Vizio VS420LF1A
  • RRR13
    • Jul 2010
    • 9
    Vizio VS420LF1A
    hello guy having issues with one of My LCD TV's ....newbie with the LCD tv repair ...where do I start with this i wonder if it is the controller card or main board issue? having red moving pixelation...=(
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Vizio VS420LF1A
    It would help to have clear focused pictures of the insides of your tv. Please post an overall picture of the boards and then a picture of each board. Use manage attachments like you did in post #1.
    --- begin sig file ---
    --- end sig file ---
    • Dgtech
      E. Technician
      • Apr 2009
      • 1462
      • Steeler
      Re: Vizio VS420LF1A
      For your sake, I hope it's the video processing board and not the panel itself. Your power supply should be fine.
      The first thing I'd do is find out if this occurs on all video inputs. This doesnt prove or disprove one board or the other however if one imput works better than the other, you might want to live with using the working input.
      • bell7526
        • Jan 2011
        • 23
        Re: Vizio VS420LF1A
        It happens on both HDMI ports as well as the component port I tested with both my Uverse Box and Bluray.
        • Dgtech
          E. Technician
          • Apr 2009
          • 1462
          • Steeler
          Re: Vizio VS420LF1A
          Are you using different names? Hmm....
          OK... as before mentioned in post number 2, post clear pictures of the set opened up, then the boards in this set. Post the numbers that are marked on these boards.
          • bell7526
            • Jan 2011
            • 23
            Re: Vizio VS420LF1A
            I will take pictures Saturday when I will have the day off of the insides. My friend/rep that sold me the TV made the intial post on my behalf while I was signing up for the forum. I am new to repairing TVs and he introduced me to this forum that he said was extremely helpful when he was repairing several. Sorry for the confusion.
            • bell7526
              • Jan 2011
              • 23
              Re: Vizio VS420LF1A
              Attached are pictures of the boards.
              • Dgtech
                E. Technician
                • Apr 2009
                • 1462
                • Steeler
                Re: Vizio VS420LF1A
                I am suspecting the board in the very last picture. I believe it's the t-conn board. I cannot tell you for sure but if you can post the numbers on this board, it can be looked into further.
                • bell7526
                  • Jan 2011
                  • 23
                  Re: Vizio VS420LF1A
                  The red pixelation is intermittant.
                  LG Philips LCD Co. Ltd.
                  Desc LG420WVN-SAA1 Control PCB 2L
                  P/N 6870C-4200C
                  Designed: 2007.08.22
                  JA018V
                  4201B1
                  tpts0S-2S
                  94V-0
                  E88441
                  0841-2
                  Last edited by bell7526; 01-31-2011, 09:16 PM. Reason: Left out important information
                  • Dgtech
                    E. Technician
                    • Apr 2009
                    • 1462
                    • Steeler
                    Re: Vizio VS420LF1A
                    With this current problem, I suggest swapping this board. I can't promise you that doing so will fix the problem however there is no way that I know of to test this board.
                    If you search in ebay for "6870C-4200C" you will find a lot of these boards for sale varying in prices. The cheapest one I seen was $20 with cheap shipping. ShopJimmy has them for about $40. There are no guarantees with ebay so be carefull.
                    • bell7526
                      • Jan 2011
                      • 23
                      Re: Vizio VS420LF1A
                      I am extremely new to this an just wanted to know what the T-Conn board does on a LCD TV? I know dumb question, but got to start learning somewhere.
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Re: Vizio VS420LF1A
                        This falls into the category of 'the only dumb questions are those that you don't ask'. T-con (or tcon) stand for 'timing and control'. It controls the individual pixels on the LCD panel so the information from the LVDS cable is accurately displayed.
                        PlainBill
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                        • SS454
                          vizio e650i-a2 backlight flashes then turns off
                          by SS454
                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                          panel: au optronics T650HVN05.4
                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                          08-20-2020, 03:57 PM
                        • mrtek
                          Vizio M65-C1
                          by mrtek
                          Hi.
                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                          07-14-2025, 07:28 PM
                        • howardc64
                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                          by howardc64
                          Failure Symptom
                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                          Where is the short?
                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                          05-27-2025, 02:56 PM
                        • howardc64
                          Vizio SmartCast TV software bug that looks like hardware
                          by howardc64
                          Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                          It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                          11-16-2024, 05:17 PM
