X-class capacitor quality
  • japlytic
    • Oct 2005
    • 2086
    When I did a check for capacitance tolerance on about 200 used X-class capacitors, up to half of them were lower than 90% of their rated value (all had a 10% tolerance), with a few being way down in capacitance.
    Apparently, half of the yellow X-class units were out of tolerance.
    I remember reading the Serviceman's Log in Silicon Chip magazine about X-class capacitors losing their capacitance because too much capacitance was crammed into a small unit, and apparently deteriorated at a much quicker rate.
    Could some brands of X-class capacitors be bad?
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: X-class capacitor quality
    No one really notices even if they're bad (unless they fail shorted, which they are specifically designed not to do) because they're basically only for EMI compliance, and really cheap PSUs don't even have them.
    • 999999999
      • Sep 2006
      • 774
      It wouldn't surprise me at all if some brands used lower purity aluminum, lower uniformity in depositing it, or lower quality plastic.
      Not sure which mechanism they are referring to by "too much capacitance was cramming into a small unit", that should just result in them having a lower voltage limit or margin but at capacitor tester voltage levels it should not matter. However I'm thinking of a new capacitor, lower voltage tolerance could cause more AC mains voltage spike damage in use. You could tear open one of the worst to see what's inside...
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        Assuming these are film dielectric ...
        It would not surprise me if cheap-@$$ brands set their machines to make parts at the low end of their tolerance, and then cheat just a little. Or made caps to the low end of 20% tolerance ("M" instead of "K") but marked them 10%. Like b7... posted, who would notice?
        OTOH, the parts you checked were all used. Some one pointed out on another thread that film X and Y caps take voltage spikes, are damaged, but self-heal (the arc that punches through the film clears metallization from the area around the arc site, so the cap is not shorted). Each self-heal does damage, and over time the damage is cumulative and can reduce the capacitance of the part. Also, the self-healing of film capacitors is not utterly perfect. There is carbon residue in and around the arc, through which current can flow. Over time these high resistance current paths accumulate and can cause the part to got hot and even catch fire.
        If you live in an area with lots of spikes due to industrial machinery or lightning storms, that can be really hard on X caps. OTOH, if your power is relatively pristine ...
        Now, if those X caps were ceramic dielectric, they don't have the vulnerabilities film caps do. BUT getting higher capacitances at the required voltage and surge voltage ratings necessitates using ceramics with horrible temperature coefficients (e.g. Z5U or Y5V). If you connect such a part to your capacitance meter and warm the part with your fingers, you can watch the capacitance reading vary. At the high or low end of such parts' rated temperature range their capacitance could le 25% or 30% (or less!) of the nominal value. Such ceramics also have horrible DC voltage coefficients, but that doesn't apply in this context. Anyway, if those were ceramic X caps, they might have been good, but your room temp (or finger temp) caused to capacitance to drop that much.
        When Electronics classes in high school, trade schools or colleges say, "Assume an ideal capacitor," that's fine for calculations, but they really should spend some time talking about and demonstrating the effects of real-world characteristics such as impedance and temperature & voltage coefficients!
        PeteS in CA
        • Tobugrynbak
          • Feb 2012
          • 1
          I'm going through a similar exercise hand grading new x2 capacitors. Found most to be low but within 10%, just a couple at just above the value and a couple lower than 10%.
          A previous batch has caused us some grief, prematurely failing in the field. Too much "self healing" causing them to go way out of spec (from 0.22uF to 0.022uF in one case).
          As for dodgy components I'm always on the lookout for counterfeit parts though that usually just concerns semiconductors. Though I've got a bag of capacitors with brand x on the bag but brand Y on the capacitors themselves. With a lot of sub sub sub contracting going on in the manufacture of parts with everyone chasing the lowes possible price, it's gonna happen again and again.
          A man will have 2 reasons to do a thing. One that sounds good, and the real one...
          • PeteS in CA
            • Aug 2005
            • 3581
            There are some parts rated for both "X" and "Y" usage. Though a .01 uF or 4700pF "X" cap seems less that useful to me.
            PeteS in CA
            • MORETTIGIAN
              Capacitor detached from PCB – RTX 2070 Super Founders Edition
              by MORETTIGIAN
              Title:
              Description:
              During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
              I did not notice it detaching, so I am unsure of its original location on the PCB.
              Procedure performed:
              - Removed backplate
              - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
              - Reapplied thermal compound
              - Reassembled card
              Observed behavior after reassembly:
              - GPU powers on and operates normally under...
              09-18-2025, 12:14 PM
            • Prolog
              RTX 3080 FE Identifying capacitor
              by Prolog
              Hi people, I hope this is the correct spot to post this, I'm new to the forum.
              I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
              I hope these photos make it clear which component I am referring to:
              (yes, the soldering is a bit botched from removing the blown one, I know)
              I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
              12-01-2024, 08:27 PM
            • Sparklingx
              SMD ceramic capacitor capacitance & voltage
              by Sparklingx
              what is the easiest way to measure the capacitance of SMD ceramic capacitors and its rated voltage?...
              09-12-2024, 01:04 AM
            • chth96
              If I replace with inferior capacitor, Is it No harm to other IC components at all?
              by chth96
              I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
              Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
              It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
              So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
              I know that these capacitor will not last as long as nichicon capacitor...
              12-22-2023, 04:34 AM
            • chth96
              What capacitor should I purchase for Power Supply of obsolete game consoles?
              by chth96
              hello.
              I have Sega Saturn and 5 years ago, I recapped all of capacitor in the Power supply, Because At that time, It frequently freezed black screen after SEGA logo displayed.
              It hardly ever freezed after I finished to recap all of caps in the power supply.
              But Yesterday, It did not show any screen at all and its green power LED constantly blinked.
              To my surprise I found that all of two NXH 10v 2200uf capacitors in the secondary area of Power supply have been bulged and It measured 57 mF and 75 mF capacitance.
              It seems that quality...
              10-01-2024, 08:14 AM
