section compared to the top left corner of the screen.
                            Checking the Voltage on the resistors will give us a clue but it may take another 2 weeks to find out from OP.
                            Most of the time they will arrange the LED strips in alternate rows, I.E. LED ROW 1, 3, and 5 may be driven by LED driver #1, row 2, 4, and 6 may be driven by LED driver #2.
                            • george_gpu
                              • Dec 2015
                              • 77
                              • greece
                              #34
                              Thanks all for your answer
                              I measure 2 resistors monday morning and i tell you
                              • george_gpu
                                • Dec 2015
                                • 77
                                • greece
                                #35
                                Good day
                                i measure dc voltage in 2 resistors , only r9169 has 0,0036 volt ( r 9167 no dc voltage)
                                i measure right this time the cnl802 connector ( from power supply to led bar connection in panel) i have 220 volt in 3 greys (+)
                                i notice 2 led bars up in monitor has low brigthtness
                                • george_gpu
                                  • Dec 2015
                                  • 77
                                  • greece
                                  #36
                                  See photo
                                    Originally posted by george_gpu
                                    Good day
                                    1) R9169 is connected in series with LED string #2, R9167 is connected in series with LED string #1, you indicated 0V reading on R9167 which means there is no current flow through LED string #1.
                                    2) You indicated all 3 grey wires (+) have 220V on each one, but if you look at the pin names of the LED connectors, there are only TWO + pins, 1+ (pin 9) and 2+ (pin 1). 1- is pin 13), 2- is pin 5.
                                    So based on your measurement, are you 100% sure that your measurements are correct?
                                    See attached picture.
                                    • george_gpu
                                      • Dec 2015
                                      • 77
                                      • greece
                                      #38
                                      good day
                                      i remove panel
                                      i measure led bars
                                      i have in 3 up bars many fault leds
                                      can you send me the type (is :bn96-38486a) for order
                                        good day
                                        i remove panel
                                        i measure led bars
                                        What do you mean "Can you send me the type (is :bn96-38486a) for order"? You cannot buy the set of the replacement LED strips?
                                        BTW, can we see the pictures of the panel showing the LED strips?
                                        • george_gpu
                                          • Dec 2015
                                          • 77
                                          • greece
                                          #40
                                          I have 40 burn leds
                                          • THXFX
                                            samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
                                            by THXFX
                                            Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
                                            I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
                                            When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
                                            What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
                                            I check capacitors and diodes and didn't find any short IN MAINBOARD.
                                            Measured all power supply...
                                            03-20-2024, 03:21 AM
                                            09-07-2024, 05:50 AM
                                          • howardc64
                                            Samsung UN55JU650DF network/streaming problem
                                            by howardc64
                                            Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                            This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                            07-09-2025, 12:44 PM
                                          • alro7779
                                            Samsung UN55MU6103F video problem; has colored stripes on the display
                                            by alro7779
                                            Hello, everyone!
                                            A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                            09-27-2025, 11:29 PM
                                            09-06-2024, 11:40 PM
