Checking fast recovery diode
  • bbjunkie
    • Dec 2011
    • 301
    Got an unnamed LCD that uses Vestel 17ips16-3 PSU unit, making a very quiet clicking noise and wont come out of standby.
    I have located a diode in the PSU which I feel may be faulty, just want to run it by you guys before I order a replacement.
    It's a BA159 - a fast recovery diode datasheet at http://html.alldatasheet.com/html-pd...2/1/BA159.html
    and is D810 on the board if anyone is looking at a schematic.
    In one direction open circuit, other direction 5.9M Ohms both measurements taken out of circuit.
    This is faulty, right?
    Jim
  • Toasty
    • Jul 2007
    • 4171
    Re: Checking fast recovery diode
    What type of meter (DMM/Analog) and what scale are you using to test?
    EDIT: Grabbed the diagram from elektrotanya.com for you.
    EDIT 2: <sigh> Sheet is for 17IPS16-1 or -2 not -3 as on their site...
    veritas odium parit
    • Toasty
      • Jul 2007
      • 4171
      Looks like there are several of these on the board. Does this one differ from the others?
      veritas odium parit
      • bbjunkie
        • Dec 2011
        • 301
        Haven't checked the others, good point i'll lift another and compare them. D801 and D803appear to be the same component. Will check against them.
        • retiredcaps
          • Apr 2010
          • 9271
          I normally use the diode test function to test diodes. A good diode should test between 0.5 and 0.8V one way and "out of range".
          --- begin sig file ---
          --- end sig file ---
          • bbjunkie
            • Dec 2011
            • 301
            Did this too, reading .440 or so (cant recall exactly, will re-test when im back in the workshop) but the extremely high resistance had me wondering.
            The whole reason I pulled it to test in the first place was that it was measuring 95k ohms in both directions in circuit.
            • bbjunkie
              • Dec 2011
              • 301
              Ok, checked and D800 801 802 and 803 are in fact not the same. Perhaps this is one of the differences in the -3 version.
              There dont appear to be any other BA159 diodes on the board. In fact there are only 5 on the primary side, 4 rectifier diodes and the D810 which is in circuit with a few other components across pins 1 & 3 on the primary side.
              I will potter around some more with it and see how I get on. Any further problems and I will start a repair thread and post some pics.
                I don't think you're dealing with an open diode problem - a shorted diode would cause the symptoms described
                I've never seen a diode fail open, but I suppose it could happen.
                Bad SMPS controller, bad startup cap?
                • PeteS in CA
                  • Aug 2005
                  • 3586
                  • USA, Unsure of Planet
                  Diodes hould be checked using the diode checker function. An ohm meter can detect shorts or abnormally low resistance. But a healthy diode will usually read high resistance in the forward direction and extremely high or out of range in the reverse. An exception to that latter is that I have seen some schottkies read onthe order of 200 ohms in the forward direction. Different diode types have different forward voltages, which can be seen with a diode checker. Schottkies are usually low, .2V-.5V; regular GP diodes perhaps .5-.7V; FR and ultrafast perhaps .8-1.2V. I have seen highvoltage ultrafast parts as high as 1.5V.
                  Sounds to me like your power supply is in a burp-mode current limit state. That diode could be bad - that forwaard voltage sounds low to me, though different meters can read differently. Maybe check to see if the output is shorted by something in the load, or maybe a bad output filter capacitor.
                  PeteS in CA
                  • bbjunkie
                    • Dec 2011
                    • 301
                    Ok, it has beaten me - i've started a repair thread: https://www.badcaps.net/forum/showth...463#post214463
                    • volinakis
                      Chromebook recovery failed - how to fix it
                      by volinakis
                      So I had a Asus C433T Chromebook enrolled and after I modified bios I had to reinstall Chromium. I made a USB recovery stick with Chromebook Recovery Utility but I got "an unexpected error has occurred ..." message. I did try with another USB stick, etc. etc. -all steps found on internet about this issue and nothing worked.
                      Finally I found a site where they suggested to try with an older image and ... it worked!
                      What I did:
                      - when “Chrome OS is missing or damaged” message appeared I pressed Tab key and found: read only firmware id: Google_Rammus. xxxxx.xxx.x....
                      09-18-2023, 03:26 PM
                    • asr
                      Finding replacement diode iPad Pro 3rd gen A1701
                      by asr
                      Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                      Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                      07-09-2024, 06:24 PM
                    • howardc64
                      LG 65UQ8000AUB no backlight burning smell
                      by howardc64
                      Only 3 years old. Owner said backlight went out and burning smell. Didn't bother plugging in to check if had power LED. Just opened the TV rear and found shorted bridge rectifier diode on the backlight circuit on the PSU. SF26G (400V 2A super fast recovery rectifier link ) diode replace with SF26 (what I had on hand) Google AI said G = Green Components.
                      Burn looked pretty bad on the board but just was blackened carbon coating material. Scraped and cleaned off quite well and clean solder pad for the new diode.
                      06-07-2025, 10:38 PM
                    • unimatrix93
                      TV backlight zener diode
                      by unimatrix93
                      Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                      So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                      Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                      The led strips has 9 6V leds.
                      02-10-2025, 12:13 PM
                    • iMuhtaseb
                      A2681 Keyboard, trackpad and sleep?!
                      by iMuhtaseb
                      Wow it's been a while since I posted!
                      This is a weird case, it has a history of liquid spill a year ago but customer did not want to replace neither trackpad or keyboard.. fast forward for today:
                      A2681 turns on but not trackpad or keyboard feedback (or external keyboard and mouse) and then after a minute or so the Mac sleeps..
                      It's a NOT a sleep sensor or trackpad or keyboard or daughterboard or anything else (I replaced all those); it's the logic board..
                      Tested another locked logic board on customer's top case and it posted with keyboard and...
                      05-22-2025, 09:59 AM
