820-000928-A Help Identify Location of this Capacitor
  • sikocan
    • Oct 2019
    • 344
    Hi there,
    I'm working on a A1707 Motherboard 820-000928-A and only boardview I can find it attached.
    Both legs of this capacitor are shorted to ground, well 1 leg is, the other is obviously ground. I've injected 1V maximum and 1.3amps I can not find anything getting hot and I don't want to go further. From injection I can tell top is Ground, 0V and max amp taken, bottom leg is going somewhere as 1amp at 0.05v for example.
    Could someone please let me know where this cap is going? The capacitor itself is good, test outside board is fine.
    When the Finger print sensor is connected, board stays at 5V and no amps taken, when finger print sensor is taken out, it jumps to 20V and system boots fine without button.
  • mon2
    • Dec 2019
    • 14672
    Re: Help Identify Location of this Capacitor
    What is the cap # ?
    • sikocan
      • Oct 2019
      • 344
      It's not in the board view, but it's on the motherboard.
      • mon2
        • Dec 2019
        • 14672
        Can you zoom out on the picture? Having a hard time locating where you are referencing this cap.
        Also, the 820-xxxx # is etched on your PCB and matches the boardview that is under review?
        • sikocan
          • Oct 2019
          • 344
          Correct for boardview model number. It's located right under power button ribbon cable. I'll send more photos today.
          • mon2
            • Dec 2019
            • 14672
            I may have found the point of view - please see attached.
            Do not see the missing cap.
            • sikocan
              • Oct 2019
              • 344
              Sir I know that cap location, I don't know where it is on boardview.
              • sikocan
                • Oct 2019
                • 344
                Sorry I couldn't explain myself properly. I need to know where that cap is in boardview. My cap is good, but it's location is Shorted.
                • mon2
                  • Dec 2019
                  • 14672
                  See attached. Could not locate this cap on boardview either.
                  • mon2
                    • Dec 2019
                    • 14672
                    I think I see the difference. The boardview does not accurately match the pcb layout.
                    Perhaps there are more updated versions of this layout? the component placements are not matching the picture.
                    • sikocan
                      • Oct 2019
                      • 344
                      Correct. I'm also confused.
                      • piernov
                        • Jan 2016
                        • 4439
                        • France
                        Boardview file is for 820-00281 not 820-00928, so that's possibly one difference between the 2. Check if the other side looks identical between your board and the boardview.
                        • sikocan
                          • Oct 2019
                          • 344
                          Hi Piernov,
                          I've packed up the unit, here's the video of all thermal scan of entire board 1.3amps at 1v, nothing gets hot. Even after removing metal shields. I'll see if I can have another go with that boardview.
                          https://youtu.be/Q1i9OiKGD7g
                          • sikocan
                            • Oct 2019
                            • 344
                            I've looked at boardview files:
                            820-00928.brd
                            820-00928 A1707 Apple Macbook Pro 15'' Retina Touch.brd
                            Boardview_J80G_MLB.brd
                            2016-3072-820-00281-A-A1707 SCHEM MLB BAFFIN X363G.brd
                            None of them have that Capacitor location. So weird. I don't understand what's going on.
                            All these files on BadCaps Forum and also ERS Discord channel.
                            Any ideas anyone? I've uploaded a video showing thermal camera of entire board every detail on both sides, no where is getting any hot at 1.3amps at 1v.
                            It's related to power button/finger print.
                            • sikocan
                              • Oct 2019
                              • 344
                              I've ordered an TS-30A, this one here https://s.click.aliexpress.com/e/_AbU1Pw and if it comes in enough time I'll try it on this board. TS-30A Short Killer
                              • piernov
                                • Jan 2016
                                • 4439
                                • France
                                The 820-00928 boardview is not available in any case. https://logi.wiki/index.php/Schemati...in_Logic_Board
                                • gizaha
                                  • Mar 2018
                                  • 25
                                  • Greece
                                  I have exactly the same problem. There are also 2 capacitors on the rear side of this area that are not on boardview and they share the shortage of the line also.
