Vestel based 16" LCD: PSU ticking
  • bbjunkie
    • Dec 2011
    • 301
    Not been able to figure this one, it's basically a Vestel TV (both power and AV boards) with CHI MEI LCD panel. PSU board is 17ips16-3
    Have found the following symptoms:
    Standby LED flashing at approx 1hz and very quiet ticking that sounds like it's coming from the primary side of the PSU and in time with the standby LED flashing.
    With everything disconnected from the PSU this noise is still there.
    Checked caps on both primary and secondary side, all seemed ok -
    Mains filter caps 18uF 400v both reading 17uF one with 1.6 ohms ESR and one with 1.7 ohms ESR
    302VDC across the filter caps (a pair in parallel)
    Startup cap 33uF 50V reading 31uF with an ESR of 0.6 Ohms
    Charge resistor 96K ohms in circuit (is this a bit low - should I pull it and check?)
    Current sense resistor ~ 1 Ohm in circuit
    Q802 chopper transistor is recognised properly by the DCA55 tester so assume it is ok.
    303.2VDC at centre pin (Drain) of chopper transistor
    D810 not shorted, forward voltage of approx 0.45v measured with DMM
    D815 D817 and D818 not shorted, forward voltage of 0.25v with DCA55 tester
    SMPS transformer (details shown below)
    30065656
    SMP-C2331
    Primary (Pin4 NC)
    1-2 1.3 Ohms
    1-3 0.L
    1-5 O.L
    2-3 O.L
    2-5 O.L
    3-5 1.4 Ohms
    Secondary
    1-2 0.6 Ohms
    1-3 O.L
    1-4 O.L
    1-5 O.L
    2-3 O.L
    2-4 O.L
    2-5 O.L
    3-4 O.L
    3-5 0.6 Ohms
    4-5 O.L
    No sign of a short on the PSU at the transformer secondary pads with transformer out of circuit.
    All component tests done out of circuit unless stated otherwise.
    (DMM leads connected together show 0.6 ohms)
    Pics of primary side attached, can post others if needed.
    Re: Vestel based 16" LCD: PSU ticking
    Of these snubber components (RCD clamp), are any failed?
    If none are, my bets are on the tiny 6-pin SMPS controller.
      Also check D608 (D808?) on bottom of the board and the three SMD resistors near it.
      • bbjunkie
        • Dec 2011
        • 301
        D808 has a forward voltage drop of 0.488v the three SMD resistors are checking at 50 ohms each which ties up as they are 150 ohms each and in parallel. All those were measured in circuit
        C852 marked 101 measures 200pf
        C873 measures 4.7nf
        Both cap tests done out of circui
        The diode on the left side of the circle is D810 already checked above.
          Schematic: http://www.4shared.com/office/YtDotRyO/17IPS163.html
          Check Vcc across C807.
          Check for any shorted output caps (not just ESR.) Check for shorts on any rail.
          • Toasty
            • Jul 2007
            • 4171
            Unfortunately, and again, that is not the schematic for this PSU as I said in the original thread:
            https://www.badcaps.net/forum/showthread.php?t=18837
            This is for the 17IPS16-2 & a piece of the 17IPS16-1
            veritas odium parit
            • bbjunkie
              • Dec 2011
              • 301
              Something not quite right here I think.. I'm measuring 10-16VAC jumping around all over the place.
              Pulled C807 to check again, 31.59uF and 0.59 ohms ESR
              • PlainBill
                • Feb 2009
                • 7034
                Voltage jumping like that is often caused by an excessive load. Since the power LED is flashing, I would suspect a problem with the inverter.
                PlainBill
                • bbjunkie
                  • Dec 2011
                  • 301
                  I have everything disconnected and the fault is still there.
                  I guess the inverter shouldnt be starting without a PSON signal?
                  • Toasty
                    • Jul 2007
                    • 4171
                    Recap it.
                    veritas odium parit
                    • bbjunkie
                      • Dec 2011
                      • 301
                      What would this achieve? I have checked ESR and value of all caps?
                      • Toasty
                        • Jul 2007
                        • 4171
                        It eliminates the caps from the equation. Ticking indicates the SMPS controller trying to start and failing. If not the caps, then the controller may be bad as tom66 suspects. If you're going to replace the controller, then replacing the caps is also a good idea as the failure of the controller can come from failed caps. Vicious circle.
                        Have you compared the caps measured ESR to their respective datasheets?
                        What is the standby voltage? Is it correct?
                        Measuring anything in the circuit past the primary caps/rectifiers for AC is incorrect. DC is all that would be in the circuit from the mains caps forward.
                        Toast
                        veritas odium parit
                        • bbjunkie
                          • Dec 2011
                          • 301
                          Ok, all noted.
                          No, compared with other caps I have seen in psu's like this. Not such a good idea i'll admit. I'll look their datasheets up and see. Apart from the low value high voltage caps such as C807 and the mains filter caps all electrolytic caps were lower than 0.1 ohms, cant recall measurements now but i'll start again and write them down. (then recap if they are out of spec)
                          I cant recall, will check that again tomorrow.
                          I thought that was the case myself and have always used DC for voltage measurements south of the rectifier. However, when I measured C807 for a DC voltage I saw a reading which resembled AC, so switched and found a much more stable reading.
