panasonic TC-P50U50 8 blinks
  • tw2005
    • Oct 2011
    • 6458
    Re: panasonic TC-P50U50 8 blinks
    Originally posted by oliku
    Good evening. I stumbled across this site & thread because I also have a TC-P50U50 with 8 blinks. I'm a copier tech, so I'm not as savvy with TV's as some of you may be. I know 8 blinks can indicate a number of issues. Since I have low experience, I want to just buy & replace the SS Board because it seems like the most likely culprit.
    I was wondering if there was any alternate suggestions or if anyone knew of the best place to buy this board. Seems like the only place I can find one is ebay. Thanks for your help!
    I dare say it must be such a common issue that there seems to be none around. Your best bet would be to follow the tech bulletin and repair it. Much cheaper and should be easy enough.
    Rare not to find SS boards for sale, usually Sc boards are the hard ones.
    Hard to believe Panasonic are not pulling their weight and looking after the customer.
    • tw2005
      • Oct 2011
      • 6458
      Originally posted by freakaftr8
      that's all I found too. yes this board is failure prone. Looj for thus model ir tc-p55ut50 ss board. Same part number.
      Better have a good look at that 55 SS, is UT 3D and U just std FHD? I'm seeing ICs missing from the 55 board. I would not use it unless the component layout is the same.
      Both TNPA5623 but no rev for the 55UT50, AB for the 50U50
      • freakaftr8
        • Oct 2012
        • 3743
        oh crap I guess I shoulda looked better before I put the board in the 50 inch last night. But it has been running for about 5 hours nonstop and it looks perfect. Go figure I wonder what the revisions about....
        • tw2005
          • Oct 2011
          • 6458
          Ok, well I don't know maybe to do with 3D. I've circled some obvious ones. This is a guess but I wonder if they're the FET driver ICs and one type maybe a heavy duty one. I know that sounds like crap but with out part numbers etc it's a guess.
          Good chance some of the capacitors and coils are different . Anyway it works so who cares.
            That change could simply be due to availability of different components for different runs, looks like the boards would sub fine to me.
            • freakaftr8
              • Oct 2012
              • 3743
              I have to admit a bad fault of mine. When it comes to replacing boards and I can't repair component-level I um... usually just replace it by partnumber and not sub.. oopsie 9 times outta 10 everything seems to work fine
              • naw
                • Nov 2013
                • 2
                I just started having similar issue with my panasonic TC-P50U50. I'm getting 8 blinks and i followed a service manual and it led me to believe the ss-board is bad. I have downloaded the repair manual from the forum, all i need now is someone to provide me with a store i may purchase these parts from. All help is highly appreciated.
                • naw
                  • Nov 2013
                  • 2
                  Originally posted by tw2005
                  Nothing like getting it from the source
                  I'm new to forums, could anyone provide me with a good place to purchase the parts from this manual?
                  • Edna L.
                    • Jan 2014
                    • 1
                    thanks for sharing the bulletin - working on this now...
                    • ygarner
                      • Jan 2014
                      • 2
                      I am new also; however, looks like this ss board problem is not. Thanks for the post, I am a retired computer tech, mostly support, training and project management. I would swap out parts and change out boards (even swapped out board on a hard drive to save it). Anyway, since I can't find this board anywhere I am going to attempt this repair. I am not afraid of much other than poor skill. I figure worst case scenario is that the non-working board does not get fixed and I have to find a sub somewhere. Can anyone point me in the right direction for parts and supplies.
                      • ygarner
                        • Jan 2014
                        • 2
                        I found parts posted in the tech bulletin for this repair at Panasonic Parts website pstc.panasonic and it will cost a fraction of the price for a board or substitute board.
                        • spiker
                          • Aug 2014
                          • 2
                          Hey guys, I found this forum because my just a couple of weeks past warranty TC-P50U50 has developed the 8 blinks of death. Is there a simple way to determine that the SS board is the culprit? I have a limited amount of electronics knowledge, but I can use a VOM. Thanks in advance.
                          • tw2005
                            • Oct 2011
                            • 6458
                            If it were me i'd read the service bulletin and check if the diode and transistor are shorted .
