need bios bin asus x75a-dh31
  • opencircuit
    • Aug 2011
    • 27
    • Philippines
    hello guys somebody help me
    i need bios bin file
    x75VD main board
    REV. 3.1
  • ridamouh159
    • Nov 2014
    • 365
    • maroc
    Re: need bios bin asus x75a-dh31
    Try with this
    • kronnos
      • Dec 2015
      • 9
      • Romania
      works 100%, 10x. in my case didn't recognise the ram from slot.
      • TABLOUJ1
        • Nov 2017
        • 4
        • ALGERIA
        thank you
        • Pascal Komlassan
          • Jan 2017
          • 806
          • TOGO
          Originally posted by ridamouh159
          Try with this
          nice job
          • antoska
            • Jul 2019
            • 4
            • españa
            someone has the ASUS X75VD bios I need it thanks
            • alexmonk63
              • Dec 2017
              • 14
              • Plzen
              thank you
              • boussaa islem
                • Nov 2018
                • 30
                • ALGRIA
                x75VD main board
                REV. 3.1
                • peste
                  • Dec 2016
                  • 12812
                  • ROMANIA
                  x75VD main board
                  REV. 3.1
                  post the original bios
                  • ragazzopazzo
                    • Jul 2019
                    • 1
                    • italia
                    thanks
                    but it dosn work
                    • razor_amd
                      [TUTORIAL] fix asus bios with bios from asus web support (by razor_amd)
                      by razor_amd
                      With ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
                      For example, you can have 3 similar ASUS motherboards, all being the same model, all of which will have different BIOS versions.
                      I will give you an example and my version of preparing BIOS from ASUS website and in the process I am always cleaning Intel ME while doing it so you have fully cleaned BIOS, no DMI data, no password, nothing.
                      This is the picture of 3 similar ASUS motherboards, all of them being X555LD...
                      12-15-2020, 07:07 PM
                    • grimacelord
                      ASUS TUF GAMING Z790-PLUS WIFI - BIOS Help
                      by grimacelord
                      I have spent the last hour on this and I guess this is just over my head, so here I am.
                      I have an ASUS TUF GAMING Z790-PLUS WIFI motherboard here that needs to have the BIOS updated in order to accept the latest CPUs.
                      The BIOS chips seem to come as a set of two: GD25B64ESIG and GD25B128ESIG. My guess is one of them is a fail-safe for the main BIOS? I really don't know. Or one of them is ME and other is BIOS? I don't know.
                      Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...
                      07-10-2025, 02:52 PM
                    • throwaway327
                      Asus ROG Ally X -RC72LA - changed hidden bios settings with 'Smokeless-UMAF', won't get past boot logo
                      by throwaway327
                      ASUS ROG Ally X - (Handheld Gaming PC)
                      Model No: RC72LA
                      Serial No: SBNVKD001014459
                      Hi all, I've spent the past week digging through the forums and guides to try correct my foolish mistake of changing hidden settings while tinkering around, and to be honest my heads overloaded so I'm hoping you'll be able to help.
                      I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...
                      06-18-2025, 05:52 PM
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
                    • DaJetzi
                      ASUS R900VM BIOS update went bad
                      by DaJetzi
                      I have an ASUS R900V notebook, MB version K95VM, which, after a BIOS update, shows a black screen and no longer boots; only the fan is running.
                      I got BIOS version 234 from https://www.asus.com/de/supportonly/...helpdesk_bios/
                      After the update failed, I read the memory contents of the EEPROM Winbond W25Q64VF and found the following lines: "EFI_SUCCESS K45VM.bin".
                      I then looked at the downloaded update, unpacked the zip file, and found the actual update named "K45VMAS.234". I was actually expecting something related to K95VM.
                      Somewhat confused,...
                      Today, 01:04 AM