                          (Still no isolation transformer so didnt scope it)
                          • bbjunkie
                            • Dec 2011
                            • 301
                            Been quite busy with life stuff, not had much time 'til today.
                            OK, on the pins (they arent numbered, so I have numbered them 1-10 and 11-20 when looking at the board upside down with the power connector closest to me)
                            I measured:
                            Pin 4: 5.04VDC
                            Pin 5: 5.32VDC
                            Pin 6: 5.32VDC
                            Pin 9: -2.55VDC
                            Pin 10: GND
                            Pin 14: 5.02VDC
                            Pin 18: 5.32VDC
                            The other pins had zero or less than 1v
                            These were taken with the board totally disconnected from the tv (due to the mechanics it's near impossible to measure 1 row of power out pins in situ) - the SSB plugs into the power board directly, (socket on SSB plug on PSU) no wires with plugs on them.
                              Are you sure pin 9 is negative?
                              • bbjunkie
                                • Dec 2011
                                • 301
                                100% sure on pin9. Unless the pin im using for ground isn't ground - it measures less than 1 ohm to chassis though.
                                I have just pulled most of the caps and re-measured ESR:
                                C830 2200uF 10v Epcos B41827 85c 2156uF ESR 0.06
                                C850 2200uF 10v Epcos B41827 85c 2076uF ESR 0.04
                                C833 2200uF 10v Chang CD110 85c 2236uF ESR 0.02
                                C829 1000uF 25v Samxon YDA 110c 949.8uF ESR 0.06
                                C841 1000uF 35v HEC ZP 105c 931.1uF ESR 0.02
                                C831 1000uF 35v HEC ZP 105C 931uF ESR 0.04
                                C905 1000uF 25v HEC ZR 85c 926.6uF ESR 0.03
                                These values are OK, right?
                                Some sort of a lookup table for ESR values would be very useful. I understand the lower the voltage the higher the ESR tends to be, and similar for the capacitance value.
                                Therefore a low voltage low value cap will have a higher ESR than a high voltage high value cap.
                                Is there a formula for working out a rough ballpark acceptable value?
                                <edit> found a chart, would this be ok? https://www.badcaps.net/forum/attach...5&d=1300287950
                                  My gut feeling tells me that C830 and C829 are going out, but they're not failed yet.
                                  • bbjunkie
                                    • Dec 2011
                                    • 301
                                    I'll replace C829 and C830 then.
                                    Anything else I should check before ordering the switch mode controller?
                                    Although we dont have a schematic for this particular revision the controller appears to have stayed the same throughout. This one is labelled AAJF X which ties up with the SG6859A in previous variations.
                                    My usual parts supplier stocks these, so I guess it's worth a try.
                                    • bbjunkie
                                      • Dec 2011
                                      • 301
                                      Ok, ordered a new controller IC on Tuesday, should be here soon.
                                      Got a low resistance on the SENSE pin, not sure if there's a problem there. Will investigate before I swap the chip.
                                      • giagiuf
                                        • Jul 2013
                                        • 3
                                        • Italy
                                        Hello to all Forum Users.
                                        I'm writing from Italy and I have the same problem to a Vestel 17IPS16-3 V1 (240906), do You have some solutions to repair IT?
                                        I have changed the SG6859A controller with a new one, the Power Mosfet and some broken diode and resistors.
                                        It is possible to have a HIGH resolution photo of the board.
                                        I had found the schematics but the parts value on the board are not the same with schematics.
                                        Please let me know as soon as possible,
                                        Best Regards,
                                        Gianluca Giuffrida.
                                        • nick4275
                                          Vestel Based JVC no picture, leds on
                                          by nick4275
                                          Hoping someone has troden this path before !
                                          I'm looking at a JVC LT-39c790 - a vestel based unit.
                                          So, the remote turns it on, led's light up but no picture at all.
                                          I have a spare mainboard, so I know its not that. The PSU seems ok too.
                                          On the AUO T-Con I've got 16v on HAVDD_H but nothing on HAVDD_L - which I'm assuming should also be 16v ?
                                          So, Ive resorted to testing eveything I can on the board as I can't find any schemas for it (AUO 39T15 C04 Ctrl Bd) and I think I've found a diode gone short. it marked D005 on the board and E1 on the package...
                                          11-21-2023, 04:43 AM
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                        • narf
                                          Epson EB-U42 projector / Caps with 0.7 ohms ?!
                                          by narf
                                          hi all,
                                          first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
                                          i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
                                          what i've found so far:
                                          - the PSU does its job and supplies 12V to the mainboard via the connector.
                                          - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
                                          - not far away, there's the first cap with a resistance of 0.7 ohms....
                                          07-02-2024, 03:53 PM
                                        • France_53
                                          Vestel tv, how to flip the image?
                                          by France_53
                                          Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                                          05-12-2024, 05:22 AM
                                        • lberkani
                                          Request: USB firmware for Toshiba 65UL2163DG (Vestel 17MB180E) - panel VES650QNTX-N2-N42
                                          by lberkani
                                          I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
                                          The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
                                          The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
                                          I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
                                          - Toshiba 65UL2163DG
                                          - Vestel 17MB180E mainboard
                                          - Panel VES650QNTX-N2-N42
                                          - Version V1.28.100.0 if available
                                          If anyone has the file, please share a download link (WeTransfer, MEGA, Google Drive) and include version.txt...
                                          11-11-2025, 12:37 PM
