ASUS n61Jq bios dump needed
  • magnetepazzo
    • Feb 2017
    • 85
    • italy
    ASUS n61Jq bios dump needed thanks
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: ASUS n61Jq bios dump needed
    Here it is. Just try it. I am not sure whether it works or not.
    • magnetepazzo
      • Feb 2017
      • 85
      • italy
      thankyou bro
        • 21219
        N61jq me_clean
        • elakhes
          • Nov 2015
          • 5
          • turkish
          thanks
          • coder78
            • Aug 2015
            • 67
            • turkey
            thanks
            • Kingtonino
              • Apr 2021
              • Italia
              It works, thank you
              • ricoleal
                • Oct 2012
                • 9
                • Portugal
                • kodox
                  Asus ExpertBook B1400CB Bios Dump Needed
                  by kodox
                  need original bios dump, original bios has flashed by other technician before me.
                  attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                  unit info:
                  Model: Asus ExpertBook B1400CBA-0711A1235U
                  S/N: R6NXNZ006657238
                  CN: 7F6F
                  Mainboard Code: B1500CBA R2.1...
                  08-16-2025, 12:20 PM
                • DynaxSC
                  by DynaxSC
                  06-14-2024, 03:49 PM
                • DynaxSC
                  by DynaxSC
                  11-17-2023, 10:56 AM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • TacticalFahrrad
                  [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                  by TacticalFahrrad
                  I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                  BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                  I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                  06-30-2025, 04:09 AM