                            use either resistance or continuity / diode mode with the meter . diode has legs marked A & K, measure between those, with the transistor check between all combinations of 2 legs.
                            • spiker
                              • Aug 2014
                              • 2
                              Ok, ordered the board from these guys at a hefty price (but still cheaper than having a shop do the work). The box has a notice saying there is a core charge. I'll be calling tomorrow to see if I can get some of that coin back.
                              http://panasonic.factoryoutletstore....FScV7Aod72IAwA
                              I watched this video on Youtube, which was helpful to learn how each connector is removed.
                              http://www.youtube.com/watch?v=GSKAmP65sHw
                              And Voila'....I now have a working Plasma that looks as good as it did before it took a cr@p.
                              Thank you everyone on the forum for being a help.
                              If anybody finds out about a class action suit against Panasonic let me know. I'm in.
                              • tw2005
                                • Oct 2011
                                • 6458
                                Well it's great your happy the TV is working. If you have anymore issues with failed boards repairing them is always an alternate option especially with a known fault and a repair that only requires 3 or 4 components replaced.
                                http://www.moduslinkptstvboards.com/TXNSS1SDUU/
                                • Jimboskeet
                                  • 7
                                  I know that this is an old thread but I need help in getting the right parts for the same issue.
                                  The bulletin lists DG3D3020CVLW, B0FBCN000005, D0GF5R6JA047 as replacement parts.
                                  I usually order from Digikey or Mouser can anyone get me the cross reference to what I need.
                                  • paulstef
                                    • Dec 2013
                                    • 724
                                    Thanks for that link, very helpful. It seems I'm lucky enough and only the IGBT is shorted.
                                    I did some research and there is really no easily available substitute for this IGBT in a TO220 Full-pak with the characteristics it is supposed to have.
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      http://www.digikey.com.au/product-de...3TU-ND/2269819
                                      That's what I'd try if I was thinking of trying a different make.
                                      • paulstef
                                        • Dec 2013
                                        • 724
                                        The guy with the repaired TV called me back and said there is noise coming from the TV. So I opened it up and yes, the solder pads from the screws where black again, so there was sparking.
                                        The two solder pads for the two screws right next to the parts that blow up are already connected via a tiny trace on the board. That means the trace's inductance causes a voltage drop on it. When we tighten the screws the two solder pads are connected via the lower impedance path of the chassis.
                                        Clearly a design failure.
                                        I used dented washers now which should assure a good contact from solder pad to chassis/screw.
                                        When it starts again I think a good way to really solve this is to connect those two solder pads with a thick wire onboard.
                                        • mcquin35
                                          • Feb 2015
                                          • 2
                                          Hi new here and would like to thank you for any help I can get. I have my tc p50u50 with 8 blinks a part. Located ss board and wondered which way to go replacing board or the 3 parts Q16051, D16041 and R16051. Where would I find parts. Any checks I should do. Any help please.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                            Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
                                            by sam_sam_sam
                                            I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
                                            This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • canadaboy25
                                            Panasonic TC-P54VT25 No image. A or D board?
                                            by canadaboy25
                                            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                            The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                                            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                            01-17-2021, 01:06 AM
                                          • Biruslapio
                                            Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
                                            by Biruslapio
                                            Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
                                            It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
                                            It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
                                            02-16-2021, 09:44 PM
                                          • mmischni
                                            Panasonic Viera Plasma TH-42PX75U 7 Blinks/8 Blinks/burned P board?
                                            by mmischni
                                            Greetings friends,
                                            I have a Panasonic TH-42PX75U manufactured in 2007. It has been trouble-free until recently. One evening I turned it on and it then powered back off and gave 7 blinks.
                                            First a question about the blinks. Everyone only speaks of a single number of blinks. I noticed on my TV, it blinks one fewer times for the first group of blinks, then blinks the full number repeatedly. So for my first code in question, the TV switches off, blinks 6, then blinks 7 repeatedly. When I disconnected the SC board, the TV switches off, blinks 7, then blinks 8 repeatedly....
                                            09-06-2017, 08:52 PM
