Lenovo G585 Bios for UMA mainboard
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Dear forum members,
    Laptop: Lenovo G585
    Mainboard: LA-8681P
    I have attached the Bios dump from my Lenovo G585 with a GPU:
    https://www.badcaps.net/forum/attach...0&d=1545390665
    If someone has a Bios dump from a Lenovo G585 that has no GPU, please upload it here for me.
    I urgently need it if it is from a LA-8681P mainboard without GPU.
    thanks
    • 21687
    Re: Lenovo G585 Bios for UMA mainboard
    Try this one: https://www.laboneinside.com/lenovo-g585-bios-bin/
    • mahmoodjavan
      Banned
      • Mar 2018
      • 584
      • iran
      [QUOTE=caspian;869874]Dear forum members,
      Laptop: Lenovo G585
      Mainboard: LA-8681P
      thanks[/QUOplz test
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        thank you
        I have tested both these Bios dumps, but there was no change. probably, the FCH is defective. If I find this mainboard, I will replace the entire mainboard.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Originally posted by caspian
          thank you
          Replacing the FCH will likely fix your problem. You dont do bga rework??
          • caspian
            • Oct 2015
            • 1591
            • Laptop
            no, I do not have any BGA machine. because it is too expensive. Every time I discover a BGA chip is defective, I stop repairing and return the laptop back to customer.
            • caspian
              • Oct 2015
              • 1591
              • Laptop
              both the above Bios dumps seem to belong to a mainboard with GPU. I still looking for another bios dump that differs from these dumps.
                • 21687
                Try the one here,i think its a UMA version: https://www.badcaps.net/forum/showthread.php?t=39017
                • caspian
                  • Oct 2015
                  • 1591
                  • Laptop
                  thanks, that link contains a bios dump which is the same as the one provided in Post#3. So I tried it before.
                  this thread is connected to my other thread here:
                  https://www.badcaps.net/forum/showthread.php?t=73661
                  still looking for a UMA bios dump or somehow to combine the bios dumps of Post1 and Post2. because each one makes some part of the FCH work correctly.
                    • 21687
                    Sorry, i should have checked first before posting it. I found a bios that may be the right one this time,although its for a ideapad G485 its the same bios version as the UMA G585
                    offset 3E000 IdeaPad G485 , Win Key at 350000
                    34FE000 $BVDT$...$.1)$6CCN96WW(V8.08).........$QAWGE.
                    QAWGE is a UMA board i believe ?
                    • caspian
                      • Oct 2015
                      • 1591
                      • Laptop
                      As you help me continue this repair, I appreciate. I will try this file and report back.
                        • 21687
                        The EC posted by @mahmoodjavan at post #3 has these strings starting at offset 4000 QAWGE,QAWGF,QAWGK .Can you backup your EC and check if it has those same strings,or compare the two files.Maybe you have to flash the EC.
                        • caspian
                          • Oct 2015
                          • 1591
                          • Laptop
                          I do not have any EC programmer. So I hope EC programming is not required.
                          Only QAWGE is mentioned in all the above Bios dumps. and the mainboard is marked by QAWGE.
                          • caspian
                            • Oct 2015
                            • 1591
                            • Laptop
                            I have tried the bios dump of Post#10. It acts the same as the dump of Post#2. that means no change.
                            Only the original dump (in Post#1) works well but it was not written to accept UMA conversion. after they updated the Bios to the one of Post#2, it accepts UMA conversion but it is not compatible to my mainboard.
                            I am still looking for other Bios dumps to try.
                            • caspian
                              • Oct 2015
                              • 1591
                              • Laptop
                              is there a way to extract the GPU or graphics section from Post#2 's Bios and replace it into Post#1 's Bios?
                              • lefos
                                • Nov 2013
                                • 321
                                • Greece
                                If somebody ever needs a bios for this UMA board then this is it. Laptop has shorted APU.
                                So I think the dump will be OK
                                The board is QAWGE LA-8681P Rev 1.0 2012-04-02.
                                • Micro System
                                  • Nov 2014
                                  • 4
                                  • India
                                  Thanks your file is working ok
                                  • mrbrian
                                    • Feb 2017
                                    • 5
                                    • venezuela
                                    works perfect, tested, thank you so much
                                    • lucaszmn
                                      by lucaszmn
                                      Problem:
                                      Initial Findings:
                                      • I concluded that the
                                      08-12-2025, 03:01 PM
                                    • Wahaz
                                      by Wahaz
                                      10-30-2023, 08:42 PM
                                    • grimacelord
                                      Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                      by grimacelord
                                      Hello there.
                                      I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                      History:
                                      1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                      I searched for this error online and discovered...
                                      03-15-2023, 03:29 PM
                                    • jendkkd jeje
                                      Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                      by jendkkd jeje
                                      So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                      I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                      10-11-2024, 03:12 PM
                                    • c.daniel
                                      Lenovo V310-15IKB weird bios problem...
                                      by c.daniel
                                      Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
                                      sn LR09493E
                                      MB DAOLV6MB6F0 REV. F
                                      The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
                                      Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
                                      Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
                                      08-22-2025, 05:39 AM
