Hi guys I have a LCD here which wont power up. My assumption was that the inverter board has a problem so today I had some time and took it apart. I found the main fuse blown (which was jumped for time being) as well as 2 bad caps. I went ahead and replaced all caps just to make sure. After that I was going to test the screen and got presented with a strobe light effect. As soon as the screen is plugged in to the power outlet it starts blinking. The power button led is not lit and I do not have a clean 5VDC going to the video board. The 12VDC seems to be between 11.7VDC and 12.08VDC. Do you guys have any ideas where to start checking more into this or maybe somebody experienced this already?
Gateway FDP1960 wont power up / strobe light effect
Re: Gateway FDP1960 wont power up / strobe light effect
1) What brand and series did you use for replacement capacitors?
2) Did you replace the little capacitor just below and to the right the big yellow SMPS transformer?
3) What do you mean by "clean" 5V DC? Is is fluctuating? Is the voltage significantly below 5V DC?--- begin sig file ---
--- end sig file ---Comment
First of all thank you for your responses and please go slow with me since I'm new to troubleshooting on component level. Also I tried to replaced the lousy cell pictures with some better camera shots in the OP but there is no edit button so I have them in this post.
U301 and U302 are ENHANCEMENT MODE POWER MOSFETS. Do I need to desolder these to check for functionality?
1. The original caps were Samxon GF(M) 105*C8 and I replaced them with NTE 105*C. I know everybody says get good caps etc. but this is what was available locally. Also I assume the original caps were pretty cheap brand as well and made it for a few years so my thinking is some other cheap crap should fire the screen for at least a week right?
2. No i didnt replaced this one yet hence the green color opposed to blue (new caps)
3. The voltage is fluctuation up and down. I can hear the inverter ramping up and shutting down. I assume the voltage is going up and down attune with the sound of the inverter. The voltage is between 2.5 and 4 but its hard to measure at this point since its cycling pretty quick.Last edited by HITandRUN; 03-27-2011, 08:41 AM.Comment
Check them for shorts "in circuit" first. If any reading is below 30 ohms, then desolder them and retest them out of circuit.
Samxon GF are a problematic series.
That little green cap plays an important part of the SMPS startup process. This cap could be causing the 5V rail not to start up properly (i.e. fluctuation). I suggest using a quality cap like a Panasonic FR, FM, or FC for a replacement.2. No i didnt replaced this one yet hence the green color opposed to blue (new caps)
While the NTE caps are likely to work, the SMPS requires low ESR (ohms) caps. If the NTE caps are low ESR, you are okay. If not, the lcd is likely to work, but dont' be surprised if you are changing out the caps again in 6 to 12 months.
The Samxon GF caps are low ESR, but they are a problematic series (lemon).
PS. The pictures are a significant improvement.--- begin sig file ---
Thank you for all your pointers! I'll get some quality caps and replace the one mentioned by you as well.Check them for shorts "in circuit" first. If any reading is below 30 ohms, then desolder them and retest them out of circuit.
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by ipatchhello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
by russpallHi there,
I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
...2 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samSee pictures for type of laptop computer
I checked switching power supply brick 19.2 volts multi meter only
No booting without switching power supply connected
Checked switching power supply with an (28 volt ) incandescent light bulb it lights then hooked up the switching power supply again now the laptop and boots like normal
What the heck is going on here...-
- Loading...
