I have the above mentioned receiver RCA RT2770.
There is a Grey Axial (resistor?) or whatever that is next to the Large transformer on the board the bands are scratched off from someone trying to pull the thing off the board is there anyway that I can figure out its rating so I can find a new one to replace it?
Or does someone have this receiver that could tell me the color of the bands on this (resistor?) This is a tough one folks I wish I knew I would get an accurate reading...
Any help would be helpful I'm really unable to determine I can make out some of the lines as follows:
Red at the bottom and the next is a thicker white line then nothing and at the top it looks to be black...
Marking on the board says R202 by the way which a quick google search turned up 3.3k 1/4 watt but I believe the R202 marking does not note what the rating of the resistor is if I am correct if it does that would solve a ton of learning issues with electronics off the bat.
). Would that work in place of the burnt one of the other board?
