Samsung LCD TV LN40B530P7N Distorted Color Picture
    Re: Samsung LCD TV LN40B530P7N Distorted Color Picture
    http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
    • Glitcher
      • Mar 2013
      • 673
      • USa
      Ah I always hated buying parts from china. Also found this one, I don't mind spending an extra $7 for a little faster shipping though. These ones will work too right?
      http://www.ebay.com/itm/5-PCS-E-CMOS...item20d3489874
        They look fine.
        Bear in mind all US sellers are doing is buying them from China. The only difference is better service and support.
        Practice removing ICs like that on dead motherboards, soundcards etc before moving to the T-con board.
        • Glitcher
          • Mar 2013
          • 673
          • USa
          I have a hot air gun, would it be easier to remove that way?
            Hot air works good; cover all but the IC you want to remove with foil. Before replacing the IC clean the pads with solder wick and use plenty of flux when putting the new IC on. The heat pad in the middle is important. Use a tiny bit of solder paste on the PCB (use the same amount as you would use for a CPU heatsink, if the CPU heatsink were as small as the pad.) Solder paste is very slightly adhesive, so you can use it to help you hold down the chip. Solder four corners, then flood all the pins and wick up the excess. Then heat the IC with a hot air gun (limit 300°C) for about a minute on the bottom of the board to solder the heatpad. With practice I am able to do one of those chips (generally, not simply on T-con) in about 10 minutes.
            • Glitcher
              • Mar 2013
              • 673
              • USa
              #26
              Looks like I got the hard part, I was able to remove the IC successfully! At first I thought I ripped off a couple of traces but it was just the really dried up solder. Hopefully I didn't overheat anything that was near around it too much (even with the foil) that's the only concern I have. It doesn't have the heatpad in the middle so it should be easier to replace with a new one. Time to order the new one.
                The pads look perfect to me.
                Looks like the reason these gamma chip may be dying is due to the lack of heat pad. The chip itself has one; they haven't used it so it will run a lot hotter. Like running a CPU without a heatsink, the lifetime is much shorter. I recommend adding a small heatsink to the IC after this repair as this is the case. For example:
                http://www.ebay.co.uk/itm/Aluminium-...item232b590605
                • Glitcher
                  • Mar 2013
                  • 673
                  • USa
                  #28
                  Since the other chips have those rubber pieces on them that also attaches to the metal plate which covers the entire tcon, should I put one of those on the gamma chip for the heat to transfer to the metal plate? Not sure if I would be able to screw on the metal plate if there was a heatsink on.
                    That could work too. I forgot about the shield.
                    • kevinm34232
                      • May 2012
                      • 1884
                      I use the foam thermal pad on these too..
                      For reinstall of new chip here's what I do.. clean get the pads good and clean with flux and alcohol and qtips. Then apply liberal amount of paste flux to pads. Place new chip on board and align very carefully.
                      I use a 1/32" chisel tip and .015" solder and tin the tip of the iron and do the corners first, then hit each pin after. You can use an exacto knife to make sure there are no bridges between pins.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        Sorry guys that I'm mixing threads here, but I have almost the same isue with almost the same T-con board but it's a Sony TV.
                        Tom, do you think that I could do this 20 pin measurements on mine also?
                        What should be the result? Voltages keep increasing in one way?
                        https://www.badcaps.net/forum/showthread.php?t=28407
                        Post #19 is the T-con picture.
                        On mine, I have replaced this IC and it didn't change a thing. Now I'm getting the second mainboard(first one didn't change anything) and I will see what happens.
                        • Glitcher
                          • Mar 2013
                          • 673
                          • USa
                          #32
                          The picture looks a bit different then mine. It looks more like when I was messing with the LVDS format, See post #3 in the third photo. Don't know if its the same problem, on mine it seems more to a negative or inverted colored picture.
                          What are the measurements from pads 1 and 20? On mine it was decreasing as it went from pads 1 to 20, but there was a spike where the voltage jumped up once (showing that the gamma IC chip may be bad). If it only decreased in a constant fashion then, that chip probably isn't at fault.
                            Yes, your problem is different. You are welcome to try measuring the voltages, but you will probably find that the IC is perfect.
                            • Glitcher
                              • Mar 2013
                              • 673
                              • USa
                              #34
                              Just got the IC's in today, when I solder them on the little circle on the chip is suppose to match with the arrow on the board correct?
                                Yes; also it should line up on one side with pin 1 (only one side will work!)
                                • Glitcher
                                  • Mar 2013
                                  • 673
                                  • USa
                                  #36
                                  Finished it up! plugged everything back in and it works! =D
                                  • johnboy1313
                                    • Nov 2012
                                    • 1959
                                    Awesome. Good job.
                                      Nice one!
                                      Any chance you could log the new gamma voltages for future reference?
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        Nice!
                                        Why I can't be that lucky as you?
                                        • Glitcher
                                          • Mar 2013
                                          • 673
                                          • USa
                                          #40
                                          Originally posted by tom66
                                          Nice one!
                                          Ahh I would but I already screwed everything back together =(
                                          • ChattFix
                                            Samsung UN55TU700DFXZA Distorted Picture
                                            by ChattFix
                                            I have a Samsung UN55TU700DFXZA with a distorted picture and I thought it was a bad panel. I had a similar board with one number off and still tried it to see what the issue could be. The picture came out clear with only missing blue hue I think. I found a replacement board for $30 but wanted to learn if this would be the main IC or possibly something else. I don't have service manual so looking to learn about these cheap sets....
                                            06-02-2024, 03:50 PM
                                            09-07-2024, 05:50 AM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • JJAAMM
                                            by JJAAMM
                                            Problem
                                            07-06-2023, 06:01 AM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