                                  I removed all 3 capacitors and the short is here. So tommorow i will search the rest of board.
                                  • sikocan
                                    • Oct 2019
                                    • 344
                                    Re: 820-000928-A Help Identify Location of this Capacitor
                                    Update me please
                                    • mon2
                                      • Dec 2019
                                      • 14672
                                      TS-30A Short Killer
                                      We have the same. Although the vendor sent us one with a dim display but we are 1/2 way across the world so cannot fire back a complaint...
                                      To use, dial up a LOW voltage (always) - try 0v8 (yes < 1.0 volts). This is to protect any possible downstream shorted rails like the CPU which will get killed with a high voltage.
                                      Then you apply the red probe to the cap / block of caps you suspect as shorted & black to ground.
                                      You will see a small spark due to the low resistance of the shorted caps and the current will climb. This process will heat up the shorted part.
                                      Suggest to apply with a Q-tip some IPA (alcohol; 70% or higher) onto the parts. The IPA will mist away with the heat. Locate and remove that shorted cap.
                                      The above is a general process and there are very detailed videos on youtube on this topic that are must watch.
                                      • gizaha
                                        • Mar 2018
                                        • 25
                                        • Greece
                                        Sometimes a shorted cap will not heat. No alcohol, no freeze spray, no thermal cam will help you. A laser thermometer does not indicate even a 0.1C difference. Motherboard lines will absorve the amperage and there are thinner that the shorted part (so the part will not heat even with high amperage).
                                        In this case i apply some safe voltage as mentioned with 1-2 amperes (never needed more) and check with multimeter all the suspicious parts that connect with the shorted line (using boardview). In the multimeter on the small voltage scale, you will see a small difference in your checks (let's say you will read 0.42v, 0.30v, 0.27v in 3 capacitors). The shortage is near the smaller voltage you will find, remove the around capacitors/parts and you found it.
                                        • MORETTIGIAN
                                          Capacitor detached from PCB – RTX 2070 Super Founders Edition
                                          by MORETTIGIAN
                                          Title:
                                          Description:
                                          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                                          I did not notice it detaching, so I am unsure of its original location on the PCB.
                                          Procedure performed:
                                          - Removed backplate
                                          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                                          - Reapplied thermal compound
                                          - Reassembled card
                                          Observed behavior after reassembly:
                                          - GPU powers on and operates normally under...
                                          09-18-2025, 12:14 PM
                                        • BlackBurn
                                          Help to identify a laptop mainboard SMD capacitor LA-9982P
                                          by BlackBurn
                                          I have an Dell Inspiron 15 3537 laptop mainboard (LA-9982P Rev. 3.0 (A02)) with a blown SMD capacitor as shown in the attached images. However, there is no printed specifications near the capacitor or a codename for the capacitor to identify the specification of the capacitor to replace it. I wonder how to identify the capacitor since the mainboard schematics are also useless as the capacitors are not named on the board. Any help would be highly appreciated.
                                          Thank You. Stay Safe.
                                          Chamara...
                                          11-27-2020, 08:30 AM
                                        • Agent24
                                          Dick Smith Q-1760 linear power supply filter capacitor question
                                          by Agent24
                                          I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                                          It has at least one problem.
                                          The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                                          I have already ordered a replacement potentiometer, so that's not an issue.
                                          Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                                          All are CapXon...
                                          10-21-2025, 05:39 PM
                                        • chth96
                                          If I replace with inferior capacitor, Is it No harm to other IC components at all?
                                          by chth96
                                          I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                                          Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                                          It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                                          So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                                          I know that these capacitor will not last as long as nichicon capacitor...
                                          12-22-2023, 04:34 AM
                                        • chth96
                                          How can I test non-polarized capacitor?
                                          by chth96
                                          I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                                          I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                                          And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                                          I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                                          06-02-2024, 07:31 PM
